Old 03-01-2006, 07:34 PM   #1
snowjob
Member#: 59357
2009 Forester XT
Default Help with Forester To RS Cluster Swap, wiring help needed?
Pics Below
snowjob is offline   Reply With Quote
Old 03-01-2006, 07:55 PM   #2
Slack
Member#: 17548
Pm'd you.
Mick
Slack is offline   Reply With Quote
Old 03-01-2006, 09:57 PM   #3
bryan_johnson
Member#: 78987
I'd appreciate a copy of that too, if its not too much trouble.
bryan_johnson is offline   Reply With Quote
Old 03-02-2006, 12:10 AM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
let me know if you need it.. I can take a couple pics of my wiring diagram if you guys need it.
subbyspeed is offline   Reply With Quote
Old 03-02-2006, 10:37 AM   #5
snowjob
Member#: 59357
2009 Forester XT
Slack is the Man, Thanks
Frazer
Old 03-02-2006, 11:07 PM   #6
Slack
Member#: 17548
Did those files help you complete the wiring?
Mick
Old 03-02-2006, 11:17 PM   #7
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
not to thread jack, but what about putting a jdm sti ver7 cluster into a 2000 rs? Would I have to change the wiring, or would it plug right in?
subydude is offline   Reply With Quote
Old 03-02-2006, 11:43 PM   #8
JDM_Scobaru
Member#: 57809
I would like to know that to!
Zach
JDM_Scobaru is offline   Reply With Quote
Old 03-03-2006, 12:00 AM   #9
Slack
Member#: 17548
subydude and Zach- Check this out for info!
Mick
Old 03-03-2006, 12:09 AM   #10
subydude
Member#: 80649
I'll probably try to do that. I'm actually in the process of swaping a ver7 sti engine in, hence using the ver7 cluster to match. Maybe over the weekend I'll try it. Might even try fitting the guage bezel from the wrx onto the rs just to see if I'd have to trim it.
Old 03-04-2006, 11:25 AM   #11
snowjob
Member#: 59357
2009 Forester XT
Hey Mick, yes they did help, everything seems pretty strait forward, except for the tack signal from the speed sensor. On the rs it gets two wires to the tack, on the forester only 1, I'll post the diagrams up later today and show you what I mean.
Old 03-06-2006, 01:13 PM   #12
snowjob
Member#: 59357
2009 Forester XT
Ok, I'm don't have a scanner to put the 1998 Forester Cluster diagram up, but here is the RS diagram and the comparison of pins I've made. Everything is pretty simple, except the Vehicle Speed Sensor, on the forester it has two wires, on the rs it has 1, I'm a bit confused, if anyone has any insight, can you please enlighten me.
Thanks
Frazer
http://i11.photobucket.com/albums/a1...wappinouts.jpg
http://i11.photobucket.com/albums/a1...sterpinout.jpg
Old 03-06-2006, 01:26 PM   #13
subydude
Member#: 80649
They're just a little to small to read I'm interested in the rs cluster pinout if you have a link that
Old 03-06-2006, 02:37 PM   #14
snowjob
Member#: 59357
2009 Forester XT
Default New pics added
my bad, I can't get these to resize properly, grrr. Subydude, pm me your email and I'll email you the pdf doc.
If anyone else has any insite, I can email you my documents and you can help from there.
Thanks
Frazer
Old 03-06-2006, 02:58 PM   #15
subydude
Member#: 80649
Just sent you the PM
Old 03-09-2006, 12:31 PM   #16
snowjob
Member#: 59357
2009 Forester XT
OK, we're off to the races, can someone help me with identifying where I need to go from here, compare the two documents and what i"ve got.
Thanks
Old 03-10-2006, 09:01 AM   #17
snowjob
Member#: 59357
2009 Forester XT
anyone, I've got pictures and everything......
Old 04-09-2006, 10:08 PM   #18
FF2
Member#: 63453
1998 Impreza 2.5RS
You know, I'm doing almost the same thing (STI Ver5/6 cluster into my 98 2.5RS). Here's the pinouts that I've written down:
Cluster Function---------98 2.5RS----2000 2.5RS
ABS light--------------------C6-----------A5
Airbag Light------------------B7-----------B14
AT Oil Temp-----------------C3-----------A2
Battery Charge--------------A12-----------C17
Check Engine Light-----------A8-----------C18
Clock------------------------B1-----------B8
Common GND----------------C10-----------A10
Fuel gauge to ECU-----------C2-----------A8
FWD (TCM)------------------C5-----------A4
GROUND---------------------B2-----------C13
Hi-Beam 1-------------------A5-----------C1
Hi-Beam 2-------------------A6-----------C2
Hold (TCM)------------------C7-----------A3
Illumination GND-------------C1-----------C3
Illumination Light------------A13-----------C4
Left door switch------------B10-----------B5
Left Turn Signal-------------B3-----------B13
Lo (AWD) switch------------C9-----------A7
Oil Pressure Light------------A9-----------C14
Parking Brake & Fluid light----A11-----------C6
POWER - Fusebox 23 no2----B8-----------C8
Power (TCM)----------------C8-----------A6
POWER +12VDC-------------B6-----------C7
Right door switch-----------B9-----------B6
Right Turn Signal------------A9-----------B15
Seat Belt light--------------B5-----------B7
Tach----------------------A10-----------C9
TCM & ECM----------------C12-----------A1
Temp Gauge---------------C11-----------A9
POWER - FB-21 (no9 - clock)----C13-----------N/C
Low Fuel Warning light----------C4-----------N/C
Speed sensor 2-1---------------A1-----------N/C
Speed sensor 2-2---------------A3-----------N/C
TCM----------------------------A2-----------C10
The problem lies within the speed sensor. In the 99-2001 2.5RS, the 2nd speed sensor is tied to the transmission control module before it is sent to the cluster. On the 98 2.5RS, the speed sensor is tied directly to the cluster. Also the low fuel warning light is tied into the fuel gauge circuit on the 99-2001 cluster. Hope this helps you out.
