Old 08-26-2008, 08:54 PM   #251
Z-GhostRex
Member#: 153430
07 WRX
Urban Grey Metallic
Originally Posted by cincyrider View Post
Found a promo code for Stylin'Motors. 30% off any order through Labor day.
The code is NASIOC.
Thanks for the info, just ordered the pieces I needed for my install.
Z-GhostRex is offline   Reply With Quote
Old 09-05-2008, 08:03 AM   #252
TheAnser
Member#: 84045
2015 WRX Base 6M
LR
Originally Posted by penusai View Post
Does anyone know the size of the silicone hose in the middle of the picture? I will be ordering the styling motors kit, but it doesn't appear that this hose comes with the kit; unless you just use some that you cut off the elbow?
Due to poor planning my STI top mount will not be going on this weekend...along with two other projects that were supposed to happen this weekend...**** it!
TheAnser is online now   Reply With Quote
Old 09-05-2008, 09:42 AM   #253
cincyrider
Member#: 95026
I believe it is the same size as the elbow, but don't think you will have enough to use from it. the elbow is 2.00" ID.
cincyrider is offline   Reply With Quote
Old 09-05-2008, 10:48 AM   #254
TheAnser
Member#: 84045
2015 WRX Base 6M
LR
Thanks Cincy!
Old 09-09-2008, 01:47 PM   #255
2002Dubx
Member#: 177337
1 Dirty Old
Bugeye and an Xterra
Can anybody let me know where I can find the stock passenger side tmic bracket, or even the set of all brackets? I've been searching the web and I can't find jack!
2002Dubx is offline   Reply With Quote
Old 09-09-2008, 09:16 PM   #256
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Best thing is to find brackets through nasioc.com members. Try wanted section.
Old 09-13-2008, 05:16 PM   #257
Tucker587
Member#: 178695
2007 Subaru WRX TR
Garnet Red Pearl
Default Air Splitter
I have a 07 WRX and i recently purchased the USDM STI IC. I still have the stock hood scoop, so does that mean I will have to buy an STI hood scoop just so that the USDM air splitter will fit, or will the JDM version fit on a stock wrx hood scoop?
Tucker587 is offline   Reply With Quote
Old 09-13-2008, 06:27 PM   #258
BIGSKYWRX
Member#: 7958
09 GH B+
I'm pretty sure on the 06/07's they didn't change hood scoops between the two models like previous years, I'm sure someone will chime to in to confirm
if that is true you need just the splitter/bellows and your good to go
Old 09-14-2008, 04:33 PM   #259
eb_rat_7
Member#: 106910
2012 WRX SWP HATCH
C6 ZO6 track toy
06/07 wrx and sti use the same hood scoop.
can anyone confirm that the elbow on the y pipe (sti) will work fine on a vf39 swapped 06 wx? is it the outlet of the td04 vs the vf39 that makes that pipe not work on a stock turbo wrx?
thanks
eb_rat_7 is offline   Reply With Quote
Old 09-14-2008, 06:17 PM   #260
BIGSKYWRX
Member#: 7958
09 GH B+
at least on the 02-05's it's more of the fact that the STi is designed to sit more rearward (throttle cable vs throttle by wire)- when mounted on unchanged brackets it sits further back- thus the need for a longer 90m also a longer TB hose
are 06/07 WRX's throttle by wire as well?
Old 09-14-2008, 06:59 PM   #261
eb_rat_7
Member#: 106910
2012 WRX SWP HATCH
C6 ZO6 track toy
06/07 have drive by wire so the ic to throttle body length is the same. i'm just worried about the elbow from y pipe to vf39.
Old 09-14-2008, 07:28 PM   #262
BIGSKYWRX
Member#: 7958
09 GH B+
if the TB distance is the same I'd have to imagine the distance from the elbow to the turbo would be the same as well
Old 10-22-2008, 11:53 AM   #263
dvsone775
Member#: 192309
2004 WRX
Default USDM STi TMIC
I ordered a USDM STi TMIC (going on a 2004 WRX) and it should be arriving in the next week or so but which splitter is best suited for that application/upgrade? Are there any tips on approaching the install and should I be aware of any problems once I begin the install?
dvsone775 is offline   Reply With Quote
Old 12-28-2008, 04:18 AM   #264
bdon22
Member#: 113940
2006 WRX
Steel Grey Metallic
So to make the STI IC core work on an 06-07 WRX re-using their stock y-pipe you need to... ???
bdon22 is offline   Reply With Quote
Old 06-04-2009, 02:27 AM   #265
Jackie
Member#: 81608
Bringing this up from the dead because I'm confused.
I have an STi TMIC coming with the Y-pipe, but not the 90 degree elbow.
I have a Prodrive silicone Y-pipe on my WRX already.
What do I need to make the STi TMIC fit?
