Old 02-24-2006, 10:46 PM   #1
leoxephen
Member#: 107724
Default 98rs engine swap
I am planning on getting a 98rs and putting a sti shortblock and 2.5 heads on would I have to replace all the electronics, wiring and censors or could I just put a ECU on there and it would work?
leoxephen is offline   Reply With Quote
Old 02-24-2006, 11:41 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I'm going to try to translate that, hope i'm right.
I am planning on purchasing a 98 2.5RS, I want to put in a STI Shortblock and use the DOHC 2.5 heads. Will I have to replace all the sensors and wiring, or can I just use the 98 RS ECU?
The heads will work fine and you can use the sensors from the original RS motor, you won't have to change wiring OR the ECU. It would be best to get the STI Oil Pump and Water Pump, you should use the STI Head Gaskets as well. The 98 ECU will work but it may throw a CEL because it is not used to running a motor with such low compression.
I'm guessing you are going to boost the engine, if so it would be wise to change the valve springs. I would personally use some aftermarket EM but that is up to you.
Old 02-24-2006, 11:43 PM   #3
Master2192
Member#: 83254
98 2.5 RS
04 WRX
And here is a link I put in another thread about putting the STI Shortblock in a RS
http://forums.nasioc.com/forums/showthread.php?t=601588
Old 02-25-2006, 01:27 AM   #4
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
If you don't boost the engine you will have possibly the weakest Subaru engine since the 360.
So boost it, get some EM, find me at a racetrack and proceed to kick my ***.
P.S. Take pictures, post em and share the joy.
speedyHAM is offline   Reply With Quote
Old 02-25-2006, 01:26 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
ECU wont throw a CEL, your 98 RS is maf based right? that means it will calculate volumetric effeciency based on o2 sensor and maf signal, it will just be slower than crap.....unless of course you boost it. if you do boost it, do yourself a favor and get better valvesprings.
~Josh~
02 5mt swap with ej205 engine swap Gamble_WRX Drivetrain 11 04-01-2010 04:40 PM
Engine swap, '06 2.5i into '00 2.5RS--Direct swap? singincanary Subaru Conversions 13 10-01-2007 09:47 PM
98Rs - STi swap - parts list and Opinions... mjd85la Subaru Conversions 5 09-26-2005 02:50 PM
98rs engine developing oil leak vet Normally Aspirated Powertrain 9 02-04-2005 09:22 AM
Engine swap or car swap? AcquaCow Subaru Conversions 21 07-18-2003 12:10 AM
