Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 02-28-2006, 08:59 PM   #1
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Default Going Cobb Stage 2 w/ stock uppipe ok?
I'll be going cobb stage 2 on my 03 wrx next week and I'm going to have the stock uppipe on for probably a good 2-3 months before I can get to the uppipe install due to some complications...
you guys think I'll be ok?
Any one else run stock up pipe with cobb stg 2 with no probs?
Erexxx is offline   Reply With Quote
Old 02-28-2006, 09:02 PM   #2
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
gut it or get a new one.... once you increase boost, its going to get hot and blow chunks of metal into your turbo.....
spoolindc2 is offline   Reply With Quote
Old 02-28-2006, 09:05 PM   #3
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Besides, with the DP off you're halfway (OK 1/3) done changing the UP.
Might as well get a cheap gutted stocker or STi UP and swap them at the same time.
02WHITEDUB is offline   Reply With Quote
Old 02-28-2006, 09:42 PM   #4
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Yes, you'll most likely be OK with the stocker for a few months. I did my DP in August last year, and I have an UP waiting to go on as we speak. I've had no problems so far. Yes, your EGTs are going to increase with the accessport tuning because you'll be running slightly leaner, but this idea that after going Stage 2 your UP cat is suddenly just going to break down and destroy your turbo is sort of overblown.
If you can do the UP at the same time, its definitely recommended, and I wish I had done it that way. But if you can't, you'll most likely be fine. Just don't go too nuts.
J
thrasher is offline   Reply With Quote
Old 02-28-2006, 09:52 PM   #5
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
haha i definately wont go too nuts and i already have the turbo back installed just doing the reflash and dyno'ing next friday
Old 02-28-2006, 09:55 PM   #6
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Well...
What does Cobb's website say?
Therein lies your answer.
Old 02-28-2006, 10:00 PM   #7
23b_Rex
Member#: 79394
02 gda
wrb
+1... forreal
right there in the map notes it says uppipe and pulley are "within limits" of their maps....
within limits = it's not required
23b_Rex is offline   Reply With Quote
Old 02-28-2006, 11:27 PM   #8
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Yeah I know that but I hear all these people say get the catless up pipe or the higher EGT's from cobb stg 2 will cause your uppipe cat to melt and destroy your turbo...
so I just wanted to get peoples first hand experience
Old 02-28-2006, 11:32 PM   #9
Butt Dyno
Member#: 17301
is the "dark side"
So you trust Cobb to run your engine, but you don't trust their recommendations as to what parts you need in order to use their software?
Old 02-28-2006, 11:34 PM   #10
23b_Rex
Member#: 79394
02 gda
wrb
i've heard that happening with bovs... but not from high egts on cobb's stg2 mapping
Old 03-01-2006, 12:52 AM   #11
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
what are you talking about? I trust everything they have to say. THey say you can safely run an uppipe with the stage 2 but it's also not required.
I just wanted to know if other people were running stock uppipe on stage 2 and if they ran into any problems. That's it.
Old 03-01-2006, 07:45 AM   #12
Turbo20VJetta
Member#: 46004
05 Saabaru
Stage 2
No, it is not going to get hot and blow chunks of metal into your turbo....
It may do this, but it is a small chance. From what I have read, the chances are really not much greater than when the car is stock.
Turbo20VJetta is offline   Reply With Quote
Old 03-01-2006, 07:54 AM   #13
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
You keep hearing about it.I haven't seen anybody post about it though.
You can run without changing the uppipe if you want.
enewtabie is offline   Reply With Quote
Old 03-01-2006, 10:17 AM   #14
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
13.630@99.88 mph
<-- 33,000+ miles on Cobb stage 2 with OEM uppipe. No problems.
IndyRacer is offline   Reply With Quote
Old 03-01-2006, 10:25 AM   #15
JamesR
Member#: 87127
2013 MKVI Golf R
Hmm...this happened to you or someone you know?
