#1 |
Member#: 79078
Vehicle:2004 WRX PSM |
Just ordered a utec from spun motorsports and I was wondering if I can use my manual boost controller with utec or if I have to hook up my stock boost controller. If so would it be better to buy the perrin ebcs. I know i should probably search this but dont have much time on the computer and it will be here by the end of the week
thanks Kenny
#2 |
Member#: 17302
Vehicle:2002 Impreza WRX you know... the blue one |
The UTEC can control your boost with the stock boost solenoid and comes with an ABC(aux. boost con.) as a bleeder in open loop (it's been a while). In closed loop it's not nessesary to use the ABC and the stock solenoid will work fine but might have a little spiking. I have the Perrin EBC and it does a great job regulating the boost with the UTEC.
I wouldn't use the MBC fwiw. |
#3 |
Member#: 79078
ok then I will hook the stock boost solenoid up..
thanks kenny |
#4 |
Member#: 107739
Vehicle:04 Ej20 |
does anyone know how to get ahold of the ABC which comes with new utech..i bought a used one, and no abc or anything included,just utech...what else will i need
#5 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
TurboXS is best place to get the other UTEC parts. Or ebay if someone has a spare ABC.
#6 |
Member#: 88322
Vehicle:2009 BMW 135i |
You may not need the ABC. I'd try to make the car run the boost you want without the ABC first.
#7 |
Member#: 107739
Vehicle:04 Ej20 |
35$ hardware kit
89$ A.B.C turboXs has the best cust. support found out everything i need and then some.. too bad i couldnt talk longer, im at work. guess i should sell some car parts maybe.....? ![]() |
#8 |
Member#: 107739
Vehicle:04 Ej20 |
A.B.C. is a must for the utech to cover your boost duty....unless you run a mechanical,or other boost controller....
#9 |
Member#: 9898
Vehicle:2002 WRX Water Injected Blue |
$35 to me and I ship that ABC to you with the allen key.
PM me |
#10 |
Member#: 73405
whats the a.b.c used for? i dont understand it in full, is it like a m.b.c when its in open loop?? I was going to replace my stock solenoid with the perrin one once my utec comes in should i do it?? and if i do do i need to use the a.b.c with it??
#11 |
Member#: 2998
VIC
abc is a bleeder valve. Helps the bcs if the values in your map dont get you to where you want to be i.e. hitting the correct boost targets as per the TurboXS manual. Some cars need it, come don't. Best to install it closed, run the basemap, check your logs and take it from there, increasing values in boost map to reach targets, if you have to put in values over 400 for example, try opening abc a few turns then log again to check boost levels.
| Thread Tools | |
| Display Modes | |
| UTEC boost control, or UTEC combined with Profec B...advice needed... | gills | UTEC | 9 | 04-01-2006 04:39 PM |
| UTEC boost control? When is it time for AVC-R or E-Boost?? | AaronWRX | Engine Management & Tuning | 4 | 03-29-2006 03:53 PM |
| UTEC Boost control as good or better than other boost controllers? | DocDetroit | Engine Management & Tuning | 0 | 02-04-2003 09:40 PM |
| UTEC boost controller or SBC-id | rochyrex | Engine Management & Tuning | 10 | 10-22-2002 10:38 PM |
| Utec Boost Control Solenoid Duty... | wop138 | Engine Management & Tuning | 1 | 10-20-2002 10:27 AM |
