#1 |
Member#: 89505
Vehicle:1998 Impreza 2.5 RS Black Diamond Pearl |
ok this is really weird. i have a 98 2.5 rs, and there is alot of smoke/steam coming out of the radiator when i stop. it seems to do it more when its wet or snowing out, but it's not normal because there is ALOT of it. i have brand new HG's, not overheating, not losing coolant, just had the radiator pressure tested and its fine, i have and injen CAI but there is a waterproof pre-filter on it for the winter. nothing is wrong with the car at all it run perfect, but when i stop it does this. anyone have any ideas or more questions, i'd love the help
#2 |
Member#: 89505
also, i have the knocking noise that is semi normal on cold engine, but could my timing belt tensioner be bad? and does that have anything to do with the smoke? i have no idea....the knocking seems to go away mostly after warming up, but it miught not go away completely, not sure
#3 |
Member#: 89505
someone help?
#4 |
Member#: 100444
on my 98 it would also do that, on mine it was the front main seal leaking. Does it smell like coolant?
#5 |
Member#: 96154
Vehicle:98 2.5RS Red |
Does it smell like coolant, are you ever seeing any fluid of anykind underneath, how is the level of your other fluids? Check all of those before it may become too late depending on the problem :-\
Billy |
#6 |
Member#: 89505
yea it does smell like coolant, but im not losing any. what will it do if its too late...i had my front seal and both cam seals done about 5000 miles ago, along with the timing belt...so i really doubt its those. i'll take anything though, whats going on here??
#7 |
Member#: 89505
come on scooby specialists...anything? im lost here
#8 |
Member#: 89505
bump...
#9 |
Member#: 21293
Vehicle:05 OB Black Bean 1969 W-30 |
You have a leak.
Was the system pressure tested when it was warm? I know there is pressure in the system when it is hot so you have to be careful opening it up, but seals expand when hot/warm and they dynamics change. Try testing when the system is warm. I have seen a pin hole leak in a water pump spray an almost invisible stream of coolant onto the radiator and smoke. When the system was cold it wouldn't get a drip at the seal when pressured for 30 minutes+. Not even enough to register as loosing coolant but it was. Just a thought. Peace, Greg |
#10 |
Member#: 96154
I believe you can also pressure test the system with the engine running....this would make it slightly safer....as you don't have to remove a hot cap. Just be careful to relieve the pressure test pressure before you remove it off the radiator neck.
Hopefully you figure out something soon. As long as you keep an eye on your coolant level, and other fluid levels....it shouldn't be bad. Don't let it get too low, as you will roast your motor if the coolant is gone! Billy |
#12 |
Member#: 89505
thanks alot guys, do i have to take my car somewhere to get this done or can i do it....and if so what do i need for it. oh and if its leaking then its the water pump? or is there other places it could be leaking...i dont need a whole new radiator do i? thanks again
| Thread Tools | |
| Display Modes | |
| So whats burning when smoke is coming out of exhaust... | WolfInSheepsCLothing | Factory 2.0L Turbo Powertrain | 19 | 07-04-2008 11:34 PM |
| help smoke coming out of hood scoop ? | phat pat | Factory 2.0L Turbo Powertrain | 7 | 08-04-2004 03:43 PM |
| Uhh... smoke coming out of my hood vent.. Clutch? | Siper2 | New England Impreza Club Forum -- NESIC | 14 | 06-10-2002 10:39 AM |
| Smoke or exaust coming out of my turbo??? | dgp | Factory 2.0L Turbo Powertrain | 3 | 04-10-2002 03:42 AM |
| Smoke/Steam coming out of vents?? | HonduhEater | Factory 2.0L Turbo Powertrain | 6 | 07-24-2001 06:03 PM |
