Old 02-25-2006, 06:37 PM   #1
quynce
Member#: 15409
Default Oil change in '06 not as easy as before
Today I changed the oil for the first time in our '06 2.5i wagon. Coming from my old WRX and RS, this was a major PITA! The filter is now completely surrounded by the headers, making it very difficult to get to. There isn't enough room to get a plier-style filter wrench in there, which is all I had. I bought one of those swivel wrenches, but it was also too big. I ended up using my old wrench and getting at it through the top. The fit is very tight there as well and I barely got it off.
I assume we have the new EL headers to thank for this? Does the fact that it is a 4EAT matter?
Does anyone have any suggestions? The dealer didn't sell any tools. I think one of those filter wrenches that you put a 3/8" drive into would work well.
quynce is offline   Reply With Quote
Old 02-25-2006, 06:51 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
you shouldnt need a wrench to take it off. when you install it you get it on till it touches the oring, then go like another half to a full turn.
Shane
PARANOID56 is online now   Reply With Quote
Old 02-25-2006, 07:58 PM   #3
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Unfortunately there both the same.
That's what will work best. Use one of those with a 6" extension.
Burnout is offline   Reply With Quote
First oil change on '06 WRX and mild panic setting in Heavy Fuji Service & Maintenance 41 12-28-2006 07:30 AM
2nd Oil Change on '06 STI - Dealer Overfill eSToI Loco Warranty Issues & SOA Problems 18 12-25-2005 07:54 PM
Would the EJ22 bolt into an EJ18 as easy as the EJ25 bolts in? Max Umbarger Subaru Conversions 16 02-27-2004 11:51 AM
Is stripping a gear as easy as it sounds? bluebaru wrx Transmission (AT/MT) & Driveline 3 12-11-2003 12:04 AM
Rear Sway Install: As easy as they say! grimlock Brakes, Steering & Suspension 8 12-14-2000 12:44 AM
