Old 02-25-2006, 08:04 PM   #1
subeesteve25
Guest
Member#:
Default quick help???
05wrx stage 2 91 base map. So I went to read my live boost with my aceessport and the car is idling and it says -8.3 is this right. how do i use the ap to read live boost
Old 02-25-2006, 08:18 PM   #2
hondaeater69
Member#: 60324
um, that sounds about right for idle. TO read live boost just leave it plugged in as you drive with the read live boost selected.
Old 02-25-2006, 08:25 PM   #3
subeesteve25
Guest
Member#:
oh ok, yea i just did that. It's kind of hard to read as your driving and kind of dangerous. I maybe saw it at 11psi but i might need a friend in car to read it as i drive. so like 16 psi, will you see it just real quick for like half second then as you back down it drasticaly changes. I guess this is normal so i need someone in my car t read live boost for me
Old 02-25-2006, 08:54 PM   #4
subeesteve25
Guest
Member#:
ok tried again and saw like 13psi in second gear. is this normal, if u are running low, how do u fix it. also i tried checking out the valet mode and when i switched it i looked at current map and it still shows the base map. but then i drove it and at like 3500-4000 im like ohhhh, definetly in valet. So i did antithecft mode and it didnt start, so everything seems to be working. It was just confusing because when i switched maps and then checked the current map it still said stage 2 91. so it does switches to valet or whatever but doesnt say it under current map. i gues current map shows your current base map. Kind of confusing but figured it out through playing with the ap.
Old 02-25-2006, 08:58 PM   #5
r8r4life
Member#: 101464
When you check what map you are running it's telling you what base map you are using.
r8r4life is offline   Reply With Quote
Help! Anyone speak German? I need some quick help! GooseMan Off-Topic 7 10-20-2005 03:10 PM
need help with swap, quick help. (pic request, tranny x-member) Keith Off-Topic 13 09-15-2004 04:35 PM
Quick help please... remove front grill. griffin General Forum Archive 2 01-12-2001 08:08 PM
need quick help regarding dealership shuman New England Impreza Club Forum -- NESIC 11 12-15-2000 03:18 PM
Quick Quick, HELP!! Joe Longworth Car Audio, Video & Security 4 02-11-2000 02:09 AM
