Old 02-26-2006, 06:36 PM   #1
dcwrx2
Member#: 69005
'04 4EAT Wgn
Thumbs up DIY: Cruise Control Light Bulb Replacement With Photos
There are numerous threads helping ppl how to change the burnt light bulb in the cruise control switch, but I think none of them have clear instructions with photos. Therefore I came up with mine after I did it over the weekend. (Thanks to those who spreaded the P/N of the replacement bulbs from RadioShack)
The following photos are taken from my 2004 WRX. I don't guarantee if they should look the same on other models.
1. A cruise control switch looks like this
2. Many ppl said in order to remove the switch, the screws which hold the dash panel will be first removed, etc... But I found this is not necessary. Just remove the little coin box below the switch (which will expose the fuse box), then stick your palm in. Unplug the connection from the cruise control switch, then use your finger to lift the lower "hook" of the switch, then push it out (SEE photo below where has a red circle)
When done, you'll see this: (I have removed the other dummy covers on right of the cruise control switch just for fun, you DON'T have to do this)
3. The bulb is located under that blue cover. Use any small screwdriver to turn counter-clockwise for like 1/8 turn, and it can be removed as shown below:
The factory bulb is quite long in length, and its terminal "legs" go through the 2 holes of the blue cover and then "wrap around" the cover so A) The bulb sits securely on the cover; B) The terminal legs touch the contact points of the cruise control switch and complete the circuit.
4. Use any tiny object (like an extra small screwdriver for eyeglasses, or needle, etc) to pry the wire of the burnt bulb, "unwrap" around the blue cover, and remove the burnt bulb. Next, get replacement bulbs. I chose RadioShack 272-1092 (#7219 Micro Lamp) because this is the only one I know after searched on NASIOC. Price is about $1.50 for a package of 2 bulbs.
5. Insert the new bulb into the blue cover, with the 2 terminal legs go through the 2 holes on the cover, then route/wrap around the cover exactly as how the factory bulb did. When done, cut away part of the terminal leg which is longer than necessary. See below. (Note: The RadioShack bulb is shorter than the factory bulb).
6. Reinsert the blue cover into the cruise control switch, and turn clockwise for 1/8 turn to lock in place:
7. Insert the cruise control switch back to the dash panel, reconnect the connector from behind. Double check the "hook" at the bottom of the switch has lock the switch to the panel securely.
8. Now, ALMOST DONE! Insert the key, turn to ON position, then turn on the corner lights (or lowbeam). Check and see if the cruise control switch glows or not. See below.
NOTE: The right-half of the letter "E" is not really bright, and I believe it is because the bulb length is too short so part of the light from the bulb filament is blocked by the blue cover..... But, I think it's ok and not worth my time to customize an "insulating-gasket" between the bulb and the blue cover in order to "rise up" the bulb a little bit and stands out from the cover.
9. Finally, put everything back to place, it's done!
I can't link too many pics due to rules set by administrator. Please CLICK HERE for the final pic
Cost: ~$0.75 + tax per bulb, plus gasoline to drive back and forth to RadioShack. Altogether it is around a $1.20 DIY job. How much will dealer charge you? FREE if the bulb burnt within warranty period, or $3x.xx (parts) + labor. Dealer does not carry replacement bulb for this switch, but have to sell you as a complete switch (DOH!)
dcwrx2 is offline   Reply With Quote
Old 02-26-2006, 10:22 PM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Nice work, man. Maybe it's time I have at the burnt out CC switch bulb in my car...
Thanks!
specialev is offline   Reply With Quote
Old 02-26-2006, 11:41 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Wow, great job on the write-up
Hank3 is offline   Reply With Quote
Old 02-27-2006, 11:03 AM   #4
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Sweet! I'm going to have to do this for my Foglamp switch...
Old 02-27-2006, 12:16 PM   #5
dcwrx2
Member#: 69005
'04 4EAT Wgn
I'd say it should be similar for the foglamp switch, but there will be 2 bulbs inside that switch. (For example, one under the blue cover and one under the red cover)
I'd guess, the one under the "red cover" will be the indicator light when the switch is at "ON", while the one under the "blue cover" will be similar as of the cruise control switch, which will turn on when you switched on the corner lights / lowbeam.
Old 02-27-2006, 02:00 PM   #6
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
sticky! this should be a thread of note!
and the cruise has two lights too, they look like the same lighting elements from switch to switch.
i just did this, and the 7219 bulbs fit in my holders just fine, the whole filament was exposed and there was even lighting across the whole switch. i had to replace both cruise and fog!
Handsdown is offline   Reply With Quote
Old 02-27-2006, 02:02 PM   #7
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
nice! gj!
Bishop is offline   Reply With Quote
Old 02-27-2006, 02:57 PM   #8
dcwrx2
Member#: 69005
'04 4EAT Wgn
Yeah, I think the bulbs they used are generally all the same, but the physical cruise control switch and foglamp switch are only similar but not the same. For example, the foglamp switch has "dedicated" position of ON and OFF, with ON position = Slightly pushed inward. On the other hand, the cruise control switch stays at same position whether the system is ON or OFF, you can't feel if the button is slightly pushed inward when the system stays ON.
