Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-27-2006, 06:04 PM   #1
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
Default Analyze my UTEC logs
I have several maps that were tuned by TurboXS for my friends MY2004 STi(listed below). I bought all his parts and put them on mine when he sold his car. These maps were tuned in Augest. I know I need to adjust the TPS sensor so it shows 100%.
1. Map Comments:-[16psi peak 11:1 afr]
2. Map Comments:-[-1 degree ]
3. Map Comments:-[-1 deg +.4 fuel Low boost]
4. Map Comments:-[really low boost]
5. Map Comments:-[low boost -2 deg]
The below pulls are using Map #2. I am worried about the Knock Counts I got around ~5600. I am going to have to try Map #3 and see how the boost is. Also I don't have the ABC valve installed, I have a Apexi AVCR to install next weekend instead. Boost hits 18.2 at points, and this is on the 16psi map. Is this most likly the cold air? Any pointers or Tips on how I can stop the knock? Does everything else look good?
Mod List:
TurboXS UTEC
TurboXS RFL TBE w/Hi-Flow Cat
TurboXS Shorty Intake
TurboXS Tuner Wideband
Thanks,
Travis
Outside Tempature: 40F
3rd Gear:
Code:
                   Load Knock                Mod   Mod         Mod   WB
 RPM   MAP  MAF TPS Site Count  Ign#1  Inj#1  Ign   Fuel Boost  MAF   AFR
       psia  V   %               deg   duty   deg    %   (CL)    V
 2916  -8.7 2.6  23  00    00   +39.8   14.6 ECU.   +0.0 ECU.   2.6  14.58
 2705  -6.7 2.6  23  00    00   +37.8   14.5 ECU.   +0.0 ECU.   2.7  14.74
 2770  -4.0 2.9  29  10    00   +30.4   21.6 +28.0  +1.6 ECU.   3.0  14.42
 2871  -1.6 3.0  26  10    00   +26.3   23.0 +27.5  +1.1 ECU.   2.9  13.81
 2939  -0.8 2.6  16  00    00   +37.8   14.4 ECU.   +0.0 ECU.   2.6  13.23
 3129  +0.2 3.1  40  10    00   +28.9   30.3 +27.0  -0.3 ECU.   3.2  13.59
 3217  +2.1 3.4  44  20    00    +8.5   34.6 +26.0  -0.7 360.00 3.4  14.45
 3443  +4.1 3.7  50  50    00   +14.6   48.9 +15.8  +1.2 375.00 3.8  14.00
 3542  +8.0 3.9  45  70    00   +11.9   56.3 +15.0  +2.2 362.50 3.9  12.96
 3940 +13.9 3.9  44  80    00   +14.8   59.4 +15.6  +1.4 360.00 4.0  11.73
 4105 +15.1 4.0  57  80    00   +16.1   66.2 +16.0  +1.1 392.50 4.1  11.58
 4317 +15.5 4.1  69  80    00   +15.9   71.8 +16.4  +1.3 422.50 4.2  11.67
 4480 +15.5 4.2  68  90    00   +15.8   81.9 +17.1  +1.8 420.00 4.3  11.62
 4761 +16.1 4.3  68  90    00   +16.7   85.8 +18.1  +0.2 420.00 4.2  11.27
 5035 +17.2 4.3  73  90    00   +17.9   84.2 +18.4  -0.7 432.50 4.2  11.12
 5175 +16.6 4.3  95  90    00   +17.7   88.8 +19.2  -0.7 450.00 4.3  11.45
 5350 +16.4 4.4  96  80    00   +17.2   94.8 +20.7  -0.3 450.00 4.4  11.73
 5621 +16.1 4.4  95  80    08   +15.3   93.4 +17.8  -0.3 450.00 4.4  11.61
 5920 +15.7 4.4  95  90    00   +18.0   92.7 +17.7  -0.6 450.00 4.4  11.58
 6071 +16.1 4.4  95  90    00   +19.0   94.1 +22.3  -0.5 450.00 4.4  11.58
