Old 12-11-2000, 07:42 AM   #1
Ben
Member#: 423
2002 WRX wagon
Have a Nice Day? Noise from Rear Diff!!!
Hi people, I just change the diff oil to the Redlind 75W90(Not 75W90NS,I use the 75W90NS for the Tranny)
While I driving on the Hwy, I could here noise from the rear, That havne't happened before!!! Any problems??
Ben is offline   Reply With Quote
Old 12-11-2000, 07:51 PM   #2
BG5
Member#: 695
Arrow
It's normal.
Redline oils have a lot fewer noise-deadening additives than mainstream motor oil so whatever (diff, trans, engine) you put it in will run a little louder than before.
You may want to consider a thicker viscosity gear oil if the diff is really making a lot of noise.
BG5 is offline   Reply With Quote
Old 12-12-2000, 12:08 AM   #3
RandyF
Guest
Member#:
Thumbs down
Sorry, I don't have your answer; but I have a comment: You gotta quit cross-posting these questions... I'm sure you will get more than enough responses in the other forums.
Just my 2cents...
A
Old 12-12-2000, 09:18 AM   #4
Ben
Member#: 423
2002 WRX wagon
Post
Thanks BG5, you make me to not worry anymore!
Old 12-13-2000, 02:51 PM   #5
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
Post
IME, heavier Redline fluids won't be any quieter. My rear diff made a little more noise after switching to Redline, but either it is gone, or I can't notice it anymore.
I believe it is the former.
hillman is offline   Reply With Quote
Old 12-13-2000, 02:53 PM   #6
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
Post
Oh, and FWIW, to folks who haven't changed their fluid; after less than 15,000 miles, the fluid which drained from my rear diff was in bad shape. Black, and nastier-than-usual smelling.
I think a pre-emptive diff fluid change is an even better idea now, than I did before I saw the fluid.
noise comming from rear diff area? "service bulletin from subaru" fliped wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-03-2008 05:43 PM
clunking noise from rear diff banta80 Transmission (AT/MT) & Driveline 7 03-18-2005 11:11 PM
wierd noise from rear diff spencerxi Transmission (AT/MT) & Driveline 2 02-06-2005 05:59 PM
'Cracking' noise from rear diff.?? STIr Transmission (AT/MT) & Driveline 2 01-29-2005 05:18 PM
Noise from Rear diff!!????? Ben General Forum Archive 3 12-11-2000 01:22 PM
