Old 02-25-2006, 02:57 PM   #1
subieracer18
Member#: 72904
Default Gm BCS Tuning
I need some help with tuning the gm bcs with the utec. I can get it to hold 16.5# in 3rd gear but when i shift to 4th it spikes all the way up to 20#. I am new to tuning the utec and would like any help i can get. I'm only running the utec base stage 2 map so i'm trying to tune the boost to what turboxs says.
subieracer18 is offline   Reply With Quote
Old 02-25-2006, 04:54 PM   #2
rewt
Member#: 60794
2007 Solstice GXP
I'm not an expert, but try lowering (raising) the boost gain; basically, the higher the number the less likely it is for your boost to overshoot, but the trade-off is slower spool. Since you're running the GM (I would presume in interrupt configuration), you should still spool faster than, or at least as fast as, stock.
Its in your UTECs parameters...
rewt is offline   Reply With Quote
Old 02-25-2006, 06:37 PM   #3
subieracer18
Member#: 72904
interrupt configuration? I hooked it up as per the directions on http://jyg.us/wrx/gmbcs/
Old 02-25-2006, 07:36 PM   #4
rewt
Member#: 60794
2007 Solstice GXP
I read through the directions you posted, and you've got it connected in the style I referred to.
Tuning Boost after GM BCS install bucket7788 Open Source Reflashes 62 05-31-2010 01:16 AM
My car has GM GM BCS but was tunned with Factory BCS davedavis1981 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-08-2008 06:34 AM
Issue with GM bcs and new tune Dragula Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-25-2007 11:39 PM
GM BCS or any aftermarket BCS for tuning an FP Green? BlackSTI2006 Engine Management & Tuning 0 04-15-2007 01:51 AM
Noisy GM BCS, pics of your quiet GM BCS mounting??? disque71 Newbies & FAQs 2 12-11-2006 11:27 PM
