Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-13-2006, 02:17 AM   #1
GlennB
Member#: 99926
2003 Bugeye
awdtuning.com
Default help troubleshooting UTEC...
howdy howdy folks. i need some help with my UTEC. just got it installed and have the red light so i know everything is installed properly as far as hardware goes. now, when i try to sync the UTEC to my laptop its not working. i go through the hyperterminal and it says its connected but its not pulling up the UTEC screen, it just stays white. i was reading the manual and it says the UTEC should be set on com1; well i don't have a com1. i only have a com3. other than that everything was set to the exact specifications of the user manual. what am i doing wrong?
GlennB is offline   Reply With Quote
Old 04-13-2006, 08:41 AM   #2
gpatmac
Member#: 18446
2002 WRX wagon
psm
Sorry for the snap response but after you're ht is connected, have you tried hitting the esc key?
gpatmac is offline   Reply With Quote
Old 04-13-2006, 10:58 AM   #3
TurbojonLS
Member#: 38772
2 Cars, No Bling
Or hit any key once you've connected.
TurbojonLS is offline   Reply With Quote
Old 04-13-2006, 01:49 PM   #4
GlennB
Member#: 99926
2003 Bugeye
awdtuning.com
ok, i tried your suggestions and they didn't work. i called turboxs and they asked me if i was using a USB to serial port connection and i am. well they had me go through my device manager and go to the ports. i don't have the software for this type of connection on my laptop. does anyone know where i can go to download or buy this software at? this would be a tremendous help.
Old 04-15-2006, 03:58 PM   #5
KitchenerWRX
Member#: 79934
02 WRX
MBP
bump im in the same position
KitchenerWRX is offline   Reply With Quote
Old 04-15-2006, 04:18 PM   #6
AaronWRX
Member#: 7194
2011 997.2 Turbo
What operating system are you using?
AaronWRX is offline   Reply With Quote
Old 04-15-2006, 07:37 PM   #7
phatfil
Member#: 15956
13 XV Crosstrek
13 FR-S Asphalt
Same here, but I do have the software for my connector. XP pro, using com4. I changed the speed to 19200 in device manager for com4 and for com4 using hyperlink is also set to the 19200 and i can connect but nothing on screen except a few little characters when i start the car, m m upside down exclamation point etc.
phatfil is offline   Reply With Quote
Old 04-15-2006, 08:25 PM   #8
pclement
Member#: 92332
2002 Impreza WRX
bump me.
pclement is offline   Reply With Quote
Old 04-15-2006, 08:26 PM   #9
pclement
Member#: 92332
2002 Impreza WRX
bump to five posts.
Old 04-15-2006, 08:26 PM   #10
pclement
Member#: 92332
2002 Impreza WRX
See if the following helps:
http://www.modemsite.com/56k/xptip.asp
Old 04-16-2006, 07:52 PM   #11
Lost_Pete
Member#: 100570
You need to adjust your settings in Hyperterminal not in device manager.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 04-17-2006, 10:15 AM   #12
phatfil
Member#: 15956
13 XV Crosstrek
13 FR-S Asphalt
Thanks Pete but I did that already and still wasn't getting the black screen, A local nasioc member(TyranosaurusWRX) helped me out and found out that my converter was the problem. You can't use the cheap converters off ebay, as he had the same problem before and then purchased a $30 radio shack converter and everything was fine after that.
Dog box/stuck gear -- need help troubleshooting... 8Complex Transmission (AT/MT) & Driveline 2 07-21-2003 05:49 PM
Help troubleshoot--started getting misfire CEs Jon Bogert Normally Aspirated with bolt-on Forced Induction Powertrain 3 05-16-2003 08:59 PM
Help troubleshooting suspension problem. peepshow Brakes, Steering & Suspension 7 05-09-2003 04:01 PM
Desparately seeking help troubleshooting! cpu77 Electrical & Lighting 4 03-19-2003 07:53 AM
Help troubleshooting dyno plots please. lenyx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-08-2002 11:25 AM
