Old 01-08-2011, 01:22 PM   #51
rubix777
Member#: 221675
2004 Subaru WRX
Smile
Great writeup! I did the bulb replacement just now and the fog light button and cruise control buttons now illuminate. Thanks a lot.
rubix777 is offline   Reply With Quote
Old 01-15-2011, 10:27 PM   #52
Sideout
Member#: 55141
2002 WRX WRB
12.35 @ 109
Just stumbled across this thread and all I have to say is thank you! Not only has it been 2 years since my fog and cruse switches lit up but I also found a bulb that will work in my old skool Greddy gauges!
Sideout is offline   Reply With Quote
Old 05-06-2011, 04:00 PM   #53
Turbedsti
Member#: 213753
2004 WRX STI
Platinum silver metallic
My intercooler sprayer button burned out went to the dealer he told me they only sell the entire switch.Went to radio shack and they didnt have anything will try another store.
Turbedsti is offline   Reply With Quote
Old 06-09-2011, 07:44 PM   #54
zakb33
Member#: 254713
'10 G37S
'11 WRX 311/318 -SOLD
great info, saved me $60 for fog/cruise switches and now the switches work again
zakb33 is offline   Reply With Quote
Old 08-11-2011, 07:02 PM   #55
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
IDIM : past tense of DIY
Thanks much, just did this to my fog light switch. Worked great!
Note to others, I found the bulbs in the drawers in the back of the store filed under Flashlight bulbs.
bugeyetex is offline   Reply With Quote
Old 08-23-2011, 08:13 PM   #56
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
+1 My cruise button stopped lighting up yesterday so went out and did this. Also my fog light button never was lite since I've owned the car, went and replaced that one also with the same steps. It was really simple and easy to do! Thanks for the write up!
Amazing Asian is offline   Reply With Quote
Old 10-08-2011, 10:49 PM   #57
mountainkiddo
Member#: 297119
Thumbs up great post
I followed these instructions on my 99 Legacy station wagon. It worked like a charm. Only difference is that I had both lamps and so I replaced both. I also used a little dab of silicon on the end of the lamp, being careful to keep the wires separated, to help extend the Radio Shack lamp a little ways out of the mount, providing more light for the switch. Worked perfectly!
Thanks so much for posting this in such great detail!
mountainkiddo is offline   Reply With Quote
Old 10-08-2012, 05:06 PM   #58
vms150
Member#: 172917
2004 WRX
Awesome, I have been in need of this work quite a while.
vms150 is offline   Reply With Quote
Old 10-08-2012, 05:38 PM   #59
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Sweet. Now if was that easy to switch to red.
Old 04-23-2014, 02:51 PM   #60
Hans84
Member#: 336971
2004 WRX Wagon
Old thread bump. Thanks for the write up! I've been wondering for 1.5 years if the switch was supposed to light up or not!
Hans84 is offline   Reply With Quote
Old 04-25-2014, 04:27 PM   #61
KnickSubie
Member#: 388998
2015 WRX sti pack
Saved my bros life with this thread... thanks!!!!
KnickSubie is offline   Reply With Quote
Old 11-16-2014, 03:45 PM   #62
Bartimaeus
Member#: 406462
Default Fixing button backlights with LEDs
Excellent thread, didn't realize there were lights on those buttons in my car. Went to replace them on my '01 Outback and didn't want to go to Radioshack, and it turns out that the hole for those bulbs is a *perfect* size for an LED. I had some cheap RGB LEDs from China lying around, so I soldered them in with a 1K ohm resistor in series (trimming off the extra legs so only one color was used). The upper tabs on the buttons for the bulbs are positive, lower is negative.
I used green for the letters and red for the indicator light. Here's a comparison between the old backlight (left) and the new (right) (sorry, didn't have a working bulb to show the old indicator light)
I didn't do any experimenting to see if there is a filter to remove if you wanted to change the light color (takes a while to heat up the metal tabs for soldering to), but if there isn't it's just a simple matter of choosing the color you want.
