Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-05-2006, 10:59 PM   #1
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
Default Modded Injectors, UTEC, and Idle
Has anyone else had problems w/ the idle on the UTEC w/ modded injectors. Sometimes it idles fine, but other time it will sit there and almost die...you can also smell the gas, so I assume its running very rich. When its almost stalling...it will have a bit of black smoke out of exhaust...but once it smoothes out...its perfect....Anyone else had this?
wrxraaca is offline   Reply With Quote
Old 03-05-2006, 11:39 PM   #2
InfamousDX
Member#: 25413
Anyone tune it? Gotta scale it correctly then fix your 0% column. I kind of had the same problem.. it was idle SLIGHTLY weird on cold starts but nothing as bad as you describe but after I borrowed a good data logger to watch long and short term fuel trims, my idle is great. It's not even that hard too.
InfamousDX is offline   Reply With Quote
Old 03-06-2006, 12:20 AM   #3
plus plus plus
Member#: 102013
It is has been hard for me to adjust the short fuel trim in the o% column for higher rpms, numbers jump from 17 to -17 after resettting ecu and getting long term trim close to 0 .....this is not in gear readings....are the trims suppose to be 7+- through 1st-5 gear sequence ie driving?
I still feel I am missing something.....I am scaled at 720 running running 850 cc.......in descending order in the 0% column I have 13,12,11,11,10,......down to as high as 7 at 5000 rpm in fuel. I will posts logs later just got the trbo xs tuner...need to install.......
I am assumimg the numbers in the 0% column are high due to the 720 scale for utec injec. in parameters. The base map I have is catered to this scaling......logic correct?
trying to learn..
plus plus plus is offline   Reply With Quote
Old 03-06-2006, 12:22 AM   #4
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
Well...I just started my car, and it started on the 1st crank and perfectly...so I did some data logging, and looks like a I got shift knock...
Load Knock Mod Mod Mod
RPM MAP MAF TPS Site Count AFR Ign#1 Inj#1 Ign Fuel Boost MAF
psig V % deg duty deg % (CL) V
3223 -9.2 2.0 5 00 00 14.5 +36.4 6.2 ECU. +0.0 ECU. 1.6
3236 -9.2 2.0 5 00 00 14.5 +36.3 5.4 ECU. +0.0 ECU. 1.6
3233 -9.2 2.0 5 00 00 14.3 +36.5 5.8 ECU. +0.0 ECU. 1.6
3293 -8.2 2.7 31 10 00 14.6 +41.5 14.0 +26.4 +2.3 325.00 2.4
3336 -5.9 2.9 55 10 00 rich +34.6 14.0 +26.0 +2.3 325.00 2.5
3468 -3.5 3.0 84 10 00 rich +33.1 15.8 +25.7 +2.3 325.00 2.6
3557 -0.4 3.1 101 10 00 rich +33.0 18.4 +25.5 +2.3 325.00 2.7
3679 +2.0 3.3 100 10 00 rich +31.1 22.4 +25.5 +2.3 325.00 2.8
3862 +3.3 3.5 100 20 00 rich +30.7 24.9 +23.5 -1.1 325.00 2.9
4016 +5.5 3.6 101 30 00 rich +30.4 26.7 +22.5 -3.8 325.00 2.9
4145 +7.8 3.8 101 50 00 rich +29.6 32.5 +19.5 -3.2 325.00 3.0
4374 +9.8 4.0 101 50 00 rich +25.6 37.2 +19.5 -3.3 325.00 3.2
4528 +12.7 4.1 101 60 00 rich +25.2 38.3 +19.1 -3.9 325.00 3.1
4782 +14.1 4.0 100 70 00 rich +27.6 39.6 +18.7 -4.6 325.00 3.2
4967 +14.9 4.0 101 70 00 rich +29.4 42.2 +19.5 -5.0 325.00 3.2
5216 +15.7 4.2 101 70 00 rich +31.2 44.7 +19.5 -5.3 325.00 3.2
5509 +15.1 4.2 101 70 00 rich +31.7 47.1 +19.5 -5.2 325.00 3.3
5668 +15.1 4.2 100 60 00 rich +32.1 48.7 +20.8 -5.0 325.00 3.3
5868 +15.1 4.3 101 70 00 rich +33.6 50.1 +20.0 -5.2 325.00 3.3
5707 +15.1 4.0 50 70 03 17.5 +39.5 31.8 ECU. -5.2 LCM. 3.0
5249 +13.9 3.8 44 50 00 lean +37.0 31.2 ECU. -4.8 LCM. 2.9
4796 +12.5 3.7 101 40 00 24.2 +34.8 28.9 +20.5 -4.2 LCM. 2.9
4284 +11.2 3.9 101 40 00 rich +28.8 34.7 +20.5 -4.3 325.00 3.1
4420 +10.6 4.0 101 50 00 rich +24.1 37.1 +19.5 -3.4 325.00 3.2
4468 +12.5 4.0 101 70 00 rich +25.2 37.6 +17.5 -4.5 325.00 3.1
4636 +14.3 4.0 101 70 00 rich +27.5 37.5 +18.0 -4.2 325.00 3.1
4655 +15.7 4.0 101 70 00 rich +27.3 38.7 +18.4 -4.9 325.00 3.1
4866 +15.9 4.0 101 70 00 rich +27.4 39.8 +18.7 -4.7 325.00 3.2
4930 +15.1 4.1 101 60 00 rich +27.7 43.1 +20.1 -4.8 325.00 3.2
5065 +14.7 4.1 101 60 00 rich +27.4 44.4 +20.5 -5.1 325.00 3.2
5128 +14.9 4.2 101 70 00 rich +29.5 44.1 +19.5 -5.1 325.00 3.2
5175 +15.1 4.2 101 70 00 rich +31.1 44.1 +19.5 -5.3 325.00 3.2
5359 +15.1 4.2 101 60 00 rich +31.1 46.2 +20.5 -5.1 325.00 3.3
5446 +15.5 4.2 101 70 00 rich +31.1 46.1 +19.5 -5.2 325.00 3.3
5659 +14.9 4.2 100 70 00 rich +31.8 48.7 +19.8 -5.2 325.00 3.3
5659 +15.1 4.3 101 60 00 rich +32.0 49.4 +20.8 -4.8 325.00 3.3
5698 +15.5 4.3 101 70 00 rich +32.6 48.0 +19.9 -5.1 325.00 3.3
5446 +12.2 3.0 0 00 00 15.8 +11.0 14.0 ECU. +0.0 LCM. 2.2
Old 03-06-2006, 10:10 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
lock down 0 column timing in that area to something like your 100 column numbers.
Old 03-06-2006, 10:53 AM   #6
wrxraaca
Member#: 81490
2002 Subaru Wrx
Blue VF-22 Equipped
You mean like where it says ECU..put in 0....?
Old 03-12-2006, 02:52 AM   #7
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
put in 20
santofontana is offline   Reply With Quote
05 WRX TMIC, modded injectors, intake,and more jayster Engine/Power/Exhaust 7 05-12-2008 02:44 AM
UTEC and Modded stock injectors - Experts wanted! Division By Zero UTEC 87 05-19-2006 04:19 PM
Inspection with modded injectors and utec ejsportcom Engine Management & Tuning 0 03-31-2006 01:26 AM
FS:FMIC, injectors, UTEC and big maf flp_sde MAIC Private Classifieds 12 01-11-2006 08:22 PM
Modded injectors, cleaned and flowed DjRez4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-20-2005 06:13 PM
