Old 02-28-2006, 01:10 AM   #1
The_Bang
Member#: 97572
Default Disappointing EJ20T conversion
Help needed to all the gurus here,
I have recently swap my EJ16 to EJ20T block to my ride last week. I am currently disappointed with the results. It seems that after some mods, my ride's feel does not make any much difference to my last EJ16 block.FYI, I do not intend to turbo-charged my ride as the country I'm living in had such strict laws here. Here are some mods I had done & also need your guys feedback:~
1) 2.5RS extractor was installed to my ride
2) 60mm throthle body
3) Spark plug optimizer
4) Electric air charger
5) Will a piggyback ecu solve my acceleration issue & how many ponnies(hp gain) do I expect from the ecu tuning?
6) Is a EJ22 better than EJ20T to be an ultimate NA runner? FYI, I had intended for the EJ22 block because it looks the same as EJ16 & I can't go for EJ25 block as I had mentioned due to the heavy penalties law in my country.
7) I am still on my original 1.6TS manual gearbox & clutch setup . Should I changed to other gearbox & clutch setup in order to improve my acceleration?
8) Do I need to change my differential as well to Rex for example after my gearbox conversion & clutch setup?
Please help me as I am a newbie to Scooby. Thanks all.
The_Bang is offline   Reply With Quote
Old 02-28-2006, 01:52 AM   #2
azn2nr
Member#: 35276
um, yeah so that electric air charger, doesnt do jack but hurt your motor. your running a turbo block na so you have no power due to lower compression. if your country knows how to check blocks ill be suprised. adn yeah, if your country has strict limits you just screwed yourself.
singapore??
azn2nr is offline   Reply With Quote
Old 02-28-2006, 02:10 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you must live somewhere in europe or asia, truth is you went about this whole process ALL WRONG. and EJ20t was not what you wanted to use an EJ20 NA block however would have done wonders.
Old 02-28-2006, 03:07 AM   #4
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
um. you lost power. tear the EJ20 apart and shove in some high comp slugs.
then you might gain somthing
slugs = pistons.
high comp = higher compression, 10:1 or somthing like that would be pretty reasonable
swapstar is offline   Reply With Quote
Old 02-28-2006, 08:07 AM   #5
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
So... you're running a turbo motor sans turbo? Compression ration is going to be way too low, for one. If you want to keep running NA, the yes, the NA EJ22 or the EJ25 are much better choices.
... i'm pretty sure.
bl_easy is offline   Reply With Quote
Old 03-01-2006, 01:55 AM   #6
_dk_
Member#: 42189
2002 wrx waggie
wrb
where do you live that you can swap to a different engine, but not the turbo that goes with it?
_dk_ is offline   Reply With Quote
EJ20T JDM conversion help! 96SubyImpreza Subaru Conversions 1 09-21-2007 03:43 PM
disappointed with HID conversion psykotik maniak Electrical & Lighting 29 02-01-2007 03:19 AM
89 ej22 conversion to 93 ej20t rs wiring problems askep18 Newbies & FAQs 1 06-03-2005 04:55 PM
AVO, F.A.T, or EJ20T conversion? LB2.5rs Subaru Conversions 0 08-10-2003 12:54 AM
