Old 12-10-2000, 07:03 PM   #1
Kruf
Member#: 2612
Angry 97 2.5 GT Bucking under 2k RPM... help!
Ok, I used Gary's fix to fix the midrange light throttle hesistation, worked like a
charm, thanks Gary! Now for the other problem that has just crept up. I have a rock solid, steady idle, but at 1/2+ throttle, under 2k rpm's, my car bucks like a bronco! Anyone have any experience with this? I reset my ECU hoping it would help, but no luck. Any suggestions fellas?
Kruf is offline   Reply With Quote
Old 12-11-2000, 05:24 AM   #2
Danno
Member#: 3013
2002 WRX Sedan
Mithril
Question
I don't have an answer to your question, but I have the same sort of problem below about 3000 rpm and was hoping Gary's fix would do it. My trouble is that my mechanic skills aren't the greatest and I don't want to get this thing taken apart any more than I'm sure I can put back together correctly. Did you have to remove the intake manifold to install Gary's fix? Did you actually remove the knock sensor from the block as per Gary's instructions, or did you leave the knock sensor in and just splice into the wire? Is there a trick to this? I'm having trouble getting at the wire and connector. The Haynes book says that in order to get to the knock sensor you have to drain the coolant, remove alternator & a/c compressor, remove intake manifold, etc., etc. Since Gary's page says "installs in minutes" I would think there's got to be a better way, but I can't figure out how. Kruf or anybody else who's done Gary's mod, I would appreciate any hints or tips.
Thanks!
Dan Crank
1997 Legacy GT Sedan
1995 Suzuki Katana 600
Danno is offline   Reply With Quote
Old 12-11-2000, 06:36 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
What is "Gary's fix"? I'm not familiar with this. Of course, I'm not sure I have anything to fix!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-11-2000, 06:51 AM   #4
gumball
Member#: 1209
Post
Patrick- Gary's "fix" is to quiet the signal from the knock sensor, b/c Subaru's TSB identified certain 97-98 ECUs that were overreacting to the signal from the knock sensor and drastically retarding the timing. The result is a low-mid range hesitation or flat spot, around 2K rpm.
His suggestions are to a) put a couple rubber donuts or other material betw. the knock sensor and the block to dampen it or b) splice in a home-made resistor, which he sells. I've used b) w/ no problems whatsoever, before that I had to re-set the ECU every week.
gumball is offline   Reply With Quote
Old 12-11-2000, 01:57 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
OK, I have heard of that before. I just bought my '97 this past weekend, haven't noticed any problems with excessive hesitation yet. I'll have to pay attention to see if I notice any problems.
Pat
Old 12-11-2000, 02:31 PM   #6
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Post
The new fix is different. all it involves is disconnection the wire to the knock sensor and putting some wires in line w/ vampire taps.
Here is Gary's site:
http://home.earthlink.net/~hobiegary/hesitation.htm
And some good info from Brian's: http://members.nbci.com/_XMCM/northu.../paperclip.htm
Brian's site has the install directions from Gary.
Peaty
PS I have the kit but never installed it because I don't have the hesitation problem myself.
Peaty is offline   Reply With Quote
Old 12-11-2000, 03:24 PM   #7
Danno
Member#: 3013
2002 WRX Sedan
Mithril
Post
Those of you who installed Gary's fix (the one with the vampire taps), were you able to do it without removing the intake manifold?
Dan
Old 12-11-2000, 06:20 PM   #8
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Post
I almost installed it on my car, I had the plug apart from the knock sensor and everything. It's a little tricky to get your hands in there but it's very simple to do. You won't have to remove anything. Just run the wires and tap the taps.
Old 12-13-2000, 06:51 AM   #9
SSLegacyGT
Member#: 2865
2006 Legacy 2.5i
Wagon, 5MT, Blue
Cool
Hey-
I thought for a while that I had that hesitation problem and I was about to get garys fix, until my check engine light came on. Found out my #3 plug was faulty. I was kinda pissed cause I had dismissed my plugs as the problem seeing as I had just changed them. Anyway, I upgraded to Platinum +4's, and I get noticeably smoother acceleration from stop. Just wondering if anyone has looked into getting MSD ignition or other high performnce ingnition system installed in their suby, pros/cons?
SSLegacyGT is offline   Reply With Quote
Old 12-13-2000, 09:10 AM   #10
gumball
Member#: 1209
Post
I think the TECII (they have their own forum) system uses the full-blown aftermarket MSD or similar ignition coil replacement. Probably a good thing, but friggin' expensive. I just stick w/ Torquemaster plugs & Magnecor wires.
As for the intake removal for gary's fix, yeah you really don't have to take anything apart. Though I got frustrated trying to work in such a small, hard to reach space and actually unbolted the knock sensor to get easier access to the plug and wire.
Old 12-13-2000, 01:18 PM   #11
Kruf
Member#: 2612
Unhappy
SO no one has any ideas about what is going on here? I called Trey from Cobb TUning to see if I could get any answers and he didn't know either. Do you guys know who I could contact about this? A professional scooby specialist shop anywhere? THanks...
Old 12-13-2000, 01:46 PM   #12
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Post
How old is the fuel filter?
When my fuel filter & sparke plug is about 25Kmi, the car bucked at low rpm well, around 2K rpm as well.
Hope this helps.
Jason is offline   Reply With Quote
Old 12-13-2000, 02:05 PM   #13
Kruf
Member#: 2612
Lightbulb
Thanks for the idea, Trey just suggested the same thing, try changing the fuel filter and sparks plugs and wires becuase it can't hurt anything. If your car had the same symptoms, it sounds like a very good place to start. Everyone I have talked to about this has been extremely helpful. Thanks EVERYBODY!
looking for a swaybar for my 97 2.5 gt sedan revhigh96 Legacy Forum 6 04-05-2005 03:57 PM
Any difference between a 97 2.5 gt and a 98 2.5 gt Polskino Legacy Forum 3 12-21-2003 07:51 PM
Looking at a 97 2.5 GT 80mgb Legacy Forum 1 03-07-2002 04:33 PM
97 2.5 GT Head Gasket update jsnspence Legacy Forum 15 02-16-2002 12:05 PM
97 2.5 GT Misfire cylinder 2 nightmare?!! jsnspence Legacy Forum 8 02-15-2002 10:32 AM
