Old 02-28-2006, 04:48 PM   #1
o2sys
Member#: 43842
200? WRX STI
Default I got this DCCD controller and now what?
i got the USDM OE DCCD controller, i called rallispec and they kindly told me what i have is pretty much useless cuz this is the auto control box. That i needed to source the DCCD wiring harness from an USDM STi. Which i know its near impossible because the harness is wrapped together with all the other wires, since i've helped doing a complete sti swap. So has any gurus out there figure this box out? Has anyone used the USDM OE DCCD controller to work with a WRX? maybe some custome wiring made?
HELP ME~
here is a pic of what i have: part number is 32520AA080
o2sys is offline   Reply With Quote
Old 02-28-2006, 04:53 PM   #2
cronic
Member#: 9749
Can't really help ya there, but i have a GEMS controller i can sell ya.. It is a simple install and is fully mapable.. I have the switch with 5 pre programed maps.. It is used..
Dave-
cronic is offline   Reply With Quote
Old 02-28-2006, 05:32 PM   #3
LastResort
Member#: 99289
I'm pretty sure you need the STi ABS controller. As the DCCD wants wheel speed information to determine the best lock up when in Automatic mode. Somebody else should feel free to correct me though if I'm wrong. Someone had an STI trans swapped into a Forrester at some point, you may try looking around and contacting him.
LastResort is offline   Reply With Quote
Old 02-28-2006, 05:38 PM   #4
o2sys
Member#: 43842
200? WRX STI
i think that was Tom from kartboy
Old 02-28-2006, 06:35 PM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
umm. yeha. its useless unless you want to rewire the whole car. sell it on ebay, and get somthing you can use. you might even make profit
h
swapstar is offline   Reply With Quote
Old 02-28-2006, 06:48 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
its not useless but unless you can plug into it it is.
If you just want manual mode you can rig that up, give it power and ground, then you have to hook up the thumbwheel or just make a switch to feed the correct pin 5 volts to make it think the scroll is in lock and you will be 50/50. however for the money you likely paid you could have had a neetronics controller with an automode for less. PDXTuning has them if you are interested.
Ben
Old 02-28-2006, 07:00 PM   #7
o2sys
Member#: 43842
200? WRX STI
didnt pay anything for it...
Old 03-01-2006, 12:18 PM   #8
ejsportcom
Member#: 88905
i ended up in your situation, just look in the sti manual and hook up all that is needed for the manual mode, auto is far beyond our reach..... that is unless you have a full crashed sti to strip to the bone....
ejsportcom is offline   Reply With Quote
Old 03-01-2006, 04:06 PM   #9
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
you beat me to it
as he said, just wire it up for manual mode
Hyper is offline   Reply With Quote
Old 03-02-2006, 10:35 AM   #10
o2sys
Member#: 43842
200? WRX STI
yea just wire it up.....ok if it was that simple
Old 03-02-2006, 03:22 PM   #11
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
what year is it from? I had some wiring diagrams for those somewhere
Old 03-03-2006, 12:07 AM   #12
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
It's about as much work wiring the Auto DCCD in as it is to do a WRX / STI engine swap in like an 93-01 Impreza. We converted Roundthebend's FXT from Automatic to 6 Speed (With Wheels, Brakes, Axles, Steering Rack, Xmember, Control Arms, Rear Sub assembly, STI Suspension, and then added STi Intake Manifold, uppipe, turbo, intercooler and reflashed STI ecu, and completely wired in the DCCD. We also made a custom dash harness to allow the STI gauge cluster to function properly. There was a rumor that the cluster was plug and play (Which IS NOT true). If you study the wiring diagrams for the cluster, There is not ONE single pin that shares a location between the STI and the FXT harness. The whole car functions just as it would in a 2004 STI (because it, for all intents and purposes, is a 2004 STI with a Forester shell). You can see some of the pictures here http://forums.nasioc.com/forums/showthread.php?t=847303
I will post up more from the build tomorrow if anyone is interested.
We were doing Erik's swap the same time Tom from Kartboy was doing his. Last I heard, tom had not decided to wire up the DCCD as it would take too much time. Origionally we had just planned to swap chassis harnesses, but the differences between the two harnesses was big enough that it would have been more work to switch the connectors for the Climate control system, door cords, Power Mirror (STI has the power mirror switch in the center console, where as teh FXT has it in the Drivers door), plus the FXT has seat heaters and the STI didn't. So it was easier to add the DCCD to the FXT harness than it would have been to adapt the FXT functions to the STi harness.
wrx_driver_2002 is offline   Reply With Quote
Old 03-03-2006, 08:57 AM   #13
LastResort
Member#: 99289
YESSSS! Uh, I mean please...
Old 03-03-2006, 10:24 AM   #14
o2sys
Member#: 43842
200? WRX STI
is the one you sent kevin? if so he sent me a copy still looking at is like greek to me
Old 03-06-2006, 09:28 PM   #15
Jonnyfilmboy
Member#: 68902
2011 WRX - WRBM
1988 Fiero GT - black
you beat me to it
You shame us all with your comments.
Jonnyfilmboy is offline   Reply With Quote
Old 03-06-2006, 10:03 PM   #16
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
my friend, it's not my fault that you want to rip people of with those prices
you wanna discuss that, go back to your thread
I don't see how you are helping this thread
Old 01-22-2007, 06:49 PM   #17
shadymilkman129
Member#: 53651
Cert Suby tech
specialist for hire!
can you repost the pictures? They are all red X's...
shadymilkman129 is offline   Reply With Quote
Old 01-23-2007, 03:22 PM   #18
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
When your shop is the best in the biz you make it sound so easy! ^^
Token-Negro is offline   Reply With Quote
FS: Spiider DCCD controller and stock STI sway bars with links Cyclops NWIC Private Classifieds 7 02-02-2010 12:39 PM
04 STI Dccd Controls and mirror control complete. wrxwagon253 Interior/Dressup/Audio & Security 31 04-27-2009 12:01 AM
WTB: 04 DCCD controller and/or switches rynine Private 'Wanted' Classifieds 2 09-19-2007 07:41 PM
I got this twin turbo motor...Now what? scubydrew Subaru Conversions 14 07-17-2007 11:58 AM
DCCD Controller Alternative - Now with pictures!!! Bayley Transmission (AT/MT) & Driveline 12 11-21-2005 08:51 AM
