Old 02-27-2006, 02:02 PM   #1
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
Default is it possible to remove the smell of smoke from furniture? if so, how?
came across an little ikea sofa for the basement for real cheap, thing is it smells like smoke, didn't notice it when i picked it up but now that it is in my house it's stinking up the basement. i think it's a job that febreeze alone can not handle. suggestions?
-El A
doubledribble is offline   Reply With Quote
Old 02-27-2006, 02:03 PM   #2
emorphien
Member#: 83039
2005 LegacyGT Ltd 5m
ಠ_ಠ
replace with farts
I could recommend a few people.
emorphien is offline   Reply With Quote
Old 02-27-2006, 02:04 PM   #3
semabe
Member#: 46282
2015 Rubicon
Panda
I've never been lucky with that. I had 6 guys in my truck smoking cigars for like 30 minutes and it took 3 years to get rid of the smell.
semabe is offline   Reply With Quote
Old 02-27-2006, 02:05 PM   #4
DrDRum
Member#: 41589
Suff erer Club
Founder (RGSSC)
Smoke as in "was in a burning house" smoke damage. If so, how badly smoke damaged.
If cigarette smoke, it can be done w/ industrial deodorizing cleaner (no fabreeze), and airing it out. It could take over a year of multiple applications to get it all.
Rarely worth it, esp if you nose is sensitive.
DRum
DrDRum is offline   Reply With Quote
Old 02-27-2006, 02:05 PM   #5
bluesunlion
Member#: 11377
2016 WRX Sti
If it's not snowing/raining/etc right now in delaware (which I doubt!)
Febreeze with the least crappy smelling febreeze and leave outside in the sunshine.
If not, find a friend with a floor/furniture steamer and steam liberally.
bluesunlion is offline   Reply With Quote
Old 02-27-2006, 02:06 PM   #6
vapore0n
Member#: 21356
2010 BMW 335i
2017 STI Limited LBP
garden hose it?
Thats how I used to get rid of the smell in my jackets when I went to a pub.
vapore0n is offline   Reply With Quote
Old 02-27-2006, 02:09 PM   #7
doubledribble
Member#: 42912
2003 Outback Sport
it's cigarette smoke. i might just have to toss it. it smells like a smoking/hotel room. i left it outside yesterday (windy as hell) i'll take the little green machine to it tonight. otherwise i guess it's a lost cause.
Old 02-27-2006, 02:10 PM   #8
HolyCrikey
Member#: 66776
2005 Mazda3 Hatch
Titanium Grey Metallic
HolyCrikey is offline   Reply With Quote
Old 02-27-2006, 02:11 PM   #9
CrazyButHappy
Member#: 58545
2003 WRX
Baking soda will absorb odors, just make sure the furniture is absolutely dry before sprinkling over the cloth parts. Apply liberally, let sit for an hour so. Vacuum up baking soda. Repeat 3-5 times.
I was able to get the cat piss smell out of the carpet in my convertible using this method.
CrazyButHappy is offline   Reply With Quote
Old 02-27-2006, 02:12 PM   #10
hotsam
Member#: 3862
Have your cat piss on it.
hotsam is offline   Reply With Quote
Old 02-27-2006, 02:13 PM   #11
DrDRum
Member#: 41589
Suff erer Club
Founder (RGSSC)
If its cloth, use the cleaner a few times as I'd mentioned, then use post #9. Baking powder, not soda btw. You can put it on the cushions, and under the cushions.
DRum
Old 02-27-2006, 02:14 PM   #12
Thunder Lungs
Member#: 33677
2003 WRX Sedan
Sonic Yellow COBB Stage 2
Set an ozone machine on the couch and throw a large sheet over the couch like a tent. Let it run for a few hours.
Thunder Lungs is offline   Reply With Quote
Old 02-27-2006, 02:15 PM   #13
del105
Member#: 43010
1974 2002tii
take up smoking it's cool.
del105 is offline   Reply With Quote
Old 02-27-2006, 02:31 PM   #14
Janq
Member#: 33246
+1
This is an old school fix that has worked for me in getting smells such as human and dog barf (very distinct smells) as well as spilled beer smells out of my cars.
Buy a big ass box of Arm & Hammer and spread the stuff liberally covering all material in a single layer of powder. Let it sit 24 hrs. for maximum effect and then come back with a strong vaccuum to remove the powder and residue. If vaccuming with anything other than a Dyson it's advisable that you empty the vac before hand and/or use a fresh bag reason being you don't want maximal sucking power _and_ don't want to inadvertantly blow dirt, dust and attendant smells from the bag back into the material making the problem worst or swapping smells for smell.
Definitely multiple dosings will be required. It required two when I was cleanign up beer smell and it had only been sitting for a day or so from time of spill to treatment.
- Janq
Janq is offline   Reply With Quote
Old 02-27-2006, 04:08 PM   #15
doubledribble
Member#: 42912
2003 Outback Sport
thanks for the info, i'll try the industrial deodorizer followed by the baking powder ASAP.
Old 02-27-2006, 04:11 PM   #16
tbert
Member#: 43357
2004 Smug 46MPG
2006 Clown Car
edit: Don't listen to that crazy Janq!
tbert is offline   Reply With Quote
Old 02-27-2006, 04:14 PM   #17
Slyte
Member#: 82212
down with oontzin
sonicyella-bugeye
Look for a special spray called 'Ozium'. Works like a charm, no matter what the stank. Poop, marijuana, stoges, etc.
Slyte is offline   Reply With Quote
Old 02-27-2006, 04:38 PM   #18
TortoiseAWD
Member#: 5223
2002 Impreza WRX
Silver Metallic
Ozone generator FTW. Check local janitorial supply stores in your area to see if you can rent one . . . rental in this area (Omaha) is around $25/day.
Tort
TortoiseAWD is offline   Reply With Quote
Is it possible to remove TOB from PP without taking off the PP from flywheel? biggreen96 Transmission (AT/MT) & Driveline 4 09-07-2008 10:56 PM
Is it possible to remove the front swaybar w/ the tire still on? MF-DIF Brakes, Steering & Suspension 8 03-31-2005 09:26 AM
Is it possible to change the date of an e-mail? GooseMan Off-Topic 5 02-17-2004 11:30 AM
Is it possible to get the benefits of a lighter crank pulley without the negatives? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 07-02-2003 01:44 AM
Is it possible to remove the turn signal cone form the headlights? Davenow Interior & Exterior Modification 4 09-05-2002 01:18 PM
