Old 02-23-2006, 11:49 PM   #1
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
Default gd knuckles fit a gc?
so my local junkyard has a 05' wrx with some ugly side damage. i was going to steal the brakes but i thought i'd check some things. i thought that the front cailpers had a mounting bracket that spaces them away from the rotor, but
thease dont have them (the rotors arent with them, maybe they were taken too?). do they have brackets or do they just bolt to knuckle? i think that the knuckles (front and rear) will bolt right up to the old style subbies but i thought i'd ask before spending the cash to be sure. also, will the master cylinder work,
or so i need the whole booster too? i didnt really look at it but would i run into an issues with the abs stuff ? i dont really know if subarus have a abs motor or if its a master cylinder thing since mine doesnt have one.
josh...just josh is offline   Reply With Quote
Old 02-24-2006, 02:47 AM   #2
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
I know the rears bolt right up (I used WRX ones for my drum-to-disc swap). Don't screw with the master cylinder if you don't have to. I don't think the WRX one is all that much bigger. If anything, go with an SVX one.
US2JDM is offline   Reply With Quote
Old 02-24-2006, 08:53 PM   #3
josh...just josh
Member#: 82273
97 impreza L
thanks, the front ones are the ones that i'm really worried about, someone has to know this!
Old 02-24-2006, 09:30 PM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
I don't know about 05. But i do know that 04's fit the GC's. From the parts cache i have laying around, i needed a front wheel bearing badly for my 95 L. Being the nut that i am.. I decided to see if maybe some of the parts from the 04wrx would work. Took the old knuckle off, grabbed the 04, held them side to side..
And sho nuff. Exactly the same minus 1 thing. The 04 has the hole for the abs wheel speed sensor in the casting. No problem. Slapped it on, worked perfectly. Hell even my alignment didn't change.
subbyspeed is offline   Reply With Quote
Old 02-24-2006, 09:59 PM   #5
josh...just josh
Member#: 82273
97 impreza L
thanks guy, does anyone know if the suspension stuff will fit?
Old 02-25-2006, 04:47 AM   #6
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
front suspension is supposed to fit. i have version 8 JDM 4 corners on my car (knuckles an brakes)
check this thread.
http://forums.nasioc.com/forums/showthread.php?t=907818
swapstar is offline   Reply With Quote
Old 02-25-2006, 05:40 AM   #7
RayQuon
Member#: 43259
1999 2.0RS
RBP
I happen to need the rear driver's side knuckle/hub/bearing assembly. Would you be willing to pull those parts for me? I'll pay for shipping, the actual cost, and whatever labor costs you would like to see. I can't find these parts anywhere locally. thanks.
RayQuon is offline   Reply With Quote
Old 02-25-2006, 12:54 PM   #8
josh...just josh
Member#: 82273
97 impreza L
well, i'm actaully planning on swaping all four knuckles until my car, my brakes suck real bad. i've heard that the struts from the gd fit if you the tophats too. does anyone know abou this? and does anyone know about master clyinder fit?
Old 02-25-2006, 12:57 PM   #9
josh...just josh
Member#: 82273
97 impreza L
the gd hubs (front/rear) are the same spline as the gc's arent they? the wrx's anyway right?
Old 02-25-2006, 01:05 PM   #10
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Yes they are the same splines.
speedyHAM is offline   Reply With Quote
Old 02-25-2006, 06:11 PM   #11
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Splines for the axles, or bolt pattern? The GD's were 5x100, until the 05 STi.. I don't know about the wrx from that year.
The actual thread pitch on the wheel studs changed at some point.. Cause the 04 knuckle i put on my car was different from the 95 version.
Old 02-25-2006, 11:59 PM   #12
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Everything should be the same except for some minor changes for stregth. I have a 93, 95 and have a set of JDM STi ver.7 spec. C front hubs and R180 rear setup under my 93. I have switched hubs between the two cars keeping the same wheels and lugs that were originally on each car with zero problems. The WRX braks will fit. The 4-pots will fit, and for those that don't like the brembos or don't want to be stuck running 17's if you shave down the brembo disk you can mount the rear group N 2-pot right on the r-180 rear hub.
