Old 02-27-2006, 12:58 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default MY05 Legacy GT Turbo tranny swap solution!
I posted on here about swapping in the legacy tranny and that subaru made the tranny female for the front axles and not male as traditionally seen in all other subaru. The legacy axles were to long to use and didn't fit at the hub anyways. So with the great help of Scott over at Exeter Subaru in NH, also known as www.subaruwrxparts.com, we came up with a solution. I had to tear apart my L tranny and remove the Tranny axle stub from the internal Front diff that make the tranny male. I then had to get them machined at the end to recieve a C-clip like the legacy axles so I wouldnt have to crack the Legacy tranny open. The legacy axle is thicker where it enters the tranny so I also had to replace the seals there with new seals ment for the impreza L tranny. Below are pictures. I don't know if anyone else will be doing this anytime soon but I would like to have a documented solution. Can a moderator put this in one of the fact files either here or tranny.
Thanks,
Joshua
Top: L axle female at tranny
Middle: L axle converted to Male
Bottom: Legacy GT turbo axle Male
Right: new gaskets, C-clip and part numbers also axle stub removed from tranny and machined to recieve C-clip
yebokmj is offline   Reply With Quote
Old 02-27-2006, 01:38 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
good work
how about a total cost estimate?
any more thoughts about the absence of the speed sensor
Old 03-01-2006, 01:18 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Nice work!
Legacy777 is offline   Reply With Quote
Old 03-01-2006, 01:22 PM   #4
yebokmj
Member#: 2213
Brilliant Red
Thanks Legacy777
I could have swore I responded to you Jaxx,
75 for machining and 27 for parts.
I'm going to be going the r,oute I discussed in that other thread for the speed sensor.
Joshua
Old 03-02-2006, 01:19 PM   #5
Legacy777
Member#: 4800
Got a link to your other thread about the speed sensor?
Old 03-03-2006, 06:55 AM   #6
yebokmj
Member#: 2213
Brilliant Red
http://forums.nasioc.com/forums/show...ghlight=legacy
Has what you looking for scroll to the bottom.
I'm approaching the end of the big stuff on this project. I have most of the wiring done and most of the mechanical. Today I will be finishing up straightening out the engine bay, and tightening exhuast bolts along with installing front sway bar and pouring in the tranny fluid which finally arrived yesterday after three weeks. After that it looks like about ten wires tops and I can put the dash in and see what happens. So most likely I'll try starting it tomorrow.
Joshua
Old 03-07-2006, 02:00 PM   #7
Legacy777
Member#: 4800
cool.
Good info to have.
Old 05-22-2006, 11:26 AM   #8
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
I'm looking to do the same thing, so far, what have your costs been for this part of the swap?
Kaymin is offline   Reply With Quote
Old 05-22-2006, 07:09 PM   #9
yebokmj
Member#: 2213
Brilliant Red
I will have to find the thread but you can purchase the parts from Subaru directly so you don't have to get anything machined. I am going to be going this route because the shop I went to didn't put the C clip groove just right so I get some noise.
Old 05-22-2006, 07:11 PM   #10
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
If you can get it directly from Subaru i bet Jamie or someone else that does OEM subaru stuff could help us out!!
It is Jamie who does it right? lol i dont know
Old 05-22-2006, 07:13 PM   #11
yebokmj
Member#: 2213
Brilliant Red
6-speed axle seal: 806730042
6-speed axle stub: 38415AA070 (Same as AT)
Circlip: 805329010
Obviously you need 2 of each...
Old 05-22-2006, 07:13 PM   #12
yebokmj
Member#: 2213
Brilliant Red
This was cut from another thread, the seal is directional though so you need a differant part number for one side.
Old 05-22-2006, 07:20 PM   #13
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
ok i'll try to figure out the other seal its probably just 1 digit off
anyways, this place has all the parts for cheap and you just enter the part number, dont know if they are reliable or not though.
www.subaru-parts-dealer.com
yup, the part number is 806730041
Old 05-23-2006, 12:53 PM   #14
Legacy777
Member#: 4800
Jamie's cheaper
www.subarugenuineparts.com
Old 05-23-2006, 12:55 PM   #15
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
Originally Posted by Legacy777
plus i can pick up from Jamie = no shipping
Can a MY05 Legacy GT tranny be fitted for mechanical Vehicle Speed Sensor? yebokmj Transmission (AT/MT) & Driveline 2 02-10-2006 10:41 PM
Can an MY05 Legacy GT crossmember be used? yebokmj Subaru Conversions 11 01-21-2006 08:28 AM
MY05 Legacy GT (56K???) buplew Member's Car Gallery 15 10-28-2005 10:33 AM
MY05 Legacy GT and Ltd. Pricing in Pittsburgh subawang Mid Atlantic Impreza Club -- MAIC 7 04-25-2005 11:24 AM
iON Sport Spec Springs (for MY05 Legacy GT Sedan available shortly... iON Performance Inc Legacy Forum 3 10-28-2004 02:39 AM