 6150 +15.7 4.4  95  80    00   +20.4   95.6 +23.1  -0.6 450.00 4.4  11.61
 6385 +14.9 4.4  95  70    00   +22.5   93.0 +23.7  -1.3 450.00 4.3  11.65
 6574 +14.9 4.4  23  00    00   +23.9   72.8 ECU.   +0.4 ECU.   3.7  11.73
 6161  +8.8 2.0   0  00    00   +23.1    7.3 ECU.   +0.5 ECU.   1.7  12.11
 5920  +2.3 1.9   0  00    00   +23.3    7.7 ECU.   +0.3 ECU.   1.9  12.11
 5518  -4.7 1.9   0  00    00   +23.9    7.8 ECU.   +0.0 ECU.   1.9  12.17
2nd to 3rd:
Code:
2nd Gear:
 2498  -1.6 2.8  26  10    00   +24.1   19.3 +28.0  +4.8 ECU.   2.9  13.45
 2686  -0.2 3.0  40  10    00   +22.1   22.9 +28.0  +2.5 350.00 3.1  13.39
 2906  +1.7 3.1  65  20    00   +19.6   30.5 +26.3  +0.9 412.50 3.3  13.47
 3226  +3.7 3.4  94  40    00   +16.3   40.2 +18.0  +0.6 450.00 3.5  13.42
 3568  +6.4 3.8  95  50    00   +11.7   58.2 +16.0  +1.0 450.00 4.0  13.06
 3968 +10.4 4.0  95  80    00   +13.0   69.8 +15.8  +1.3 450.00 4.2  12.46
 4312 +14.1 4.1  95 100    00   +14.6   75.0 +16.2  +1.4 450.00 4.2  11.77
 4668 +16.8 4.2  95 100    00   +15.7   83.3 +17.8  +0.7 450.00 4.3  11.58
 5167 +18.2 4.3  95  90    00   +16.3   87.1 +19.0  -1.0 450.00 4.3  11.45
 5482 +17.4 4.4  95  90    00   +16.0   93.2 +20.5  -0.1 450.00 4.4  11.52
 5858 +16.1 4.4  95  80    00   +16.8   94.7 +22.0  -0.5 450.00 4.4  11.58
 6082 +15.3 4.4  95  80    00   +19.5   94.0 +22.4  -0.5 450.00 4.4  11.45
 6253 +14.3 4.4  95  70    00   +22.9   93.0 +23.5  -1.2 450.00 4.4  11.53
 6734 +13.9 4.4  95  70    00   +27.2   94.2 +24.7  -1.0 450.00 4.4  11.71
 7077 +13.5 4.4  87  70    00   +29.3   88.5 +26.0  -1.0 450.00 4.3  11.87
Shift to 3rd:
 6775 +10.6 2.9   0  00    00   +23.0   13.5 ECU.   +0.5 ECU.   1.8  11.68
 6397  +4.5 1.7   0  00    00   +23.0    7.8 ECU.   +0.4 ECU.   1.8  11.81
 5777  -1.8 2.1  29  10    00   +40.4   19.6 +27.0  -1.5 ECU.   3.0  12.09
 5307  -5.3 3.8  64  10    00   +11.5   62.6 +27.0  -2.0 410.00 3.9  12.89
 5649  -3.8 4.3  94  30    00    +7.0   88.1 +24.0  -0.1 450.00 4.3  13.06
 5621  +2.9 4.4  95  70    01   +14.8   92.8 +21.8  -0.6 450.00 4.4  11.98
 5767 +10.0 4.5  95  90    02   +16.4   93.9 +17.5  -0.5 450.00 4.4  11.73
 5899 +14.3 4.4  95  90    00   +17.1   93.8 +18.1  -0.6 450.00 4.4  11.68
 6172 +16.6 4.4  80  90    00   +18.3   95.2 +22.6  -0.6 450.00 4.4  11.67
 5767 +13.3 2.6   0  00    00   +23.2    8.2 ECU.   +0.1 ECU.   1.9  11.45
 5678  +6.4 1.8   0  00    00   +23.3    7.5 ECU.   +0.0 ECU.   1.8  11.89
 5385  -1.2 1.9   0  00    00   +23.2    7.1 ECU.   +0.0 ECU.   1.8  12.17
 5192  -8.9 1.9   0  00    00   +23.2    7.7 ECU.   +0.0 ECU.   1.9  11.81
 4923 -12.8 1.9   0  00    00   +23.4   80.0 ECU.   +0.0 ECU.   1.9  12.14
TravisSTi is offline   Reply With Quote
Old 02-27-2006, 06:54 PM   #2
kts262
Member#: 45464
91 E30 325i
95 E36 325is
I'm still a UTEC n00b so take what I say with a grain of salt, but I was having similiar issues recently.
