Old 02-28-2006, 08:41 PM   #1
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
Default HID's into non-hid bugeye JDM projector quesiton
Which set would fit without having to cut/hack into the back of the housings for them to fit. Ive heard some kits do not fit? Interested in the Kaixen kits..let me know what works
thanks
BuggeyEYED is offline   Reply With Quote
Old 03-01-2006, 12:34 AM   #2
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
why dont you PM the guy thats selling the Kaixen kit in the Group buy thread. he might have more info for you
bubba03wrx is offline   Reply With Quote
Old 03-01-2006, 05:59 PM   #3
BuggeyEYED
Member#: 101691
97 Supra TT
i asked him..he doesn't know...he's new to the subaru world...no one has bought one yet but one was ordered for the projectors..i guess i have to wait till he posts up?
he expects to have to drill for the wires ..
Old 03-01-2006, 06:15 PM   #4
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Every HID kit will need you to cut a hole in the back of the housing cup. The stock bulb you can unplug the wires from the bulb. However with aftermarket ones all of the wire connections are on the bulb so You can't easly remove it, this is why you need to cut a bigger hole in the cup piece and then thread the wire connnectors through it and use the supplied grommet to seal it all up.
-Dan
suby_dude is offline   Reply With Quote
Old 03-03-2006, 04:43 AM   #5
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Ya.. I really didn't want to cut a hole in the back of my JDM's but after a year I finally caved and did it. It's really worth it, the hids look amazing in the projector.
Uncle Ben is offline   Reply With Quote
Old 03-03-2006, 07:21 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You should also open them up and fix the RHD beam pattern, which is already an issue with halogens but even more so with HIDs.
Old 03-03-2006, 08:11 PM   #7
BuggeyEYED
Member#: 101691
97 Supra TT
what do you mean open them up?? and how do i fix it?
if it has ANYTHING to do with "OPENING" and sealing back again..count me OUT!!..lol..not messing around with $900 lights
Old 03-03-2006, 08:30 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes it involves opening them up and modifying things inside. But, if you don't the RHD beam pattern (which rises to the left) will blind oncoming traffic.
Old 03-04-2006, 01:19 AM   #9
BuggeyEYED
Member#: 101691
97 Supra TT
ive heard not EVERYONE has a problem with them..some ppl say you can just do simple adjustments with a screwdriver..
Old 03-04-2006, 06:42 AM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You can lower the beam to reduce the effect, but this does nothing to alter the beam pattern and will reduce the amount of usable light on the road. If you lowered them enough to eliminate the glare to oncoming traffic totally the lights would be of minimal use. It is in both your own best interest as well as that of other drivers to modify the lights properly. This is something that anyone purchasing JDM lights needs to be aware of, and especially anyone putting HIDs in them or buying the OEM JDM HIDs.
Old 03-04-2006, 06:42 AM   #11
garie
Member#: 26607
2002 wrx wagon
the light pattern won't be that great with the rhd lights......even if you try to adjust the aim of the headlights you will still be blinding ppl.
there are instructions on scoobymods.com on how to grind the shadow plate. I did it to my jdm projectors w/ hid kit and the light pattern now is immensely better.
I actually will probably redo it and try to do a better job since my drivers side still shines a little too high
garie is offline   Reply With Quote
Old 03-04-2006, 10:15 AM   #12
BuggeyEYED
Member#: 101691
97 Supra TT
can anyone find the link on scoobymods...i cant...
Old 03-04-2006, 12:14 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Here is Imprezer's thread on I-club, with pics-
http://www.i-club.com/forums/showthread.php?t=3988
Old 03-05-2006, 09:24 AM   #14
BuggeyEYED
Member#: 101691
97 Supra TT
nice write-up but..im not taking the chance...anyone in the NJ area done this? and would do mine??
Old 03-07-2006, 09:32 AM   #15
vicdeng
Member#: 53355
2002 02 WRX
WR Blue
I heard the JDM sti projector uses the H1 bulb, so i was thinking to buy the projector and the philips 4300k HID kit (H1 bulb) and just plug and play. so we have to modify the hole to fit the HID kit? correct me if i am wrong. thanks
vicdeng is offline   Reply With Quote
Old 03-07-2006, 10:15 AM   #16
file_id
Member#: 28197
2003 WRX w/ VF34
You have to drill a hole in the back of the cup. I used a dremel, a pilot drill bit, and a 1" hole saw. Came out a perfect circle.
Here is a picture of my old EDMs.
file_id is offline   Reply With Quote
Old 03-07-2006, 12:27 PM   #17
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
i just installed a set ofd hid's into an 06 wrx and did the same thing. i just used the drill bit used to drill the 1/2 holes. or something like that. i figured it was better to have to work the grommet in, than have it fit losely in there.
ATX25RS is offline   Reply With Quote
Old 03-07-2006, 07:19 PM   #18
vicdeng
Member#: 53355
2002 02 WRX
WR Blue
Do u have more pics? like the front, and the pic of the hole. thanks
Old 03-07-2006, 07:47 PM   #19
vicdeng
Member#: 53355
2002 02 WRX
WR Blue
and i am also curious, what's the blue and red wire head to?
Old 03-07-2006, 08:55 PM   #20
ATX25RS
Member#: 4597
the connectors for the hid bulb.
Old 03-07-2006, 10:03 PM   #21
vicdeng
Member#: 53355
2002 02 WRX
WR Blue
Because i previously owned a Scion, and i just switched to Projector and the hid kit is just plug and play, for this one, do u actually have the place that u can turn and lock ur connector onto the projector light...
bugeye jdm projector lens + housings w/ 2 free h1 halogen bulbs and h1 hid 6000k bulb fastwrx25 Exterior/Styling 23 06-28-2010 08:57 AM
FS: JDM STi Non-HID Bugeye Projectors Ryan314 Exterior/Styling 3 12-31-2009 09:54 AM
bugeye jdm projector lens + housings w/ 2 free h1 halogen bulbs and h1 hid 6000k bulb fastwrx25 SCIC Private Classifieds 7 12-01-2009 07:38 AM
FS: Driver's Side Bugeye JDM Projector, Non-HID 4bangers4life Exterior/Styling 15 12-06-2006 04:05 PM
Bugeye JDM projector beam pattern quesitons BuggeyEYED Newbies & FAQs 2 03-15-2006 05:01 AM
