Old 03-01-2006, 07:21 PM   #1
JM530
Member#: 69212
'11 A3 Quattro K04
DSG Lava Grey
Default Winter vs. "normal" Gas
Do you need to get retuned in the spring/summer if you get tuned in the winter in areas that use "winter" gas????
JM530 is offline   Reply With Quote
Old 03-01-2006, 10:01 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Not so much for the winter gas, but also for the winter temps. If you have a normal tune, unles you have obvious issues, no. If you have a 10/10ths, to the edge race gas/WI OMFGBBQ tune, then yes, you need a summer and winter tune.
Old 03-01-2006, 10:32 PM   #3
JM530
Member#: 69212
'11 A3 Quattro K04
DSG Lava Grey
Thank you, sir.
Old 04-20-2006, 12:19 PM   #4
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
so what's the difference between the two?
Bishop is offline   Reply With Quote
Old 04-20-2006, 12:39 PM   #5
sb427f-car
Member#: 93766
2005 Busted WRX
Thanks to being rearended
Mainly the timing and fueling between the two tunes due to the colder denser air in the winter. In the summer, you're going to have increased det. res. due to more humid weather (at least on the EAST coast), which means that's actually less oxygen in the air for the motor to interact with the fuel. The summer blends of fuel (which is now @least 10% ethonal in every state, Maryland I learned last night is 15%) is the oxygenator in the fuel for the summer. The reaction upon burn provides more oxy as there is more of that in the chemical string. Basically it's for emissions more than anything else, to make sure that the fuel is burned in the CC rather in the tailpipe during the summer.
sb427f-car is offline   Reply With Quote
Old 04-20-2006, 03:08 PM   #6
CynicX
Member#: 48199
06 WRX
The vapor pressure. Different chemical compounds change this so your car will supposedly run better in that particular season. So they cant use a light compound in the summer because it will evaporate too fast, or cause vapor lock. And they cant use a compound to heavy in the winter because the fuel wont vaporize properly and cause lean mixtures and hard starting etc etc. So they change the compounds per seasons....
I believe methyl tertiary butyl ether is the chemical that plays the major difference between summer and winter gas. I believe there is a good size list that go along with that but I think methyl tertiary butyl ether is at the top of that list......
I imagine warmer or colder climates dont even change there gas? I dunno.
You shouldnt have to tune around this in my opinion unless you have an all out race only car. But I'm running an OTS tune so what do I know
CynicX is offline   Reply With Quote
Old 04-20-2006, 03:51 PM   #7
sb427f-car
Member#: 93766
2005 Busted WRX
well...MTBE was it until it just went bah-bye.
Old 04-20-2006, 04:04 PM   #8
Bishop
Member#: 59993
Ass, grass or cash
thx guys. make a lil more sense now.
Old 04-20-2006, 04:43 PM   #9
CynicX
Member#: 48199
06 WRX
last time I wanted to know the difference was YEEEEAAARRRRSSSS ago. What is with the MTBE going bah-bye?
Old 04-20-2006, 07:13 PM   #10
ejsportcom
Member#: 88905
i live in NJ and the fuel is 10% ethonal all year round...
ejsportcom is offline   Reply With Quote
Old 04-20-2006, 08:20 PM   #11
sb427f-car
Member#: 93766
2005 Busted WRX
It's a carcinogen. It leaches into the ground water and you can't get it out.
track times, winter vs. summer stirob Texas Impreza Club Forum -- TXIC 3 06-21-2006 03:16 PM
JDM STi V3 vs. "normal" WRX clutch/flywheel mykrrrr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-03-2004 06:17 PM
winter vs. summer setup in snow? wagonman Tire & Wheel 5 02-21-2004 09:09 PM
winter vs tein HA Turbo Tin Can Brakes, Steering & Suspension 1 11-21-2002 06:39 PM
xpost- winter vs coilovers dmg? Turbo Tin Can Canada Region Forum 0 11-21-2002 04:47 PM