Bartimaeus is offline   Reply With Quote
Old 11-17-2014, 08:58 AM   #63
86Dreams
Member#: 385256
What is this? An
injector laying contest?
Nice job, I have a bulb that is out and have been wondering how to fix it, so I should be able to soon...
On a side note this is realy funny, you can get xmas cards of it...
86Dreams is offline   Reply With Quote
Old 12-03-2014, 09:09 PM   #64
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
I have had to replace a few bulb lights on my car and the wifes outback.... they are a piece of cake... radio shack near me though has closed its doors so I either order it online or goto the small local electronics stores which tend to have a good selection and not to mention people behind the counter that really know their electronics...I did not think about a LED but hey if you got them and they work go for it!
Kcwiro is offline   Reply With Quote
Old 01-20-2015, 07:34 PM   #65
lotus777
Member#: 411427
Default Works 100%!! Thanks!!
Worked 100%!! So Easy!! I saw this Excellent Post with the Photos and stopped by Radio Shack on my way home from work. Sure enough, they had the Lights in stock. $2.00 for a pack of 2 Mini LED Lights!!
I get home, pop off the coin box revealing the fuse area, I reach up inside and after 10 seconds I push on the Cruise Control switch and it pops right out!!
Sure enough, just like the photos, there are two bulbs, one of mine on my 2002 Subaru Forester L has been burned out for about a year and I can't tell if the Cruise Control is ON or OFF.
Well, I replaced the bulb with a new one as shown in this post!! Took me about 10 minutes, Very Easy to do!!
Pop the switch back in, IT WORKS!!!
THANK YOU!!!! Excellent Info!!
lotus777 is offline   Reply With Quote
Old 05-15-2015, 06:13 PM   #66
ragnaroc
Member#: 388165
I just tried to do this with some bulbs from superbrightleds.com and nothing happened. The switches still worked but nothing lights up on either switch. Did I miss a step or should I just have gotten the old style bulb?
ragnaroc is offline   Reply With Quote
Old 05-15-2015, 06:49 PM   #67
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
You didn't get the bulbs lined up with the power. Also some bulbs are directional in how they need power.
Old 05-15-2015, 08:09 PM   #68
ragnaroc
Member#: 388165
even the ones that came preinstalled in holders? I tried using oem bulb holders and nothing happened. they are the neo3 bulbs
Old 05-15-2015, 08:26 PM   #69
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
This is common. Use a volt meter you will see it still has power. It's just a pain to put these in and get them to work right.
Old 05-15-2015, 08:37 PM   #70
ragnaroc
Member#: 388165
so basically just pull the leds from the sockets and figure out which is the positive and negative side, fun fun lol glad i got the 3rd brake lights right on the first time
Old 05-15-2015, 08:38 PM   #71
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Pull out the bulb. Just be careful not to cross anything.
Old 05-15-2015, 08:51 PM   #72
ragnaroc
Member#: 388165
i'll try it tomorrow or sunday. thanks for the advice
Old 05-17-2015, 03:22 PM   #73
ragnaroc
Member#: 388165
Well I switched the bulbs around but they still wont turn on. any suggestions?
Old 05-17-2015, 04:43 PM   #74
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Flip the bulb 180 degrees in the holder.
Old 05-17-2015, 05:56 PM   #75
vms150
Member#: 172917
2004 WRX
They aren't LEDs, they are mini bulbs. If you are attempting to use LEDs this is why it's not working. Use the radioshack ones that are mentioned earlier in the thread.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Cruise control light keep flashing whats up with that jetblue2004 Service & Maintenance 13 11-22-2010 08:49 AM
CEL with Blinking Cruise Control Light. NEED HELP! PremierWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 06-10-2009 11:20 PM
CEL with cruise control lights goign on and off bnr34rb26dett Newbies & FAQs 10 02-12-2009 07:58 PM
Can anyone help with my cruise control light blinking NlsBold Newbies & FAQs 1 12-12-2004 02:45 PM
