Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 02-26-2006, 11:46 PM   #1
subaru932001
Member#: 108442
1993 Impreza 2.5 8-)
Medium Red
Impreza GC8 head gaskets for a 2.5/2.2 hybrid??
Heya,
I'm building a 2.5L from a 99 forester with 2.2 heads to mount my 1.8 intake on to install in a 93 GC8. Anyone know where to get the thick head gaskets for this conversion?????
Thanks
subaru932001 is offline   Reply With Quote
Old 02-27-2006, 12:22 AM   #2
AWDimprezaL
Member#: 94061
1996 impreza
red mica
i dont know about thickest, get STI head gaskets, they are triple layered you will definatly avoid headgasket failure that n/a 2.5s are notorious for
AWDimprezaL is offline   Reply With Quote
Old 02-27-2006, 01:18 AM   #3
subaru932001
Member#: 108442
Medium Red
Default compression reduction
i'm not tryin to counter failure im trying to keep from getting valve slap and reduce compression to about 10.5:1 right now it should be about 11.5:1 best i can figure. But if the STI gaskets are 3 times thicker that might do it, not sure though.
Old 02-27-2006, 12:47 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Just get the STi gaskets. They are not thicker, but I built the EXACT set up that you are looking at. phase 1.5 block, EJ22 heads and STI metal HG's. You will be fine...
Old 02-27-2006, 03:38 PM   #5
subaru932001
Member#: 108442
Medium Red
Default thanks
Woot Thanks
Old 02-28-2006, 09:36 AM   #6
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
i'm curious why would you want to lower the the CR?
Rally_wgn is offline   Reply With Quote
Head Gasket Leak Problem on all NA 2.5? H5N1 Normally Aspirated Powertrain 621 03-23-2014 10:11 AM
Head Gaskets for 2.5L WRX Hybrid toecutter Built Motor Discussion 14 04-20-2008 03:31 PM
what head gasket did you use on your EJ22t hybrid? 2.5rsDOHC Built Motor Discussion 18 09-13-2007 10:16 AM
Hybrid 2.5 SB, 2.0 Heads 9vapors Built Motor Discussion 20 04-07-2007 12:04 AM
WRX Head/2.5 STi bottom Hybrid 12.92 @ 106.19 Ronin Quickblade Proven Power Bragging 8 05-25-2006 09:02 PM
