Old 02-26-2006, 09:10 PM   #1
03MBP
Member#: 32460
2005 Forester XT
Default 03 WRX 5 speed into an 05 WRX?
Both WRX's are 5 speed...my buddy is looking to buy my complete 5 speed, put a gearset in and then put it in his 5 speed 05 WRX. I know there are axle differences in mid 04, but since he has all the axle pieces from his stock trans could he just re-use them on mine?
03MBP is offline   Reply With Quote
Old 02-26-2006, 10:39 PM   #2
WRXOFIVE
Member#: 105201
05 WRX
If he is looking to pull his apart and put the 05 frount diff in the 03. But yes it will work.
WRXOFIVE is offline   Reply With Quote
Old 02-27-2006, 01:31 AM   #3
downshift1
Member#: 15607
I'm not the type
to make angry
no he cannot, the case is actually changed in 05'. All he'll need is a set of 02-03' front axles.
-Dylan
downshift1 is offline   Reply With Quote
Old 02-27-2006, 12:42 PM   #4
03MBP
Member#: 32460
2005 Forester XT
He needs the whole axle or just the male/female parts where it connets to the trans?
Old 02-27-2006, 10:44 PM   #5
WRXOFIVE
Member#: 105201
05 WRX
-Dylan
I never relised this i just put an early 04 gearset in my 05 and the pinion lined up correctly, every thing elese appeared the same. Except for the stubs.
Old 02-27-2006, 11:49 PM   #6
downshift1
Member#: 15607
I'm not the type
to make angry
03MBP- you'll need the front axle assembly as Subaru doesn't offer the joint seperatly.
WRXOFIVE- He's trying to swap a non-stub front diff into a subbed case.
-Dylan
02-03 wrx 5 speed vs 04-06 wrx wagon 5 speed nicerb Transmission (AT/MT) & Driveline 2 07-24-2009 03:25 PM
Nuts and Bolts of a 07 STi 6 Speed into an 04 WRX knakai1 Transmission (AT/MT) & Driveline 11 05-13-2008 10:04 PM
WRX 5 Speed into RS??? shanemono4 Transmission (AT/MT) & Driveline 19 04-22-2008 06:08 PM
03 WRX 5 speed into a 96 Legacy 4EAT cm1wrx Transmission (AT/MT) & Driveline 4 12-14-2007 11:17 AM
will a stock 03 wrx downpipe fit into a 05 wrx? eshtog General Community 3 07-14-2004 11:49 PM
