Old 03-01-2006, 04:48 AM   #1
alfo40
Member#: 108837
2002 Impreza STI 2.0
Grey
Default Spec C MY06 steering wheel on WRX/STI 02.. How?
Maybe someone can help me out on this. I recently got a brand new Spec C 2006 airbag steering wheel to install on my 02 STI that has a bigger one. Everything fits perfectly but wires and airbag/horn connectors are different. I've seen some store that sells the steering wheel as a kit saying that some cutting/soldering must be done. Anyone knows what goes where?
Thanks a lot for helping
Alfo
Italy
alfo40 is offline   Reply With Quote
Old 03-01-2006, 03:20 PM   #2
06suba
Member#: 105588
2006 2.5i
come stai alfo...
06suba is offline   Reply With Quote
Old 03-01-2006, 07:34 PM   #3
MINO
Member#: 12841
The horn should be plug and play. The length of wire is a little short for the newer wheel, but it'll reach.
As for the airbag.
Just swap the explosive (8mm nuts). The harness changed throughout the years but the bolt pattern has not. It's possible the explosive has gone through a design change for the different steering wheels though. When/if you do this. Remember it's comprimising your life and safety.
MINO is offline   Reply With Quote
Old 03-01-2006, 07:41 PM   #4
subaru222
Member#: 92967
01rs 13 impreza spt
everything should work the same
subaru222 is offline   Reply With Quote
Old 03-01-2006, 07:46 PM   #5
MINO
Member#: 12841
I've done this on a few cars.
It is not the same. The airbag harness is different.
Old 03-06-2006, 04:48 AM   #6
alfo40
Member#: 108837
Grey
Default Thank you!
As for the airbag.
I felt kind of stupid now that I've swapped the explosive and fit the all thing in 5 minutes! I thank you a lot for the suggestion also if that turned me nervous... I've been watching the damned thing for a week thinking about how to find the missing airbag plug instead of get 4 nuts loose and solve!
The good stuff is that now I have 3 friends stucked with the same problem and I'll be happy to gift them some "stupidity feeling" as well!!
Thank you
Alfo
Italy
Old 03-06-2006, 10:14 AM   #7
MINO
Member#: 12841
Glad to hear you got it in.
On my first try, I spent an hour trying to dissasemble the harnesses then noticed the bolt patterns were the same.
How To: Change a power steering pump on WRX/STi Gamble_WRX Service & Maintenance 23 04-06-2013 08:22 AM
HOW TO: Prova Steering Wheel 2008+ WRX/STI RallySport Direct NASIOC Project Cars 50 08-29-2012 07:37 PM
sparco steering wheel adapter wrx sti bootman Interior/Dressup/Audio & Security 1 07-07-2009 03:10 AM
2 STi spec c roof in WR Blue wrx, sti 02-05 subaruxtra.com Exterior/Styling 5 01-12-2005 12:55 AM
02 WRX steering wheel on 04 STI not plug and play kenchan Car Part Reviews 1 02-02-2004 11:40 AM
Message Board Statistics All times are GMT -4. The time now is 12:51 AM.
