Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-01-2006, 12:04 PM   #1
TurboRex
Member#: 8635
04 STI, 07 FXT
Default UTEC Knock Control
When will UTEC be upgrading the software so that you can determine how many knock counts are needed for the cel light to flash. I have forged pistons which make the cel flash false on 1 counts. I can lower knock sensitivity but I want more flexibility on tuning for knock.
I was told it would be upgraded by now for this issue.
Greg
TurboRex is offline   Reply With Quote
Old 03-01-2006, 12:39 PM   #2
x99percent
Member#: 27108
2004 STi
2004 A4
So... you want lower knock sensitivity, without lowering the UTEC's knock sensitivity?
Why would making the UTEC less sensitive *not* be a desirable option?
x99percent is offline   Reply With Quote
Old 03-01-2006, 01:40 PM   #3
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I don't know about the STi firmware, but the WRX UTEC has the capability in rev 5.0.
TypeC is offline   Reply With Quote
Old 03-01-2006, 02:38 PM   #4
TurboRex
Member#: 8635
04 STI, 07 FXT
When I first installed the UTEC, I had 1 counts everywhere with the stock knock sensitivity but never anything higher. I then lowered the sensitivity by 20 to get out the knock counts due to my forged pistons. I would prefer to keep knock sensitivity closer to stock levels and only pull timing on knock counts over 1 or even over 2 (which is what I told for the best tune). With the sti, you can't do this yet. I am wondering when it will be available. I was told last year it would around the first of this year.
Greg
Old 03-01-2006, 05:01 PM   #5
x99percent
Member#: 27108
2004 STi
2004 A4
Yes you can. It's been there from day 1 on the STi.
"Knock Count Threshold" under "Tuner Constants". Default is "1", you want 2 or 3.
Old 03-01-2006, 06:33 PM   #6
TurboRex
Member#: 8635
04 STI, 07 FXT
I meant you can change the knock count to a higher number to pull timing, etc. but the cel will still go on as long as their is a knock count of 1. I want to be able to adjust when the cel comes on.
Old 03-01-2006, 11:52 PM   #7
x99percent
Member#: 27108
2004 STi
2004 A4
That would require making your UTEC less sensitive to knock.
Why is that not a desireable option? Properly lowering the sensitivity would have the same effect as making your current "2" knock counts a "1".
Old 03-02-2006, 09:41 AM   #8
Division By Zero
Member#: 7555
Yep. That's correct! No problem with lowering the sensitivity but you got to know if it's real knock or not. Who's to say that the UTEC is right? It's only telling you what it thinks. If you've got the default knock sensitivity then that's a best case scenario and works for most cars. However, 99.5% will never tune their knock sensors. I am actually about to do just that myself.
Division By Zero is offline   Reply With Quote
Old 03-02-2006, 06:44 PM   #9
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
By a knocklite
Wombat North is offline   Reply With Quote
Old 03-02-2006, 08:33 PM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by Wombat North
By a knocklite
Good idea - something way dumber than the UTEC.
Jon [in CT] is offline   Reply With Quote
Old 03-02-2006, 09:32 PM   #11
Division By Zero
Member#: 7555
Yep! What the hell is a knock lite going to do It'll work bt STILL needs to be tuned.
Old 03-02-2006, 11:57 PM   #12
Wombat North
Member#: 21267
STI, EWG 8cm Green
Still see you don't like TurboXS.
Drive thru
Old 03-03-2006, 09:00 AM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
... best thing i ever did, imo.
Old 03-03-2006, 09:03 AM   #14
Division By Zero
Member#: 7555
Which device did you use on yours?
Old 03-03-2006, 09:34 AM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i used the tuner pro's built in knock sensor amp and included 2ndary knock sensor with a pair of headphones.
essentially i went +15 knock sens. across the board on all the rpm ranges in the utec, then made sure that when it went off there really wasn't knock occuring. if not, then i'd bring the sens. back a bit. when all was said and done they all hovered around +10 or so.
(edit: when i say +10, that is on top of the default values.)
Old 03-03-2006, 09:41 AM   #16
Division By Zero
Member#: 7555
Ken, so you made them more sensitive? By adding 10 to 85, for example would be more sensitive. I would've thought that the default settings would already be overly sensitive.
Old 03-03-2006, 10:02 AM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
maybe for folks with big old forged slugs in their engines... you might need to go less sensitive.
on the contrary i have found that the utec's default settings are on par with the oem ecu's sensitivity.
generally, when i DO get knock, the utec pulls timing and the oem ecu does not!
i should point out that i've set the threshold for the utec DOING something about the knock to a count of 2. the cel will flash at 1.
Old 03-03-2006, 10:23 AM   #18
Division By Zero
Member#: 7555
Okay I gotcha!
Old 03-03-2006, 10:26 AM   #19
TurboRex
Member#: 8635
04 STI, 07 FXT
ride, I am considering what you are doing as well. Pull timing at 2 counts and flash at 1. I just want to have the ABILITY to change the flash to 2 counts if I want. This option is already available with the wrx. I am anxious for the same flexibility. That is all I want.
So I guess no one knows if this mod will be forthcoming?
Greg
Old 03-03-2006, 10:29 AM   #20
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i know exactly what you mean greg. i found that noise sometimes popped up at a 1 count, and when knock actually occured it was well above a 2 count... like 5 and up. i wish i could give you an answer.
Old 03-03-2006, 08:11 PM   #21
Davenow
Member#: 23676
Greg
I dont know what revision you are running, but on my 05 STI with a UTEC, I have the sensativity adjusted AND I have it set to only care about 2 counts or higher.
This has been the case the entire time I owned it.
I have it adjusted WAY more sensative than the way it comes, and I have it set up to ignore 1 counts.
I also have it set up to pull 4 degrees at a time, and pull up to 16 degrees total. I am running alch injection, and in case of any problems, I want that timing YANKED back hard. It works very well too.
Old 03-03-2006, 08:25 PM   #22
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
the point is that he wants to divorce the utec's view of knock, and its response of pulling timing, from what he is presented through the CEL-flash. having the knocklite would allow him to do just that: leave his UTEC desensitized, but see the purdy amber light flash at a different threshold.
shikataganai is offline   Reply With Quote
UTEC boost control, or UTEC combined with Profec B...advice needed... gills UTEC 9 04-01-2006 04:39 PM
UTEC Knock Sensitivity Settings AaronC Engine Management & Tuning 1 06-24-2003 05:00 PM
UTEC knock correction Big Turkey Engine Management & Tuning 30 05-15-2003 08:29 AM
UTEC Boost control as good or better than other boost controllers? DocDetroit Engine Management & Tuning 0 02-04-2003 09:40 PM
Utec knock mikaust Engine Management & Tuning 3 12-01-2002 07:53 PM