I had my STi tuned by TurboXS as well and I found that in this cold the car was making more boost and I was knocking (just slightly) with my "all out 18psi" map and my "15psi daily driving map". The knocking was around 3000-3500rpms @ WOT. I turned it down to my #3 map which was had -1 degree of timing from the 15psi map and that stopped most of the knocking. I switched it down to my 4th map which is -1 degree of timing AND +1 fuel and I've been running fine for the week I've done that with no knocking at all. I haven't had time to pull logs but I've heard from several people that knocking with these maps is a common issue for cars that are tuned in warmer weather (My STi was originally tuned in early September.)
I'm surprised your map only goes up to 16psi, they set my #1 map to boost up to 18psi. I have the UTEC + Stealthback w/ high flow cat.
Switching to a map with a bit more timing and/or fuel should help kill the knock.
I'll pass your post on to a friend who has shared a lot of UTEC knowledge with me to see if he has any more input.
ninja edit: My car also does not have the ABC installed. I didn't install it and when I asked Nathan @ TXS he said it wasn't necessary on STis.
kts262 is offline   Reply With Quote
Old 02-27-2006, 07:53 PM   #3
Freon
Member#: 88322
2009 BMW 135i
If you're hitting too much boost just lower your boost table settings. That simple.
Your boost and AFR seem to be pretty middle of the road. Since it seems to be consistent at 5600rpm, I'd just take a degree or two of timing out right along your 5250 and 5500 line. If you look at the stock ECU, there are similar activities where the map isn't predictably smooth. It may seem odd that you'd need to put a "hole" in your timing, but if it works...
Although your fueling isn't really aggressive compared to what some people run, you could try targeting closer to 11.0:1 16psi@ 5600rpm is a lot of air.
Here's a log from when I was running a very similar setup (stock airbox, though)
Here's my timing map (parameters set to 18.5 psi max):
http://freon.shackspace.com/car/ecu%...ing/timing.PNG
I never had the kind of problem you are seeing @ 5600rpm and run almost the same timing there (about +20-21 BTDC).
I've always been running richer. I have leaned out the low and midrange columns, but my top columns still run 10.5-11.2:1 or so. I did have problems with the top mount and had to add some fuel around 5000rpm in the low and mid columns due to knock when shifting on the dragstrip, which I partly blame as heatsoak issues.
I'm running a new solenoid now, but even before I could've hit 20psi if I wanted without an ABC. I hit 18psi midrange no problem with about 380-400 in the boost map.
I'd try adding some fuel back in from 4500-5750 to start. If you end up with 11.0:1 and it still knocks, I'd then pull 2 degrees across the board in 5250 and 5500, 1 degree from 5000 and 5750. I say across the board because it looks like you're getting it in lower loads as well. Another trick may be to remove "ecu" from the 0% column from 5000 or 4750 rpm up so there is no transistion from ECU to UTEC during shifts. You can just copy your 10% column down.
Freon is offline   Reply With Quote
Old 02-27-2006, 11:17 PM   #4
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
Thanks for the input guys! I did a few pulls on my map 3 when I was going out to lunch. This is after I adjusted my TPS sensor. There is no knock on this map! atleast since its this cold....currently flurries are falling.
Anyway the log shows TPS = 100% but it just bearly hits the 100% Load column. It is common to see 100% TPS and running the 80 or 90% load columns this deep into a pull? As you can see it hits the 100 column then dips back to 90 column and eventually the 80 column even though I have 100% TPS.
