Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-24-2006, 12:51 PM   #1
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Default Tinkering with UTEC knock thresholds...
I had an idea that might be useful, might be annoying, might just not work. Goes like this: set the thresholds of knock in the range I can get above 1 bar boost pressure (so like 2k range and up I guess) so that the UTEC thinks I'm always knocking a certain ammount, like 10. Obviously also change the dynamic timing retard to something like 11 count and less */noise. That way you can log whenever you want and know relative to your tune if you are quiet, on spot, or knocking. Normally you only know you are below your threshold, but not by how much.
It relies on the question: does a more "successful" burn create more engine noise or is the knock detection in the UTEC only good for a "its too late" scenario? Has anyone tried this?
cdvma is offline   Reply With Quote
Old 03-12-2006, 02:03 AM   #2
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Cool idea have you tried this? Any logs?
santofontana is offline   Reply With Quote
Old 03-12-2006, 11:26 AM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I haven't tried yet
It relies on the engine being louder the "better" the burn is...I don't know if this is true.
Old 03-12-2006, 06:14 PM   #4
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Even if the burn is not louder when its better, you will be able to see more in the logs, and maybe we can learn what to look for after analyzing some logs. Kind of like digital det cans for the deaf.
properly set utec knock thresholds ride5000 UTEC 9 08-25-2006 01:14 PM
Recommended UTEC Knock Threshold settings for STi? STI05 Engine Management & Tuning 3 10-31-2005 10:15 PM
UTEC Knock threshold safe setting values help AXA Engine Management & Tuning 12 10-07-2005 10:35 AM
Need help with UTEC knock asap!! Brewmaster New England Impreza Club Forum -- NESIC 13 10-01-2003 07:58 PM
UTEC Knock Thresholds D_REX Engine Management & Tuning 2 09-22-2003 06:22 PM