FF2 is offline   Reply With Quote
Old 04-09-2006, 11:05 PM   #19
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
TCM should only be for automatics.
Pin 1 (GY) goes to c10 on the i12 connector
Pin 3 (GB) goes to c7 on the i12 connector
Pin 2 is your power wire for the VSS
This is for a 2000/2001 RS 5mt.
Pin1,2,3 correspond to the VSS for a manual tranny
Old 04-09-2006, 11:54 PM   #20
FF2
Member#: 63453
1998 Impreza 2.5RS
Subbyspeed, is your reply for me or for snowjob?
Old 04-10-2006, 10:28 AM   #21
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Its just an FYI for whoever needs the 2000-2001 RS info.
Old 04-16-2006, 01:06 PM   #22
snowjob
Member#: 59357
2009 Forester XT
My pins look different from yours because I'm doing it from a forester, basically the same idea though. How is yours coming along?
Old 02-05-2009, 01:43 AM   #23
EvenSteven
Member#: 156542
I fixed that thing up a little bit better. I added the colors of the wires. I just forgot to get the colors for A1, A2, and A3 before i pulled my wires out. If anybody knows that info that would be cool.
TCM & ECM----------------C12----------------------------A1
AT Oil Temp-----------------C3---------------------------A2
Hold (TCM)------------------C7---------------------------A3
FWD (TCM)------------------C5----------Yel/Red---------A4
ABS light--------------------C6-------Lt GRN/Yel---------A5
Power (TCM)----------------C8----------pink-----------A6
Lo (AWD) switch------------C9----------WHT/BLK-----------A7
Fuel gauge to ECU-----------C2---------BRN/WHT-------A8
Temp Gauge---------------C11-----WHT/GRN------------A9
Common GND----------------C10------BLK/RED---------A10
Left door switch------------B10-----------BLU/WHT-------B5
Right door switch-----------B9----------YEL----------------B6
Seat Belt light--------------B5----------------BLK/BLU-----B7
Clock------------------------B1---------------YEL/BLK------B8
Left Turn Signal-------------B3------------BLK/GRN------B13
Airbag Light------------------B7-----------GRN/RED-------B14
Right Turn Signal------------A9---------LT GRN/BLK------B15
Hi-Beam 1-------------------A5--------------BLU/WHT------C1
Hi-Beam 2-------------------A6--------------------RED------C2
Illumination GND-------------C1---------------YEL/BLU-----C3
Illumination Light------------A13--------------WHT/YEL-----C4
Parking Brake & Fluid light----A11-----------BLU/RED------C6
POWER +12VDC-------------B6---------------GRN/BLK------C7
POWER - Fusebox 23 no2----B8--------------BLU/RED------C8
Tach----------------------A10------------------BLU/GRN-----C9
TCM----------------------------A2-------------GRN/YEL------C10
GROUND---------------------B2--------------------BLK------C13
Oil Pressure Light------------A9--------------GRN/WHT-----C14
Battery Charge--------------A12-------------BLK/WHT------C17
Check Engine Light-----------A8--------------RED/WHT-----C18
EvenSteven is offline   Reply With Quote
Old 08-02-2010, 05:27 PM   #24
riffraff
Member#: 244244
1995 impreza
primer black
where would a1 be at on the connector which connector is a,b,c sorry for thread jacking
riffraff is offline   Reply With Quote
Does anyone have a USDM 2006 STI ECU pinout diagram? FleaDog Engine Management & Tuning 3 05-11-2010 04:08 PM
wtb rs gc8 cluster harness 99 to 01 Rdwrc Private 'Wanted' Classifieds 2 03-20-2007 10:22 PM
2000 RS GC8 suspension options 92XJET Brakes, Steering & Suspension 3 11-14-2006 01:09 AM
Anyone have pix of the Gauge Cluster surround gauge pods? BrysImpreza Interior & Exterior Modification 22 09-26-2004 01:11 AM
Anyone have a diagram for the ECU Pinout on the FXT? BrysImpreza Forester Forum 0 01-25-2004 07:26 PM