Jackie is offline   Reply With Quote
Old 06-04-2009, 10:53 AM   #266
BIGSKYWRX
Member#: 7958
09 GH B+
you can purchase the 90 and the extended manifold/ic hose as a kit
here's one place (there are others as well)
http://www.stylinmotors.com/subaru.html
Old 06-04-2009, 09:07 PM   #267
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
jackie,
sell the prodrive Y-pipe. I cut mine and it still wasn't long enough. Search my name in the car part review section for a 90 degree hose that fits perfectly.
scoobystas is offline   Reply With Quote
Old 06-28-2009, 10:36 PM   #268
Ryan314
Member#: 82989
Hybrid VF22
I've been reading this entire thread trying to figure everything out... I have one question. Since the stock WRX hosing is a inch short, can't you just buy an 04-05 STi Samco intercooler hose kit to properly install the USDM STi IC without any modifications or hose extending?
Ryan314 is offline   Reply With Quote
Old 06-28-2009, 11:34 PM   #269
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
Last I checked, the only hose kits Samco made for intercoolers were for WRXs only. The STIs come with "high flow" y-pipes already, so there is no need to upgrade it to a silicone one, whereas the WRX came with the restrictive corrugated one. So, in essence your thought might be right, except the parts dont exist as far as I know. This is why everyone uses either the stock STI y-pipe, the aftermarket two piece y-pipe kit, or cuts and lengthens the WRX silicone version.
I had the cut and lengthened silicone y-pipe hose, but split it open. So, I just bought the one piece OEM y-pipe and gaskets brand new for $70. Im going to give that a shot. I already have about 3 different TB couplers and 90 hoses floating around here, so Im sure I can make a combo that works.
As for the hood scoop, splitter, and seal, I need to come up with something for that. I, like others, ran the STI intercooler with the WRX scoop, splitter, and seal, and noticed pretty warm IC temps.
~T.J.
02CWRX is offline   Reply With Quote
Old 06-29-2009, 12:03 AM   #270
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
Also, this seems like a good place to post it...
I was looking for some of those replacement clips that hold the rubber to the splitter since a few of mine were broken when I bought the car, and I didnt want to pay over $1 each at the dealer.
I managed to find a very close replacement at a local Napa just by chance (the first place I looked before the body shop supply store). Theyre made for a Nissan apparently, but work perfect for this as far as I can tell. Found them in the auto body replacement stuff. Not all Napas have this area I have found though. My local store had JUST added the section. They had a few choices, but most were wrong in one way or another (I went through the whole section for anything close). These are the closest I could find to the correct clip. A key point here is the fact they are a "closed" clip like the OEM clips. This means that after the clip is installed, it will still hold pressure on either side of the holes to keep itself centered and hold the seal tight. Some of the other "arrow" clips you can find are open once the tip of the "arrow" goes through. That means the clip has a lot of side to side movement after installation, and doesnt hold the seal well.
Anyway, theyre slightly longer than the OEM clips, but I used them in all locations on my OEM WRX splitter on my 02 with no problems. They look factory with almost the same texture as OEM even, and hold strong. All the holes on the 02 splitter are through holes (nothing behind them to hit), so the extra length doesnt seem to matter. I bought a bag of 25 of them for about $5 I think it was. Just thought I would pass on some helpful info.
~T.J.
Picture Of Clips
Clips Installed
Picture of the bag (with PN 665-2439)
Old 06-29-2009, 08:53 AM   #271
Ryan314
Member#: 82989
Hybrid VF22
~T.J.
So this kit by Samco for the 04-05 STi won't work with the STi IC in a WRX?
http://www.rallysportdirect.com/shop...it-p-2469.html
Old 06-29-2009, 10:19 AM   #272
BIGSKYWRX
Member#: 7958
09 GH B+
no- the STi has no fitment issue w/ it's own intercooler, the WRX does
Old 06-29-2009, 11:52 AM   #273
flukewrx
Member#: 75081
2003 WRX
5. WRX splitter and seal won't align correctly!
Solution: order air splitter and seal kit from rally spec
RST-9085kit Air Splitter & Seal Kit MY02-03 $84
http://www.rallispec.com/
Thanks for that link. I think I may have to get the air splitter and seal kit from there because that is much cheaper than I was looking at getting the JDM splitter for.
flukewrx is offline   Reply With Quote
Old 07-10-2009, 01:29 AM   #274
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
Interesting. As I said, I didnt know that existed. Although, for the price, I would still just buy the OEM one piece y-pipe for $70 and go that route.
As far as fitment goes, Im not sure if that would work or not. Essentially you would still have the elbow in the wrong place I would think... The same as if you had the STi factory y-pipe and elbow.
~T.J.
Old 07-20-2009, 09:27 PM   #275
Mehdik
Member#: 215392
just trying to get some confirmation on this. I have an 06 WRX looking at a 07 USDM STI intercooler. I understand all the hose stuff just confused about the hoodscoop/spliter/seal. Do i just order the air splitter off rallispec? RST-9087kit WRX MY'06-'07 (Ver.9) $138.
Mehdik is offline   Reply With Quote
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
