Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 02-24-2006, 08:34 PM   #1
drkg
Member#: 108441
'02 WRX
Default Gages: EGT or AFR
Which is a more important engine monitor/tuning tool
Part of this spring's round of mods is going to be putting in some gages to help me watch what my engine is doing. I can't decide which will be more useful in monitoring my fuel ration: an acutal AF gage or Exhaust Gas Temp. My Buschur Racing TBE icludes a high flow cat(emmissions testing), and I'm using a factory O2 sensor.
Also, since its the first set of aftermarket gages I'm installing in my WRX and I'd like any others I may add later to match what I'm going to install now- this would be the perfect time to take reccommendations as to which brand to use. I'm leaning toward Stewart Warner.
drkg is offline   Reply With Quote
Old 02-24-2006, 08:38 PM   #2
-Kevlar-
Member#: 82378
an A/F ratio gauge is, for lack of a better term, a light show. its fairly accurate, but i wouldnt trust money on it. for more accurate readings, monitoring, tuning, get a egt gauge. (and a wide band O2)
-Kevlar- is offline   Reply With Quote
Old 02-24-2006, 10:19 PM   #3
drkg
Member#: 108441
'02 WRX
Thanks. That's kind of what I was figuring, but I don't like to buy anything without getting at least some recommendations.
Old 02-24-2006, 10:54 PM   #4
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
I have both.
Air fuel ratio is indeed useless, unless you get a wideband one. I own a PLX Devices M300 and I will never attempt to modify another car without of of those; it is just so incredibly useful! It will tell you almost everything you need to know, instantly, and with extreme accuracy.
I also have a Greddy Digital EGT gauge. The probe is mounted right at the meeting point of cylinders 1 and 3, some 2 inches from the head.
It reads its highest at high speed cruise; 90MPH in 5th will show 810C when the AFRs are close to 14:1. If I nail the throttle boost builds, the AFR will *instantly* drop, but the EGT takes a while to get moving. Similarly, if I floor the car from a low speed the AFR will respond in a microsecond, but it may take 5 seconds untill the EGT probe has warmed up to the real temperature of the gases going around it. It just takes time to heat things up; there is no way around it.
As such I will say that, for experience, an EGT probe is nearly useless. If your tune is bad enough that it will cause unsafe EGTs, your engine will pop before you ever get to see them. AFR is a much faster way of knowing what is up inside your engine.
Gauge pillar: Boost and EGT (top and bottom)
Center Pod: Apexi S-AFC-2 (Knock, air/fuel ratio control, engine RPM, %airflow into engine, battery voltage)
Ashtray (under stereo): Wideband Air/Fuel Ratio.
powerlabs is offline   Reply With Quote
Old 02-24-2006, 11:23 PM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I disagree. If you get a probe that isn't slow like molassas in January you will see EGTs in very close to real time. I've had great AFRs and a non-agressive timing curve (street tuned) but watched my AFRs skyrocket quickly. A little more timing I was all set. I wouldn't have known this without my EGT gauge and would probably be posting "crap, lost a ringland" by now if I haven't had it. IMHO if you are tuning you need a wideband and EGT to do the job properly.
cdvma is offline   Reply With Quote
Old 02-25-2006, 11:04 PM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I have both.
Thats funny..... it looks like on your speedo, after the 80mph mark, the next indicated speed is 400mph.....
jigga is offline   Reply With Quote
Old 02-25-2006, 11:57 PM   #7
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
^ haha, your right,looks like 400.
I agree with powerlabs, if you have the money, get a wideband.
zietronix offers an awesome setup with little cluter, it includes AFR, boost, egt and lambda in a small, yet readable screen. I love mine. for all it does, its very cheap.
the_colombian is offline   Reply With Quote
Old 02-25-2006, 11:59 PM   #8
hondaeater69
Member#: 60324
if you're going to tune your own car, you need a WB. If you just want to monitor things, get an EGT.
EGT vs AFR gauge (wideband) Carlito2002WGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-30-2007 05:30 PM
SoCal: 02 DEFI Gauge Pod: Greddy 60MM EGT/Boost/AFR RDJ Private 'For Sale' Classifieds 12 03-16-2006 06:59 PM
Brand new Autometer ProComp Ultra-Lite Gauge Set: Boost, EGT & AFR Thug Private 'For Sale' Classifieds 19 12-15-2004 09:46 PM
s-afc tuning. EGT or A/F gauge, what do have? why do you like it? munkis Normally Aspirated Powertrain 21 03-29-2002 12:32 AM