JamesR is offline   Reply With Quote
Old 03-01-2006, 10:36 AM   #16
brex16
Member#: 78703
2004 WRB STi
YOU ARE FINE! thread closed. your uppipe wont break, if cobb thought they would break, then they would have required a catless uppipe.
brex16 is offline   Reply With Quote
Old 03-01-2006, 10:41 AM   #17
subieworx
Member#: 47769
In all the time I have spent here I have seen 1 or possibly two actual documented cases of the UP cat actually coming apart and getting sucked into the turbo. You are fine.
subieworx is offline   Reply With Quote
Old 03-01-2006, 10:47 AM   #18
JamesR
Member#: 87127
2013 MKVI Golf R
My thoughts exactly, this is not common. I am running stage 2 w/stock up and I don't have any problems. Too many urban legends floating around and people making comments about things they're not familiar with. I'm sure it can happen but it is rare, probably just as rare as it happening to a stock setup.
Old 03-01-2006, 10:58 AM   #19
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
I've seen the pictures... I've heard the stories...
you should def. get rid of it... it just makes logical sense...
it will not only increase your performance, but also the reliability.
Bundyboyz is offline   Reply With Quote
Old 03-01-2006, 11:10 AM   #20
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
...and I have seen none (not arguing with you subieworx). This is the most overblown issue I have seen on these boards.
You're fine.
HerculesPeanut is offline   Reply With Quote
Old 03-01-2006, 11:15 AM   #21
fatgroundhog
Member#: 44942
You're fine.
++++++111111111111111
fatgroundhog is offline   Reply With Quote
Old 03-01-2006, 12:31 PM   #22
Bundyboyz
Member#: 32764
2003 WRX with 91K
not the most overrated issue is installing an uppipe...
people think it's impossible or such a pain in the ass... but really it's cake...
I did mine myself with no lift...
get out the record book.... a stage 2 with catless uppipe will "rip-apart" a stage 2 with a factory uppipe.
Old 03-01-2006, 03:42 PM   #23
Sharky NRK
Member#: 29549
2003 WRX
I have done several uppipe installs and they are cake after the first one, just takes time if you doing it yourself to get under and over the car repeatedly. but get that uppipe out, that cat in there is the worst idea ever
Sharky NRK is offline   Reply With Quote
Old 03-01-2006, 04:52 PM   #24
JamesR
Member#: 87127
2013 MKVI Golf R
Please come and do mine for me, I'll supply the beer
Old 03-01-2006, 05:02 PM   #25
Paulie V
Member#: 10260
2002 WRX Sedan
PSM- Knock, knock :-(
To summarize what others have said and what I've seen:
Most (if not all) the uppipes that I've seen that have broken apart have been on cars with externally vented BOV- this includes one that was at a dealer getting a new turbo and uppipe
However,
When you do the DP, you're already halfway there to replacing the UP anyway, so it might not be a bad idea to get some quicker spool-up and neat sounds. I threw in my gutted stock UP the same time I did my DP and I think the most time-consuming part of the whole install was messing around with the heatshields for the DP and drilling and tapping my exhaust manifold for my EGT probe. Really, the UP isn't that big of a job, especially if you're doing a DP at the same time. Just remember- PB Blaster is your friend!
Paulie V is offline   Reply With Quote
going cobb stage 2...but still have stock midpipe on. SubNoob Engine Management & Tuning 6 01-21-2006 07:01 PM
Going Cobb Stage 2 and I have a question Agkelos Engine Management & Tuning 3 07-25-2005 03:54 PM
How many miles on your 'rex since going Cobb Stage 2? ScoobyNubieToo! Engine Management & Tuning 21 07-07-2005 02:13 PM
perrin turbo inlet hose installed-cobb stage 2 with headers, uppipe, pulley garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 03-01-2005 05:06 PM
cobb stage 2 the stock uppipe? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 09-05-2004 02:03 AM
