Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 03-01-2006, 10:36 AM   #1
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
Question EJ20 Swap longevity?
I about this || close to pulling the trigger on an USDM EJ20 swap into my 2000 Legacy GT 5mt. The tranny is good, body and interior are nearly perfect, the rear diff and axle are good, and there is no rust underneath. I'd replace the suspension and probably the front axle when the swap is done, and definitely a new clutch too.
I only put ~12k miles on my car a year now, and although I'd probably add a few mods gradually after the swap, nothing crazy to put down huge power.
If I do this I'd be committing to the car long term -> 4-5 more years. Is this reasonable to assume on a swapped car assuming normal preventative maintenance?
Thanks in advance
:Steve
Rice & Gravy is online now   Reply With Quote
Old 03-01-2006, 11:15 AM   #2
Lachlan
Member#: 19470
1981 Brat GL
A full swap will last you longer than a modded engine since the swapped engine comes from the factory that way. I don't see why it wouldn't last as long as any other suby engine (long time)
Lachlan is offline   Reply With Quote
Old 03-01-2006, 11:56 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I tall depends on how the Ej20 was treated in it's former life. If it was stock and low miles, expect it to last as long as if it had stayed in the WRX. If it was tweaked and boosted hard, that's a whole nother story. But a swap is an OEM replacment and should be OEM reliable...
Old 03-01-2006, 05:22 PM   #4
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
Thanks guys, excellent points. Aside from what I've pointed out, anything preventative you would do at the time of the swap to help w/ longevity for the rest of the car?
Old 03-01-2006, 05:32 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
If you plan on a TBE exhaust and an ECUtek or Cobb reflash, a fresh clutch and pressure plate would be in order at the point of swapping. Also, a close inspection of things like cam seal, rear main and any other areas that might be leaking some oil would be in order...
Old 03-01-2006, 05:38 PM   #6
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
The clutch would be done. I would be getting the swap done by ECS and they include the choice of either Exedy or ACT disk as part of the parts/install.
Old 03-01-2006, 08:47 PM   #7
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
well, if they are doing it for you then just have them look over everything and make stuff sound. they have a good rep, so no worries for you.
swapstar is offline   Reply With Quote
Old 03-02-2006, 01:19 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Make sure to have a catless uppipe. Thats one of the few issues the USDM EJ20's have had, with the cat failing and getting sucked up into the turbo/engine causing issues... Better safe than sorry.
Old 03-02-2006, 11:57 AM   #9
Rice & Gravy
Member#: 39569
09 Acura TSX 6spd
Thanks. I had thought about that as well as a downpipe too to help with turbo lag and more low end.
Old 03-02-2006, 12:09 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
Also, make sure you get everything for the swap in advance. I have seen a couple of cars sit literally for a month or more while they shopped for a power steering reservoir and lines of all things. Buying a complete swap saves time and money...
EJ20 swap...keep A/C or can I use the swapped one? Gator GT Subaru Conversions 7 11-29-2004 03:05 PM
03 USDM EJ20 -> 97 JDM EJ20 swap marksWRX03 Subaru Conversions 10 06-09-2004 08:13 AM
EJ20 Swap? adeck Normally Aspirated with bolt-on Forced Induction Powertrain 11 09-21-2001 02:59 PM
('93-'01) those with completed EJ20 swaps Cool Hand Impreza Forum 6 08-14-2001 07:44 AM
EJ20 swap complete!!! 22B_WannaBe Normally Aspirated Powertrain 26 10-27-2000 02:21 PM
