Old 02-25-2006, 01:20 PM   #1
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
Default ecu pins
Does anyone know if Radio Shack or Fry's Electronics would carry the ecu pins? I have the pins for the black connector to hook up the avcs but the pins I have are then too big to fit in the white ecu connectors on the stock harness. I only need to get 4 to hook up the solenoids to the hydra.
if anyone knows the correct size let me know! thanks
dan avoN7 is offline   Reply With Quote
Old 02-25-2006, 01:47 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
The pins you need are probably described in http://techinfo.subaru.com/html/down...p?doc_id=68814. There's a cross-reference on the last page. Maybe a Subaru dealer will sell you some.
Jon [in CT] is offline   Reply With Quote
$$$ Reward - JDM STI ecu pin diagram and engine wiring diagram- OK $250.00 cash ! alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-20-2010 09:49 AM
ECU pins and engine harness pins??? MK19_ Electrical & Lighting 3 04-21-2005 07:10 PM
I need ECU pin out for Euro specs WRX Santo Domingo 2.5 RS Engine Management & Tuning 0 12-09-2002 09:47 AM
2002 2.5 RS ECU pin out PunKidd Normally Aspirated with bolt-on Forced Induction Powertrain 0 02-17-2002 11:17 AM
MY99RS ECU pin outs? time for the TEC-II Joe Hogan Technical Forum Archive 5 07-26-2000 07:55 PM