Should I adjust the TPS to read 102% ? Currently it reads right on 100%
Code:
 1951  -6.9 2.1  11  00    00   +38.9    7.7 ECU.   +0.0 ECU.   2.1  14.05
 1963  -6.7 2.1  11  00    00   +39.1    7.6 ECU.   +0.0 ECU.   2.1  14.00
 2000  -6.7 2.1  11  00    00   +39.8    8.1 ECU.   +0.0 ECU.   2.1  13.95
 2025  -6.7 2.2  14  00    00   +40.1    7.8 ECU.   +0.0 ECU.   2.2  13.84
 2076  -6.1 2.2  14  00    00   +40.4    8.9 ECU.   +0.0 ECU.   2.2  14.08
 2129  -5.7 2.2  15  00    00   +40.7    9.4 ECU.   +0.0 ECU.   2.3  14.37
 2223  -4.9 2.5  25  10    00   +38.2   12.1 +30.0  +4.5 ECU.   2.6  14.42
 2313  -3.4 2.6  28  10    00   +28.5   15.4 +29.6  +4.6 ECU.   2.7  14.15
 2413  -2.4 2.7  28  10    00   +26.6   17.1 +28.8  +4.8 ECU.   2.8  13.95
 2570  -1.0 2.7  28  10    00   +25.7   19.1 +28.0  +4.3 ECU.   2.9  13.81
 2699  +0.0 2.9  45  10    00   +24.2   21.7 +28.0  +2.2 362.50 3.1  13.53
 2911  +1.5 3.1  87  20    00   +22.3   26.9 +26.4  +1.1 415.00 3.1  13.78
 3124  +3.1 3.3  99  30    00   +18.8   34.4 +24.0  +1.3 425.00 3.3  13.84
 3343  +5.1 3.6 100  40    00   +15.5   43.8 +18.5  +1.0 425.00 3.7  13.28
 3631  +8.2 3.8 100  60    00   +11.9   58.6 +15.0  +2.6 425.00 4.0  12.81
 3992 +11.7 4.0 100  90    00   +13.1   68.0 +16.0  +1.6 425.00 4.1  12.14
 4357 +14.7 4.0 100 100    00   +14.6   71.7 +16.3  +1.8 425.00 4.2  11.68
 4655 +16.4 4.1 100  90    00   +15.5   80.9 +17.4  +1.5 425.00 4.2  11.62
 5035 +17.4 4.2 100  90    00   +17.5   85.6 +18.5  -1.3 425.00 4.2  11.33
 5376 +17.0 4.3 100  90    00   +16.0   90.6 +19.9  +0.0 425.00 4.3  11.33
 5659 +16.1 4.3 100  80    00   +16.1   94.4 +21.8  +0.2 425.00 4.4  11.53
 6027 +15.7 4.3 100  80    00   +19.1   92.6 +22.2  -0.3 425.00 4.3  11.52
 6242 +14.5 4.4 100  70    00   +20.8   88.7 +22.8  -0.9 425.00 4.3  11.61
 6548 +13.9 4.4 100  70    00   +23.9   89.2 +23.7  -0.7 425.00 4.3  11.76
 6761 +13.9 4.4 100  80    00   +27.4   93.2 +24.8  +0.0 425.00 4.4  11.87
 6830 +13.7 4.3   0  00    00   +33.5   55.0 ECU.   +0.4 ECU.   3.2  11.87
 6944  +8.2 1.8   0  00    00   +39.5    7.2 ECU.   +0.5 ECU.   1.6  11.71
Thanks,
Travis
Old 02-28-2006, 10:35 AM   #5
alcrudojr #00
Member#: 20652
06 WRX STI
493whp @ 93oct fuel
My humble opinion is your way to lean as already mention try runing more between 10.8 to 11.1 at top end.
alcrudojr #00 is offline   Reply With Quote
Old 02-28-2006, 10:51 AM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Originally Posted by TravisSTi
Code:
Alright, I'm not master UTEC tuner, but I do have good knowledge of how it works.
