Old 02-26-2006, 05:22 PM   #1
Slow06WRX
Member#: 108181
06 WRX
Default AccessPort question
I recently got an AP, i have a 06 wrx and i'm reading the manual and it says you "MUST USE STOCK INTAKE OR COBB'S SF INTAKE" i use a CAI and was wondering if i need to take this off or is this a way for cobb to try to scare people into buying their intake. i really don't know that much about it so any help would be good.
Slow06WRX is offline   Reply With Quote
Old 02-26-2006, 05:32 PM   #2
waktasz
Member#: 86356
2015 s1000r
wheelie monster
You shouldn't use a CAI unless you have been tuned for it. It can affect how the ECU sees the amount of air coming in an can mess with the AFR.
waktasz is offline   Reply With Quote
Old 02-26-2006, 05:38 PM   #3
Slow06WRX
Member#: 108181
06 WRX
thanks, thats sort of what i thought, i'll just go back to stock intake for now and maybe get cobb's intake and sell mine. there is a guy coming down from atlanta who tunes so i might put it back on when he gets down to florida where i am.
Old 02-26-2006, 05:39 PM   #4
-Kevlar-
Member#: 82378
12345...... just take it off. youll notice no difference unless its for the better (drivability). hell you could possibley put it back on with a protune.
-Kevlar- is offline   Reply With Quote
Old 02-26-2006, 05:50 PM   #5
Slow06WRX
Member#: 108181
06 WRX
thanks again. i have no problem putting the stocker back on, i kept everything i've removed just in case something like this came up and i needed it. like i said i'll just wait for a protune and see what the guy says if he thinks i should put it back on.
Old 02-26-2006, 08:25 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
In english, the meaning of
is VERY clear to me.
I guess there are a GREAT MANY non-english as a first language speakers, here.....
Old 02-26-2006, 11:12 PM   #7
chaddeus
Member#: 56624
2004 Subaru WRX STi
so whats so special about COBB SF Intake? Why is it that only their intake can be used and not other intake?
- Charles
chaddeus is offline   Reply With Quote
Old 02-27-2006, 12:25 AM   #8
WRC51
Member#: 16373
- Charles
Because they make it & offer the maps they know the MAF levels. I think the Perrin Short Ram is another intake that has the same diameter as the stocker.
WRC51 is offline   Reply With Quote
Old 02-27-2006, 12:44 AM   #9
chaddeus
Member#: 56624
2004 Subaru WRX STi
Originally Posted by Cobb Tuning
After market intakes tend to not flow consistently, and they tend to flow with turbulent air. This turbulent air is often not read properly by the air sensor in the intake. When the air cannot be calibrated, there is usually a loss in power. The stock intake is not a restriction on the Stage 1 and Stage 2 street tunes, and it will flow the more consistent over any aftermarket intake.
If what WRC51 say is true, then I assume COBB intake is superior as it will provide consistent flow and non turbulent air which will be read properly by the sensor. Humm.. How is that so?
Is this a marketing gimmick my COBB or am I wrong? Any pointers?
- Charles
Old 02-27-2006, 01:25 PM   #10
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
The Cobb SF Intake has a radiused edge and air-flow straighteners. It also does not change diameter or have any bends that will negatively affect airflow. Other intakes without these features can cause air to move at different speeds, angles, and even loop back past and across the MAF sensor leading to false and inaccurate readings. Some intakes can be tuned for because they are consistent(actual airflow X = sensor measured airflow Y), but others can be problematic because they lead the sensor to read one airflow level when different levels might be occurring(actual airlow X = sensor measured airflow Y = sensor measured airflow Z)
mrbell is offline   Reply With Quote
Old 02-27-2006, 05:18 PM   #11
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Cobb, marketing?!?!?
parker/slc/gc8fan is offline   Reply With Quote
Old 02-27-2006, 07:27 PM   #12
dibblejr
Member#: 94070
05 LGT
COBB marketing still recommended to me to use the stock intake, I even asked about their SS intake and they were honest enough to tell me take off my AEM and use stock for stage 2.
They could have told me to remove my AEM and buy their SS intake.
I got my Protune with the stock intake.
Mike at Innovative Tuning in Seneca Falls did a great tune. Great noticeable gains.
dibblejr is offline   Reply With Quote
Old 02-27-2006, 07:46 PM   #13
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
It depends on your power levels
(Marketing at it's finest )
Exhaust Question + AccessPort Question Nugen Newbies & FAQs 1 10-27-2009 02:55 AM
Cobb Accessport Question - Noob question hlanderr Newbies & FAQs 7 05-08-2006 12:23 PM
Accessport Question Flexx999 Canada Region Forum 5 04-07-2004 03:21 PM
cobb accessport questions skimmilk68 Engine Management & Tuning 18 04-05-2004 08:25 PM
accessPort question oooggss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-17-2003 05:40 AM
