Old 03-01-2006, 08:36 PM   #1
wit2003
Member#: 104395
2007 Element/99 GMC
1500/87MC-SS/00 Mirage
Question 06 WRX remote starter
Anyone install a remote starter in their 06 WRX? If so howd you do it? Neutral safety switch, relays, etc. What did you do?
wit2003 is offline   Reply With Quote
Old 03-01-2006, 08:46 PM   #2
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
Ill be doing a compustar 2way piece on saturday in a fellow members 06 and will be taking pics. Ill only be posting them if he give me the OK(deing an alarm and everything ).
audio1der is offline   Reply With Quote
Old 03-01-2006, 08:49 PM   #3
wit2003
Member#: 104395
2007 Element/99 GMC
North attleboro huh......im over in waltham.....yea if you could take pics and document everything I would greatly appreciate it.....im doing the alarm/starter combo..audiovox APS997
Old 03-01-2006, 09:01 PM   #4
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
Damn Didnt even look where you were LOL Ill take pics and Ill ask the car owner how he feels about it...actually Ill give the pics to him to show.
Old 03-01-2006, 09:10 PM   #5
toekneeyo
Member#: 97884
06 WRX_vf39
06 X5 Black
can u guys tell me what it is you are talking about?
i just came because it said 06 WRX
toekneeyo is offline   Reply With Quote
Old 03-01-2006, 09:13 PM   #6
wit2003
Member#: 104395
2007 Element/99 GMC
this is about installing an alarm/remote start combo in an 06 WRX.
Old 03-02-2006, 08:39 AM   #7
davisk6
Member#: 57396
2013 BRZ
Yup, it's my car. We'll post them when after the install this weekend.
davisk6 is offline   Reply With Quote
Old 03-02-2006, 12:58 PM   #8
toekneeyo
Member#: 97884
06 WRX_vf39
06 X5 Black
sweet iheard about this set up. pretty pricey...
Old 03-02-2006, 01:09 PM   #9
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
Nice, I can't wait to see the install. One question though, Is the car a manual or auto? I have never used a remote start on a manual car.
MFR Sweep is offline   Reply With Quote
Old 03-02-2006, 01:16 PM   #10
wit2003
Member#: 104395
2007 Element/99 GMC
im guessing its a manual as doing a remote start in an automatic is fairly straight forward....
Old 03-02-2006, 08:27 PM   #11
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
Yep, Its a stick. Ill try to get as many pics as possible. I usually get into a zone when working and might forget a few connections (pics of them that is )
Old 03-02-2006, 09:46 PM   #12
NutBucket
Member#: 90804
'11 CR-Z
'05 GGA, '12 Acadia
The manual trans have neutral switches on them for cruise control purposes. I see no reason you couldn't tap into that.
NutBucket is offline   Reply With Quote
Old 03-03-2006, 12:27 AM   #13
Mystic
Member#: 89826
05 STI
some blue color
if any one needs any help with installing or needs one put in drop me a PM .. i live on the south shore and work at a shop ...i have done few 5 speeds and they work great....
Mass that is
Mystic is offline   Reply With Quote
Old 03-03-2006, 12:48 AM   #14
littlewhitewagon
Member#: 103068
11 STI sedan
Doing a 5 speed isn't hard. Use the neutral safety switch from the transmission to be your safety so it doesn't drive away and a relay activated by the start signal (isolated) to bypass the clutch safety.
Here is something you have not thought about...what are you going to do about the transponder in the key? Make sure you have the module or bypass it somehow, if not you will not get a sucessful start. Test to see if the transponder is present by cutting a regular key, remove all factory keys from the vicinity of the vehicle and attempt to start the car with the copy key without transponder.
littlewhitewagon is offline   Reply With Quote
Old 03-03-2006, 03:06 AM   #15
vipernj
Member#: 86854
2004 fx35 02 Z06
the 06's are the same as the other MY imprezas. the NPS is green/white at the ECU. You need a relay to switch from + to - and tie it into the black/white neutral safety switch on the aftermarkeyt unit (assuming that you are going DEI). Its very straight forward, very simple, just like any other RS install, just with an additional relay.
vipernj is offline   Reply With Quote
Old 03-03-2006, 03:07 AM   #16
vipernj
Member#: 86854
2004 fx35 02 Z06
nope, you dont need a relay to bypass the clutch. Just use the BLUE (status output (-)) trigger from the remote start with a diode straight to the clutch wire which is GREEN/YELLOW. No need for a relay.You also need a DEI 556UW for the immobilizer
Old 03-05-2006, 11:42 AM   #17
davisk6
Member#: 57396
2013 BRZ
So, I got the Compustar Remote Starter+Security installed yesterday and it's fantastic. audio1der did a great job! In some ways, there are too many options on this system, but I'm very pleased.