First off, take a look at the "mod fuel %" column and the "AFR" column. Those two are obviously interconnected. But a certain AFR that you see isn't correlated to the "mod fuel %" that is on the same line. You need to compare it to a "mod fuel %" from a line or two ago. And that's where your problem starts. You have "mod fuel %" numbers that are all positive that all of the sudden go negative and look at what happens to the AFR a couple lines later…it goes to high 11’s. So I would take those -0.7’s and add fuel to them first to get that AFR into the low 11’s. Actually, looking at it again, you have all negative numbers from 5000RPM on up in the 80% and 90% load columns. I would add about .3 in there and see where that puts you. You want that “mod fuel %” column to have a relatively nice shape if you graphed the numbers and the jump from +0.2 to -0.7 is not a nice jump and is probably starting the knock event and then it finally shows knock a couple lines later. This is also evidenced by your ign#1 column. The timing stops advancing as soon as you get into the line that has negative “fuel mod %” values.
I don’t think your timing is that aggressive, but I think your fuelling is and that is what is causing your problems. Try that and see what happens.
Tim
SloRice is offline   Reply With Quote
Old 02-28-2006, 01:26 PM   #7
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Try Freon suggestion ... hopefully your knocks will go away ... if you are running pump fuel .. I think ur A/F bit too lean .. just my 2 cents
WRX-Blue-Mica is offline   Reply With Quote
Old 03-04-2006, 02:13 AM   #8
Davenow
Member#: 23676
Ideally you dont want it to ride in the 100% load column. Set your maps up so that a HARD full pull is only in the 90% load column, then tune the 100% column for less timing, and more fuel, so that in the event of overboost, you dont run into det issues.
And you are lean up top. You can run 11.7 that high on water injection (or alch/water) but on pump thats a little lean IMO
Old 03-05-2006, 08:03 PM   #9
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
From my experience isn't 85+% injector duty cycle a bad thing? I saw his logs were in the mid 90's!!! Maybe a fuel pump and injectors? Then retune.
My .02
Pacobeagle is offline   Reply With Quote
Old 03-05-2006, 08:42 PM   #10
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
My .02
Bad? No not really. It doesn't give much overhead but it isn't a bad thing.
cdvma is offline   Reply With Quote
Old 03-05-2006, 09:41 PM   #11
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Agreed
Old 03-05-2006, 10:56 PM   #12
VWGrk1
Member#: 57882
2004 WRX
Thanks for explaining that, Dave, it has been bothering me for awhile. I keep thinking that load site determines boost, but it is the other way around.
VWGrk1 is offline   Reply With Quote
Old 03-06-2006, 07:11 AM   #13
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
Thanks for the pointers guys! I have adjusted my fuel map so im not so lean but had a few more questions. The below 3rd gear pull was taken at 40F
Code:
 3724  -9.4 1.9  10  00    00   +29.5    6.6 ECU.   +0.0 ECU.   1.9  13.06
 3236 -11.4 2.1  15  00    00   +43.1   14.3 ECU.   +0.0 ECU.   2.3  14.37
 3126 -10.8 2.4  21  00    00   +20.4   11.7 ECU.   +0.0 ECU.   2.5  14.08
 3159  -9.1 2.6  23  00    00   +43.8   14.9 ECU.   +0.0 ECU.   2.6  13.78
 3233  -7.3 2.8  26  10    00   +41.0   17.9 +27.0  -0.5 ECU.   2.8  14.65
 3333  -4.9 2.9  28  10    00   +39.0   21.2 +27.0  -0.6 ECU.   2.9  14.92
 3454  -2.6 3.2  45  10    00   +32.8   30.8 +27.0  -0.5 327.50 3.3  14.83
 3572  +0.2 3.5  53  20    00   +23.0   43.3 +25.0  -0.8 380.00 3.7  14.61
