Old 05-08-2001, 02:43 PM   #1
IMPRZME
Member#: 5335
2004 STi
Java Black
Post anyone ever have this problem starting your RS?
Ok, so i go out to leave my house, push in my clutch, put in the key, and turn it. Nothing. Kinda like the battery is dead, but it's not. All my accessories work fine, etc, but no engine start. It doesnt even click or anything. So, I disconnected my battery for like 30 seconds, reconnected, an bam it worked. So now like 4 days later, same thing...disconnected for like 30 seconds, nothing. Now I'm just resetting the ECU and hopeing thats the problem?? Hmm...otherwise I dont know what the hell it could be!! I'm figuring if it works when i re-connect the battery and it happens again, I'll just have to take it down to the dealer and have them try to find out what it is...
anyone have any idea what it could be???? thanks for any help!!!!!!!!!
~Lenny
IMPRZME is offline   Reply With Quote
Old 05-08-2001, 02:47 PM   #2
inzomniac
Member#: 1710
1998 2.5RS/2002 WRX
RS: RBP/ WRX: PSM
Post
My 95 does the same thing... I just take of the handbrake, jiggle the wheel, move the gear selector... one of those things will get it going... as for what it is, I don't have a clue, it's never done it for the mechanics so they can't help me.
inzomniac is offline   Reply With Quote
Old 05-08-2001, 02:51 PM   #3
Silver2000RS
Member#: 857
Post
Do you have a security system installed? Maybe you have a problem with the starter-kill relay.
Silver2000RS is offline   Reply With Quote
Old 05-08-2001, 02:57 PM   #4
IMPRZME
Member#: 5335
2004 STi
Java Black
Post
yeah i have a security system. I tried locking then unlocking the car again, but still didn't work. Hmm...well I'm going to go re-connect my battery and see if it starts... wish me luck...I'd still like to know what this is though!!! grrrr
Old 05-08-2001, 03:11 PM   #5
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
I had this problem. Then my dumba$$ figured out it was the combination of aftermarket pedals (the retaining scres were too long on the back) and my floor mats were riding too high. basically it was not allowing the clutch to go all the way to the floor. I moved the mat and cut the screw. prob solved.
ChosenWon is offline   Reply With Quote
Old 05-08-2001, 05:36 PM   #6
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Maybe a floormat is in the way, so you can't step on the clutch all the way. Make sure there are no obstacles. I had this situation once or twice when I couldn't start the engine because of a floor mat.
If not, maybe the switch on the clutch is defective so it has good days and bad days.
tmat3 is offline   Reply With Quote
Old 05-08-2001, 05:40 PM   #7
Loki
Member#: 4543
2003 WRX
Post
Well, my impreza will not start if the clutch is not in. If I try to start the ignition while it's in neutral or something, it refuses to turn over. My guess is that something to do with the device that detects that the clutch is all the way in and allows the ignition to engage.
<IMG SRC="http://www.theloki.org/sig.gif" border=0>
EDIT: Doh! Didn't see you had the problem solved ... my bad
[This message has been edited by Loki (edited May 08, 2001).]
Loki is offline   Reply With Quote
Old 05-09-2001, 01:02 AM   #8
IMPRZME
Member#: 5335
2004 STi
Java Black
Post
well, not completely solved, just narrowing down the reasons! :-) after i reset ecu, still didn't work. So i tried playing with the alarm, i think that MIGHT be a problem cause: lock, unlock, turn key...nothing...lock, unlock turn key nothing...lock, unlock, turn key...VRROOM...so i turn it off again, lock, unlock, no start. REPEAT, VRROMMM...and ever since it's been starting fine... soo hmm...i think it may be a clutch sensor like some of u guys say...cause i did push the clutch in a lot during the process ya know? so as long as i can get around without having too many problems until i can get it in the dealer...
Anyone ever have this problem with coilovers? (car pulls to the left) Pete Holt Brakes, Steering & Suspension 2 10-13-2006 11:44 AM
Anyone ever have this problem with EZ-Pass? plunk10 Mid Atlantic Impreza Club -- MAIC 24 04-20-2006 12:24 AM
ANyone ever have this happen to them on the road or track... Nivek-CA Brakes, Steering & Suspension 2 05-04-2004 07:19 AM
Hesitaion of Acceleration - TSB anyone ever have this SubeDonC Normally Aspirated Powertrain 19 09-19-2003 09:43 AM
Wastegate Actuator Arm Popping out. Anyone ever had this problem? BlueDemon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-20-2003 02:56 PM
