Old 02-24-2006, 08:59 AM   #1
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
[email protected] mph
Default Where is atmospheric pressure sensor located?
I have been doing some work on my intake system, and was wondering where exactly the atmospheric pressure sensor is located. Is it internal to the intake system, or does it measure underhood pressure, external of the intake system?
Since our boost systems are based on relative pressure, it would seem that any increase in atmospheric pressure would directly correspond to more absolute boost, and thus more power. I obviously can't change the actual atmospheric pressure, but if the sensor is in the intake system, there may be ways to artificially raise the value, or at least make sure it is not lower than actual atmospheric.
IndyRacer is offline   Reply With Quote
Old 02-24-2006, 09:44 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
There's a barometric pressure sensor on the ECU's circuit board and a manifold absolute pressure sensor just behind the throttle.
Jon [in CT] is offline   Reply With Quote
Old 02-24-2006, 10:11 AM   #3
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
Thanks Jon. Not the answer I was hoping for, but the answer none the less.
Now, how does the ECU adjust boost (manifold relative pressure) to account for differences in atmospheric pressure? Does it use the sensor in the ECU to account for elevation changes, weather, etc.
Old 02-24-2006, 10:14 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the atmospheric pressure is sensed by the map sensor after ignition power is applied but before the engine turns over.
Old 02-24-2006, 10:14 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jon, are you sure there's actually a sensor on the oem ecu board?
Old 02-24-2006, 11:16 AM   #6
hondaeater69
Member#: 60324
for reference the stock barometric compensation table for WGDC looks like this:
baro- 8.51 9.75 10.98 12.22 13.36 14.7
WG% 18.75 18.75 18.75 18.75 18.75 0.00
expressed as a % added to WGDC.
Boost limits are also cut under lower atmospheric pressure.
Old 02-24-2006, 12:20 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
Yes. For instance, the only step in the diagnosis of a P1110 trouble code (Atmospheric pressure sensor low input) is to replace the ECU.
Old 02-24-2006, 12:38 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
very interesting!
well in that case, strike my earlier comments on it determining atmospheric pressure via the underhood MAP sensor.
Where is the knock sensor located on an 04 WRX? shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-09-2009 12:54 PM
Where is the MAP SENSOR LOCATED on 2002 wrx? plus plus plus Water/Methanol Injection, Nitrous & Intercooler Cooling 11 05-19-2007 09:52 PM
Where is the O2 sensor, located compfool Service & Maintenance 2 04-21-2006 10:53 AM
Where is the cam sensor located? Shaitiger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-05-2004 02:10 PM
Where is the crank sensor located? (N/M) gronemeyer Normally Aspirated Powertrain 10 08-19-2001 10:33 AM