Wayne_Coots is offline   Reply With Quote
Old 02-26-2006, 01:04 AM   #13
Damon
Member#: 2902
karma is gonna get ya.
Damon is online now   Reply With Quote
Old 02-26-2006, 03:16 AM   #14
myver8
Member#: 100817
2004 subaru
Default yes this can be done
go to car car-part.com you can get hubs from any legacy,impreza,froester(exc.wrxsti)from 89-05 any maybe 06 too all will fit on your car for sure (i recently put 04 wrx spindels in the front of my 93 impreza l and 02 forester hubs in the rear 50 a corner from a local junkyard
only difference is the hole for the abs sensor
car-part.com
myver8 is offline   Reply With Quote
Old 02-26-2006, 04:27 AM   #15
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
car-part.com
w3rd! i was wondering if i was the only one who's thought of that. I knew i wasn't!
Old 02-26-2006, 04:41 AM   #16
moss
Member#: 10197
So hubs are all the same? No alignment issues or anything? doesn't push anything out?
I've got axles attached to JDM 02 hubs and its looking like it'd be easier just to put everything up together and swap out the hubs.
moss is offline   Reply With Quote
Old 02-26-2006, 11:33 AM   #17
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i had no alignment issues putting an 04 knuckle on my 95. If you start swapping control arms and crap like that, then you'll run into problems
Old 02-26-2006, 12:28 PM   #18
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
front track i didnt notice a differance. the GD knuckle is superior to the GC, unless you have a STi-RA ver 2 Gc8 front knuckle :P
i actually swapped my ra ver 2 gc8's for GDBs, and would do it again for slight reasons (arguably better, arguably not)
Old 02-26-2006, 01:28 PM   #19
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
care to share?
Old 02-26-2006, 08:29 PM   #20
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
Yes, Please do!
Old 02-26-2006, 08:32 PM   #21
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
What about using Legacy knuckles on an Impreza? I know someone has tried it. What are the results? I was told that they are better than even the GD's.
Old 02-26-2006, 09:39 PM   #22
moss
Member#: 10197
hmm... then we might be putting the whole driveline in as is
Old 02-26-2006, 09:41 PM   #23
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
early Sti-RA has really light forged knuckles with kinda a I forging like a rod. no abs hole either.
legacy seems to be identical to impreza, although my experiances are limited mainly to impreza. legacy r160 rear knuckles seem identical to gc8 though.
GDB (at least the ones on my carjdm v8 5x100) have brace webing of sorts. i have a picture somewhere, will find and post when the chance appears. stiffer for sure, heavier though. if you were building a drag monster that didnt need to stop......
perhaps the bearings are biggor. perhaps they are the same. i not in the know.
5x114 should be slightly differnt im thinking.
it seems also that the geometry was revised ever so slightly. my steering wheel dead spot seemed a little smaller and the turn in was a litle easier (not better, just seemed easier). caster?
Old 02-26-2006, 09:53 PM   #24
moss
Member#: 10197
Hmm... mine are V7 non-STi (NBs).... I'll have to look at them this weekend.
keith
Old 02-26-2006, 10:58 PM   #25
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
wasn't one of the main reasons for subaru switching from the 5x100 to 5x114 primarily to be able to use a larger wheel bearing? Thats what i've heard and been told.
GD Knuckle/bearing/hub assembly fit on GC's? MyFirstDeuce Brakes, Steering & Suspension 2 01-08-2006 04:13 PM
Any experience with fitting a GC FMIC kit on GD models? Ixx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-01-2005 04:16 PM
anyone know if floor mats from a GD will fit a GC okay? beaudawg North West Impreza Club Forum -- NWIC 3 10-25-2004 12:37 PM
Turboback from new age/GD fit a GC body? annointed Subaru Conversions 8 07-06-2004 02:25 AM
GD skirts fit GC chassis? garface Interior & Exterior Modification 6 08-13-2002 04:35 PM