 3762  +3.7 3.9  62  50    00   +13.6   62.9 +16.4  +1.0 390.00 4.0  13.75
 4001  +8.6 4.1  76  80    00   +13.4   73.5 +15.9  +1.5 425.00 4.1  12.68
 4246 +12.9 4.1  81 100    00   +14.1   78.4 +16.3  +1.7 425.00 4.3  11.81
 4409 +16.1 4.3  92 100    00   +15.0   85.5 +16.8  +2.1 420.00 4.3  11.52
 4701 +18.2 4.3  94 100    00   +15.8   87.0 +17.9  +1.3 415.00 4.4  11.34
 4982 +18.6 4.3  97 100    00   +16.0   90.7 +18.0  -0.5 415.00 4.3  11.05
 5167 +18.6 4.4  97 100    00   +15.2   94.5 +18.7  +0.0 410.00 4.4  11.05
 5428 +17.4 4.5  97  90    00   +15.3   99.8 +19.7  +0.1 410.00 4.4  11.27
 5527 +16.6 4.5  97  80    00   +16.0   97.3 +21.6  +0.3 410.00 4.5  11.24
 5797 +15.1 4.4  97  80    00   +18.1   99.5 +22.0  +0.1 410.00 4.5  11.14
 6049 +14.3 4.5  98  70    00   +18.9   97.9 +22.4  -0.4 410.00 4.4  11.14
 6172 +13.9 4.5  97  70    00   +20.7   98.2 +22.8  -0.5 410.00 4.4  11.12
 6349 +13.7 4.4  94  70    00   +22.5   96.0 +23.3  -0.6 410.00 4.4  11.18
 6510 +13.7 4.5  35  80    00   +24.3   75.6 +23.8  +0.1 417.00 3.8  11.27
 5878  +8.8 1.9   0  00    00   +23.3    6.8 ECU.   +0.3 ECU.   1.6  11.34
 5611  +2.5 1.8   0  00    00   +23.3    7.5 ECU.   +0.2 ECU.   1.8  12.06
 5216  -4.0 2.5  36  10    00   +41.2   26.7 +26.0  -2.5 ECU.   3.2  12.21
 5299  -7.5 3.9  72  10    00   +32.9   63.4 +26.0  -1.2 390.00 4.0  12.49
 5208  -3.6 4.3  93  30    02   +17.0   89.5 +19.0  -0.9 410.00 4.3  12.93
 5324  +3.5 4.5  96  70    00   +13.8   96.4 +15.0  +0.0 410.00 4.4  12.11
 5224  +8.6 3.3   0  00    00   +25.2   20.1 ECU.   +0.2 327.50 2.0  11.62
 5184  +5.9 1.6   0  00    00   +23.3    6.2 ECU.   +0.2 ECU.   1.8  11.08
I am going to pull a bit of boost from 4500-5500. Is there anything else I can do to help bring down IDC's from 5500-6500 without lowering boost?
The knock event I got was a bit lean. This was after shifting into 4th and starting to get back on the gas I'm going to add some fuel in the those areas but was this knock caused by the fuel? or possibly the jump in the timing? I went from +26 to +19. If I set timing in the 5000rpm 10% column to +23 will that be enough to prevent this from happening again, or should I copy my 10% column over to the ecu?
Travis
Old 03-06-2006, 10:45 AM   #14
AaronWRX
Member#: 7194
2011 997.2 Turbo
Edit: Did you shift in that log or did you take your foot off the gas then mash the pedal in the sam gear?
The timing going from 26 to 19 is because the utec is pulling timing due to knock. I also noticed you dont have any timing in your 0%.
It sucks that youre knock because this looks to be a pretty anemic tune. Youre not running that much boost and your MAF voltage is weak sauce. What brand of gas are you using and do you make it a habbit of getting the same brand?
AaronWRX is offline   Reply With Quote
Old 03-06-2006, 01:14 PM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i do not agree with this.
fueling adjustments and offsets are not like timing. the engine sees the AFR and nothing else wrt fueling decisions. you make the AFR look nice, not the offsets.
Old 03-06-2006, 01:58 PM   #16
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Try to adjust the timing not jump more than 3 and lower your timing in low loads ... ur knock still at (-) psi so the A/F still fine ... but this just my 2cnt.
Old 03-06-2006, 06:20 PM   #17
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
I did shift, I ran up through 3rd then shifted to 4th and got the knock. Should I just move some timing into the 0% column from 5000rpm up? and reduce advance in those columns as well?
I use sunoco or exxon 93 all the time.
Do most people not let the ECU control timing in the higher RPM ranges?
