Old 02-24-2006, 02:02 PM   #1
myver8
Member#: 100817
2004 subaru
Default transmission swap
hey guy's need to know how to get my 93 impreza mechanical speedo to work with a 03 forester 5speed (electronic speed sensor) !!!!!!!!!!!!!
installing 03 forester transmisson in a 93 impreza
also need the diagrams for the 93 impreza if any one could get them to me
Thanks alot, guy's
myver8 is offline   Reply With Quote
Old 02-25-2006, 02:30 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I am fairly sure that if you rip out the cluster and disassemble the speedo receiving box there will be one or two wires you can hook the '03 electronic speed sensor to and it will work. Don't kill me if I'm wrong, but let me know if it works.
speedyHAM is offline   Reply With Quote
Old 02-25-2006, 03:39 AM   #3
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
All you have to do is unscrew the electronic speed sensor from the forester transmissions, unscrew the speedo cable from your impreza transmission, and then screw the cable back into the forester transmission after you get it bolted into the car. Very very easy, and also very common. I love my "legos"
wrx_driver_2002 is offline   Reply With Quote
Old 06-03-2013, 08:05 PM   #4
Shawn1640
Member#: 356306
Default 02impreza 2.5L transmission swapped into an 01 forester 2.5L now having an issue some
i own an 01 forester S that the manual transmission went out on and i replaced it with an 02 impreza manual transmission. now the problem im having is when i shift into gear and let off the clutch it just grinds and wont go fully into gear but if i take out the shift linkage and put it into gear manually it works fine im lost do i need to change the linkage to are the linkages different im kinda lost someone please help me inbox me if u have any suggestions thanks p.s. the only gear i can go into fully is reverse
Shawn1640 is offline   Reply With Quote
wrx swap along with manual transmission swap? hail2theTheif Subaru Conversions 3 03-28-2005 03:43 PM
Transmission swap... stentorian Transmission (AT/MT) & Driveline 5 01-09-2002 09:29 PM
Manual transmission swap into an SVX? Rownan SVX Forum Archive 5 02-23-2001 04:11 PM
transmission swap extanker Newbies & FAQs 1 01-25-2001 10:07 PM
Transmission swap Jay Technical Forum Archive 0 06-06-2000 01:08 AM