The "red cover" of the cruise control is not wired up (because there is no bulb), and the brown connector at the back of the cruise control switch does not have a terminal for the "red cover". So even if I wire up a bulb under the red cover, it should do nothing.
Old 02-27-2006, 03:35 PM   #9
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
red cover?
my cruise has an orange status light that goes on when it is activated, similar to the green status light in the fog switch... the illumination of the switches appears to be identical though, discounting the wiring plugs and mechanical operation(staying in versus momentary). the orange status light might be an led, i don't know... but there is a bulb holder even if there is no bulb.
i just did this on both of the switches(both of mine were out) and it was the same procedure with flawless results for both
Old 02-27-2006, 03:47 PM   #10
avk
Member#: 17252
'06 WX8
59E
Excellent pics. The same bulb goes into various switches w/o removable sockets, and can be replaced after taking the switch apart.
The bulb, assembled w. socket, is available as a spare part but you'd likely need to have it ordered, and wait. The part numbers can be found in numerous threads about gen 2. Legacy climate controls backlighting, on Nasioc and elswhere.
avk is offline   Reply With Quote
Old 02-27-2006, 03:49 PM   #11
dcwrx2
Member#: 69005
'04 4EAT Wgn
They must have changed beginning 2004....arrrggghhh....
The brown connector at the back of the cruise control switch doesn't even have that terminal wired up.... they didn't prepare the switch to show status... all they did is to ask us "Read the @#$% gauge bezel for any illuminated 'CRUISE' word, in order to tell if the system is on or off" ...>_<...
Old 02-27-2006, 03:56 PM   #12
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
my car's manual, maybe that's why they're different.
Old 02-27-2006, 03:57 PM   #13
avk
Member#: 17252
'06 WX8
59E
Just wire the status bulb in parallel with the one in the cluster, although the one in the cluster could be an LED making it a bit more complicated.
Old 02-27-2006, 10:23 PM   #14
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
added to the FAQ thread as per requested.
Jay
Old 10-13-2006, 08:51 PM   #15
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Excelent write up thanks... bulbs fixed and working great again =)
Kcwiro is offline   Reply With Quote
Old 10-13-2006, 10:21 PM   #16
avk
Member#: 17252
'06 WX8
59E
A replacement bulb, with socket and cover, has its part number and can be ordered. But it's still hardly worth it as people have been using RadioShack bulbs for years now with great results.
Add: duh, I posted in this thread before, didn't realize it was old.
Old 11-02-2006, 04:22 PM   #17
ktmrider
Member#: 125687
2006 Outback XT
ABP
Search function + awesome threads = DIY to perfection!
Thanks for the excellent write up dcwrx2.
ktmrider is offline   Reply With Quote
Old 01-02-2007, 11:23 PM   #18
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
For 5 years I've thought the "CRUISE" letters just didn't light up, wow. Well I fixed it! thanks!
djerickd is offline   Reply With Quote
Old 01-03-2007, 12:34 AM   #19
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
ah, thanks for bumpin this erick! i was looking for it.
KAX is offline   Reply With Quote
Old 01-03-2007, 12:55 AM   #20
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I stumbled upon this looking for more 12 switched sources
Old 01-03-2007, 10:59 AM   #21
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
Great write-up
I've been waiting to replace my foglamp switch bulb.
Thanks
Force is offline   Reply With Quote
Old 01-03-2007, 11:25 AM   #22
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
haha didn't notice the date. bump for a great thread.
Old 01-03-2007, 04:00 PM   #23
Lambu
Member#: 125883
a flying guitar
could those bulbs be used to replace the seat heater status bulb? mine's been burnt out for a while now and i can't tell if its on until my butt starts to burn
tia
Lambu is offline   Reply With Quote
Old 04-01-2007, 11:25 PM   #24
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Bump again...
Noticed my fog switch lights were burnt out and being able to pick something up from Radio Shack was a great tip.
Now I've noticed the cruise is burnt out as well. Back to Radio Shack.
Thanks!
wobbletop is offline   Reply With Quote
Old 06-19-2007, 04:17 PM   #25
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
OMGHi2U
Bumper-eenos! I'm getting my burnt-out indicator lights for Fog lights, Cruise, Defrost & Hazard replaced for my B-day...woo-hoo. Thanks very much for the instructions & pic.
Susie
Susie's Suby is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Cruise control light keep flashing whats up with that jetblue2004 Service & Maintenance 13 11-22-2010 08:49 AM
CEL with Blinking Cruise Control Light. NEED HELP! PremierWRX Factory 2.5L Turbo Powertrain 19 06-10-2009 11:20 PM
CEL with cruise control lights goign on and off bnr34rb26dett Newbies & FAQs 10 02-12-2009 07:58 PM
Can anyone help with my cruise control light blinking NlsBold Newbies & FAQs 1 12-12-2004 02:45 PM
Message Board Statistics All times are GMT -4. The time now is 03:22 AM.