Old 03-05-2006, 03:31 PM   #18
wit2003
Member#: 104395
2007 Element/99 GMC
can you PM me or email me a quick write up for this...or even just post it....i got all my parts and am waiting to get it all in....Thanks
Old 03-05-2006, 04:27 PM   #19
netZ
Member#: 5743
2007 Kia Optima
gold brick
Not really... 2002 - 2004 impreza's, the NPS (Neutral Position Switch) throws ground when the vehicle is in gear. 2005+ impreza's, the NPS throws ground in neutral.
For the 2005+ impreza's you can do the following... if you want to detect the vehicle in neutral only... tap the vehicle's NPS wire to the NSS (Neutral Safety Sense) input off the DEI unit.
If you want to detect the vehicle in gear, wire the NPS wire to the brake input (you will need to diode isolate the NPS wire to the brake input to prevent voltage feedback to the vehicle's ECU and diode isolate the vehicle's brake wire to the brake input to prevent the brake lights from being turned on when the vehicle is in gear) off the DEI unit.
The 2nd option allows the DEI unit's NSS wire free to be wired up to the vehicle's parking brake.
Also... the NPS doesn't have enough current to trigger a 12 volt bosch type relay. a low voltage triggered relay will be needed if this option is so desired.
thanks!
netZ
netZ is offline   Reply With Quote
Old 03-05-2006, 09:06 PM   #20
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
Did a compustar 2 way combo on saturday. Finished product (other than the led) I have pics of 90% of the wires, might to a small write up MIGHT.
Old 03-06-2006, 12:16 PM   #21
davisk6
Member#: 57396
2013 BRZ
Also, for all those looking to do this. 06 Imprezas Have Chips in the Keys. I had to lose a key for this install. So be forwarned.
Old 03-09-2006, 04:46 PM   #22
Black-Falcon
Member#: 106318
11 Zoom Zoom3
Why exactly did you have to lose a key for it to work? For remote start you mean? (To tell the car its okay to start right?)
Black-Falcon is offline   Reply With Quote
Old 03-09-2006, 05:16 PM   #23
wit2003
Member#: 104395
2007 Element/99 GMC
There is an imobilizer chip in the key, and without this chip the car WILL NOT start....therefore with the imobilizer module(little black box that houses the extra key+ some circuitry) that extra key "talks" with the ignition and starts.......its a security feature....
Old 03-18-2006, 05:45 PM   #24
wit2003
Member#: 104395
2007 Element/99 GMC
So does anyone know what wire it is for the 06 neutral safety switch....i've heard there is and there isnt....gonna be doing the install this week coming and would be nice to know......Thanks all
Old 03-18-2006, 07:14 PM   #25
hornyturbo
Member#: 108618
2010 10 RX350, 04 A4
12 IS350, 08 STI
good info here, as i will be installing my Alpine 791VX next weekend
hornyturbo is offline   Reply With Quote
WRX remote starter by Subaru - anyone installed? WRXFiles Canada Region Forum 39 03-06-2007 01:54 AM
06 WRX remote on a 02 WRX? vicdeng Car Audio, Video & Security 0 01-03-2007 01:22 AM
Can a remote starter ruin the starter motor? Please Help! big67 Car Audio, Video & Security 4 12-21-2005 09:15 AM
Remote Starter for MT WRX? bcblues Car Audio, Video & Security 28 08-26-2002 09:25 AM
Remote starter for a 5 speed RS & Factory or Aftermarket Alarm WRX-1977 New England Impreza Club Forum -- NESIC 3 12-20-2000 05:37 PM
Message Board Statistics All times are GMT -4. The time now is 06:02 AM.
