Old 02-28-2006, 12:40 AM   #1
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
Question 04' WRX Accessport Stock Map ?
I recently uninstalled my Accessport from my 04' WRX. When the stock Subaru "generic" map is loaded onto the ECU, from the Accessport, how does it know if the vehicle is manual or automatic transmission? Accessports are not sold transmission specific until 06'. Are M/T and A/T stock maps the same for 02'-05'?
Any feedback would be much appreciated.
Russell
sanremo_russ is offline   Reply With Quote
Old 02-28-2006, 01:31 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Russell
....d00000d.....there is no 'generic' map.......there IS the map that was on the car when ya started---which knows which tranny ya got, just fine
Old 02-28-2006, 09:40 AM   #3
JRSCCivic98
Member#: 67080
Have you gone crazy with the d00000d thing?! That isht is really starting to get anoying here lately.
Anyway, the map that's on the AP as "Stock" is not nessaceraly the same map version you started out with prior to the AP being married. It's more then likely different. As for how the ECU knows if a car is auto or manual... it has to do with a hard wired pin on the ECU. That hard wire is what triggers the ECU to use the different maps in the ECU that pertain to whatever kind of transmission you have. There are 2 boost maps in there for example... one for auto and one for manual. Just FYI.
JRSCCivic98 is offline   Reply With Quote
Old 02-28-2006, 11:19 AM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Actually, FYI, that pin doesn't trigger the ECU to select different maps, only whether or not to try and negotiate communications with the TCU (and throw appropriate trouble codes if it fails).
Also, in answering the OP's question, so long as the CalID is the same, the ECU EEPROM for manual and automatic transmission vehicles are identical... ie, an AF413 AT ECU and an AF423 MT ECU use the same A4SGD10C CalID. Any AF41x and AF42x ECU can be flashed with any of the A4SGxxxx CalID ROMs and be functional (though, perhaps, not optimal).
Kha0S is offline   Reply With Quote
Old 02-28-2006, 03:04 PM   #5
subieworx
Member#: 47769
[quote=JRSCCivic98]Have you gone crazy with the d00000d thing?! That isht is really starting to get anoying here lately.
QUOTE]
If you only knew!!!
Another nub d00ded by US.
subieworx is offline   Reply With Quote
Old 03-28-2006, 11:49 AM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Russell
The 2004 and 2005 WRX ECUs have a different Calibration ID depending on whether the car is manual or automatic transmission. When you revert to stock on those cars, the resulting Calibration ID will be one that Subaru only shipped on cars with automatic transmissions. Which means that if your car is manual transmission, it's not very hard for a dealer to detect that the ECU has been reflashed by someone other than Subaru.
Jon [in CT] is offline   Reply With Quote
Old 07-23-2006, 08:39 PM   #7
tairese
Member#: 103385
2005 WRX CGM
Cobb Stg negative 15
bumping an old thread. Any way to make it so when you revert to stock, the Calib. ID says Manual?
tairese is offline   Reply With Quote
06 wrx tr stock map flippedr6 Open Source Reflashes 5 09-17-2009 03:06 PM
FS: jdm sti pink injectors, 04-05 wrx accessport, stock wrx fuel pump (IL) normaspirated Private 'For Sale' Classifieds 6 05-12-2006 10:24 AM
FS: jdm sti pink injectors, 04-05 wrx accessport, stock wrx fuel pump (IL) normaspirated MWSOC Private Classifieds 0 05-11-2006 02:55 PM
pix request of 04' wrx on stock rims and if so, do you need a camber kit? gookyjabroni Member's Car Gallery 7 04-18-2005 11:54 PM
Another person looking for used 04' WRX Accessport sanremo_russ North West Impreza Club Forum -- NWIC 0 09-14-2004 02:10 PM
