Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-27-2006, 11:35 PM   #1
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Default Will Utec work Without Abc Valve?
Anyone have used the UTEC boost controler without the ABC valve? Where do you hide the map switch?
gaby is offline   Reply With Quote
Old 02-27-2006, 11:52 PM   #2
gaby
Member#: 94097
[email protected]
Sorry, I just bought one use and it didn't came with the abc. I intended to use it in a WRX 04.
Old 02-28-2006, 01:12 AM   #3
gaby
Member#: 94097
[email protected]
Anyone???????????
Old 02-28-2006, 01:38 AM   #4
Gethin
Member#: 2998
You can use the factory boost controller and UTEC without the ABC but if you don't hit your psi targets with values in the boost map alone you need the ABC as a bleeder to get to those targets (which is specified in the UTEC user manual). The UTEC is not a boost controller btw it's a piggyback ECU and can control fuel, timing, boost and a host of other goodies, if you dont know that already.
http://www.turboxs.com/downloads/UTE...nual%205.0.pdf
You can stick the map switch anywhere you like!
Gethin is offline   Reply With Quote
Old 02-28-2006, 03:12 AM   #5
gaby
Member#: 94097
[email protected]
Thanks. I'll stick it where ever I wanted.
Old 02-28-2006, 01:54 PM   #6
Gethin
Member#: 2998
Old 02-28-2006, 09:31 PM   #7
gaby
Member#: 94097
[email protected]
Bump.
Old 03-01-2006, 07:46 AM   #8
Rich10
Member#: 14934
Why don't you contact TXS and see how much a new ABC is?
Rich10 is offline   Reply With Quote
Old 03-01-2006, 10:44 AM   #9
gaby
Member#: 94097
[email protected]
Yea I already contacted them, It cost with the hardwarekit $35.
Old 03-01-2006, 12:39 PM   #10
MonoxideChild
Member#: 107739
04 Ej20
Default abc
i talked to someone named Nathan. he said the a.b.c. is 85$ and the hrdwr. kit is 35$
MonoxideChild is offline   Reply With Quote
Old 03-01-2006, 05:13 PM   #11
gaby
Member#: 94097
[email protected]
Wink
Hi,
The UTEC Hardware kit can be purchased for $35, which will include everything you described below.
Thanks,
Jermaine~
www.turboxs.com
301-977-4727
-----Original Message-----
Sent: Monday, February 27, 2006 11:26 PM
To: [email protected]
Subject: Harware
I need The kickplateand/ecu standoff, kickplate J-bracket and bolt, the abc, abc Y and the 9volt adaptor. Can you guys sell those items for a UTEC ver.5?
That was the answer.
Old 03-04-2006, 08:26 AM   #12
xolosis
Member#: 103373
May be too late but what I recommend is to do away with the ABC and get yourself a 3-Port Boost Solenoid. Perrin and Prodrive sell a good units. You don't have to worry about messing around with the turning the ABC when you don't reach your disired boost target; plus Perrin unit will control boost up to 120psi.
Hope this is of some help...
xolosis is offline   Reply With Quote
Old 03-04-2006, 03:48 PM   #13
gaby
Member#: 94097
[email protected]
So the problem with the WRX is that the boost solenoid is to slow?
Old 03-04-2006, 05:22 PM   #14
Freon
Member#: 88322
2009 BMW 135i
The problem with the stock solenoid (if you have the problem, that is) is it doesn't bleed enough air to keep pressure off the wastegate. Another solution is to use a slightly smaller restrictor right off the compressor, or swap out the solenoid for either an interrupt solenoid, or a higher flowing bleed.
There is no one piece that you can say is solely "at fault." There are multiple solutions. The factory setup is working as intended.
Freon is offline   Reply With Quote
Old 03-06-2006, 06:03 AM   #15
gaby
Member#: 94097
[email protected]
I put a smaller restrictor(compresor side) and it hit 22 psi I went down on the bosst map to 75 on the 100%. It will hit 13.5psi but it peak 16 first. is there any way to control that peak with the UTEC (100 on the gain, 0 wastegate shut)?
Old 03-15-2006, 08:31 PM   #16
gaby
Member#: 94097
[email protected]
I fix it 80=16psi with the small restrictor, wich Im happy with.
Old 03-15-2006, 08:44 PM   #17
gpatmac
Member#: 18446
2002 WRX wagon
psm
I've got an extra if you need it.
gpatmac is offline   Reply With Quote
Old 03-15-2006, 09:15 PM   #18
gaby
Member#: 94097
[email protected]
thanks for the offer. It is working fine without it.
Old 03-15-2006, 09:38 PM   #19
gpatmac
Member#: 18446
2002 WRX wagon
psm
Okeydoke.
Anyone else using UTEC without ABC installed? disque71 Engine Management & Tuning 6 11-08-2005 11:01 PM
ABC valve or MBC for TurboXS unichip NEEDED! alvyman Private 'Wanted' Classifieds 2 12-20-2003 03:45 PM
ABC VALVE + Y . Turboxs parst.. WTB WRX Jim Private 'Wanted' Classifieds 0 10-22-2003 06:47 PM
Utec and ABC? DocDetroit Engine Management & Tuning 3 12-01-2002 08:29 PM
Unichip without ABC/MBC ? Ken Levin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 11-14-2002 09:23 PM