Old 03-07-2006, 08:59 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you can get away without locking it down, then don't lock it down.
if you have to in order to prevent shift knocking, then obviously do it.
i have not had to lock it down, but ymmv.
ken
Old 03-07-2006, 09:17 AM   #19
djviper
Member#: 107276
99 V.R.Special
WRC blue
couple of things mate, change the injectors first youve got next to no head room for temp fluctuations or altitude
once youve done that could you post a 4th gear log from tick over to redline as the turbo only fully spools up in fourth
djviper is offline   Reply With Quote
Old 03-07-2006, 08:57 PM   #20
TravisSTi
Member#: 51243
2004 Subaru WRX STi
WRB - GTX30r
Yeah I'm saving up for injectors but until I get them I guess i'll just have to run less boost. But considering im tuning for winter weather pretty close to sealevel when it gets hotter won't it require less fuel as the density of the air decreases? The map I started with was a Summer low boost map tuned by TurboXS and all I have been doing to it is adding fuel, lowering boost and retarding timing. I'll pull some more boost and get 4th gear pull. I think I have my shift knock undercontrol now.
Old 03-09-2006, 12:40 PM   #21
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
The "mod fuel %" and the afr can be correlated pretty good. If you mod fuel % goes from -1 to -2 in the 4000 and 4250 row, I will be that your AFR's will change a 1/2 point or more. Making the AFR look nice will make your "mod fuel %" map look nice also. You won't see big changes in your fuel map unless something like boost comes on.
Old 03-09-2006, 12:48 PM   #22
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
That last log you did looks much much better. That’s the problem with the stock fuel system, its maxed out if you up the boost on the stock turbo. I installed the Walbro fuel pump in my car and it gave me a little more overhead. My IDC’s went from --.--- from 5500RPM up to 95% from 5500RPM up. So it might be worth a shot, but it may not work…..big debate on a fuel pump changing a tune…another day, another thread.
As for the knock event, it’s not fuel related. You are in vacuum and running 12.5:1 AFR. That’s really rich. Anytime you are in vacuum, you’re AFR’s should be ~14.7:1. I personally think the knock is due to the large jump in timing. In lower load columns, you can have higher timing values, even high in the RPM band.
As ride5000 said, if you don’t have to lock down timing in low load columns, don’t.
Old 03-09-2006, 01:52 PM   #23
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you'd lose that bet.
not necessarily.
case in point, a log from this very morning (complete with knock) :
Code:
5299 +23.9 4.5 100 100    00  11.1  +19.5   97.2 +15.6  -6.4 100.00 4.2  11.11
 5376 +23.9 4.5 100 100    00  11.1  +19.5   98.6 +15.3  -6.5 100.00 4.2  11.06
 5341 +23.9 4.5 100 100    00  11.1  +20.3   98.6 +15.6  -6.3 100.00 4.2  11.08
 5420 +24.1 4.5 100 100    00  11.1  +20.3   99.3 +15.2  -6.4 100.00 4.2  11.11
 5385 +24.1 4.5 100 100    00  11.1  +20.9   98.3 +15.3  -6.3 100.00 4.2  11.14
 5518 +23.7 4.5  99 100    00  11.2  +20.7   97.8 +15.3  -6.4 100.00 4.2  11.18
 5527 +23.7 4.5  99 100    00  11.2  +20.3    1.0 +15.5  -6.4 100.00 4.2  11.18
 5473 +23.7 4.5 100 100    00  11.2  +21.1   99.0 +15.5  -6.4 100.00 4.2  11.18
 5737 +23.7 4.5 100 100    00  11.2  +21.0   98.4 +15.6  -6.3 100.00 4.2  11.23
 5527 +23.3 4.5 100 100    00  11.2  +21.1   98.4 +15.5  -6.3 100.00 4.2  11.23
 5621 +23.3 4.5 100 100    00  11.2  +21.2    1.0 +15.5  -6.3 100.00 4.1  11.23
 5583 +22.9 4.5 100  90    00  11.2  +21.4   98.5 +15.6  -7.6 100.00 4.2  11.24
 5668 +22.3 4.5  99  90    00  11.2  +21.4   97.2 +15.8  -7.6 100.00 4.2  11.24
 5630 +22.3 4.5  99  90    00  11.3  +21.5    1.0 +15.8  -7.6 100.00 4.2  11.27
 5707 +22.3 4.5  99  90    00  11.3  +22.0   96.0 +15.9  -7.4 100.00 4.2  11.30
 5777 +22.5 4.5 100  90    00  11.3  +21.8   95.8 +15.8  -7.4 100.00 4.2  11.33
 5678 +22.5 4.5 100  90    00  11.4  +21.6    1.0 +15.7  -6.4 100.00 4.2  11.37
 5847 +23.1 4.5 100 100    00  11.4  +22.1    1.0 +15.7  -6.4 100.00 4.2  11.37
 5747 +23.1 4.5 100 100    00  11.4  +22.2   99.8 +15.6  -6.4 100.00 4.2  11.37
 5817 +22.3 4.5 100  90    00  11.4  +22.2   99.2 +15.8  -7.5 100.00 4.2  11.39
 5878 +22.3 4.5 100  90    00  11.4  +22.1   96.7 +15.9  -7.5 100.00 4.2  11.42
 5837 +22.3 4.5 100 100    00  11.4  +22.0    1.0 +15.8  -6.4 100.00 4.2  11.42
 5899 +22.3 4.5 100 100    00  11.4  +22.6   98.7 +15.9  -6.4 100.00 4.2  11.42
 5868 +21.8 4.5 100  90    00  11.4  +22.0    1.0 +15.9  -7.5 100.00 4.2  11.42
 6060 +21.6 4.6 100  90    02  11.4  +22.3   99.5  +9.8  -7.2 100.00 4.2  11.42
 5952 +21.6 4.6 100  90    00  11.4  +22.1   97.3  +9.7  -7.4 100.00 4.2  11.42
 5910 +21.6 4.6 100  90    00  11.5  +22.4   99.5  +9.8  -7.3 100.00 4.2  11.45
 6049 +22.1 4.6 100  90    00  11.5  +22.7    1.0  +9.7  -7.3 100.00 4.2  11.45
 6105 +22.5 4.6 100  90    00  11.5  +22.8   97.3  +9.7  -7.3 100.00 4.2  11.48
 6161 +22.5 4.6 100  90    00  11.5  +22.8    1.0  +9.9  -7.3 100.00 4.2  11.49
 6105 +21.8 4.5  99  90    00  11.5  +23.2   97.5 +10.0  -7.2 100.00 4.2  11.49
 6161 +21.8 4.6 100 100    00  11.5  +23.1    1.0  +9.7  -6.4 100.00 4.3  11.52
 6195 +21.8 4.6 100 100    00  11.6  +23.1    1.0  +9.8  -6.5 100.00 4.3  11.56
 6242 +21.8 4.6 100 100    00  11.7  +23.6   99.8 ECU.   -7.0 100.00 4.3  11.73
note the repeated jumping from -6.4 to -7.2 or -7.5. according to your theory, the afrs should be all over the place... yet this is not the case when one looks at the stability of the indicated afrs.
i'm telling you relying on the "prettyness" of your fuel offset map is the wrong way to determine the health, stability, or performance of the tune. whether or not you agree is up to you.
in the meantime, i will continue to put in whatever offset i need to net a given afr, regardless of whether or not it obeys some numerical pattern.
Old 03-09-2006, 02:18 PM   #24
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Well, I stand corrected and apparently my theory only applies to my car.
What logger is that?
I'm guessing when your injectors go static, the idc reads '1.0'?? Also, how are you knocking with only 15 degrees of timing??
Old 03-09-2006, 03:45 PM   #25
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that's UTI, by navybluesubaru. 20 lines/sec log speed.
the 1.0 in idc could be static, but in other logs i have 100.0 as an entry, so who knows? as long as the afrs are ok i don't really care.
as far as knock at 15*, did you notice the map and maf? that's a vf23 pushing that air into an ej205 block, which requires less advance than a 2.5l block in the first place.
oem wrx injectors btw.
Someone analyze my Utec logs.. jefersun Engine Management & Tuning 6 03-03-2005 10:11 AM
Is my UTEC log safe? no_rex_yet Engine Management & Tuning 8 05-15-2003 01:22 PM
check out my utec logs, please help! datdudedennis Engine Management & Tuning 31 05-01-2003 08:21 PM
tmic ic just put in.. examine my utec logs topgrinder Engine Management & Tuning 4 04-13-2003 06:53 PM
need help with my utec log....please topgrinder Engine Management & Tuning 3 03-24-2003 01:13 PM
