Old 07-20-2009, 10:25 PM   #276
eb_rat_7
Member#: 106910
2016 GTI
C6 ZO6 track toy
Originally Posted by Mehdik View Post
just trying to get some confirmation on this. I have an 06 WRX looking at a 07 USDM STI intercooler. I understand all the hose stuff just confused about the hoodscoop/spliter/seal. Do i just order the air splitter off rallispec? RST-9087kit WRX MY'06-'07 (Ver.9) $138.
correct- the 06/07 wrx and sti have the same scoop. just get the 06/07 sti splitter/bellows and you'lll be good to go.
eb_rat_7 is offline   Reply With Quote
Old 07-20-2009, 10:41 PM   #277
Ryan314
Member#: 82989
Hybrid EJ257
I've got an 02 WRX with an 04-05 STi style hood scoop. Which splitter/seal kit do I need from Rallispec?
Ryan314 is offline   Reply With Quote
Old 07-21-2009, 11:10 AM   #278
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
you'll need the version 8 splitter and shroud if your scoop is 04-05. Check with them if they have them in stock. Their site is not does not actually list if they have the products in house.
scoobystas is offline   Reply With Quote
Old 07-21-2009, 01:34 PM   #279
allday789
Member#: 95511
2005 WRX
Does any body know the part number for the usdm v8 splitter/seal kit? Is it RST-9086kit or is that the jdm v8? Is there a difference between jdm and usdm v8 splitter/seals?
allday789 is offline   Reply With Quote
Old 07-21-2009, 01:43 PM   #280
allday789
Member#: 95511
2005 WRX
I had a couple of other questions.
1. is the 05 wrx hood scoop taller than the 06/07 wrx and sti hood scoop?
2. Is the 04-05 sti splitter taller than the 06-07 sti splitter?
Old 07-27-2009, 08:43 AM   #281
burtonrider3889
Member#: 163519
2006 Cayman S
I have a quick question that I can't find by searching. I know us wrx guys need the two extra hoses to make the STI top mount fit, but is this fitment to the stock turbo or an upgraded turbo? Is the hose still too short on a bigger turbo like 16g? I have my top mount. I'm wondering if I need to buy these hoses to make it fit for when I put it on with my turbo or if I can just use the old hoses.
burtonrider3889 is offline   Reply With Quote
Old 08-02-2009, 03:09 PM   #282
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It's a fitment on stock turbo. I am pretty sure extended hoses are needed on 16g or bigger turbos.
Old 08-28-2009, 12:24 AM   #283
konmann
Member#: 125466
2006 WRX TR
SGM
Default 06/07 WRX to STI TMIC
I did this just a few days ago, aiming for a "factory" type install which included the foam "packing" seals found on the STI splitter. Hopefully this will help a few of you out. Subiegal supplied this diagram w/ part numbers:
My final parts list was something like this:
P/n...........description...................quantity....actual catalog #
90817.........splitter...........................x 1...........90817FE310
W300029.....splitter grommet..............x4............909300029
Q575017.....grommet bolt...................x4............904575017
90817B.......bellows...........................x1. ..........90817FE340
90881H.......bellows anchor clips..........x20..........90826FA000
59185.........plastic alignment screw.....x1............59130AA000
W130083.....alighment/anchor pin........x2............909130083
90875B......packing seal.....................x1 ...........90875FE180
90875C......packing seal....................NA............2004/05 MODEL YEAR ONLY
90875E......packing seal *.................NA............2004 MODEL YEAR ONLY
90875F......packing seal *..................x2............90875FE080
* for both the E,F packing seals, a package contains single pieces
Remember my quantities and parts may differ from what you need. I did order extra of the plastic clips and screws because I have a tendency to break em or lose em to the black hole on top of the engine block
Hope this helps,
Konmann
konmann is offline   Reply With Quote
Old 09-15-2009, 02:12 AM   #284
05wrx09
Member#: 204111
2005 WRX
Will a Samco 90 degree 2in hose for the y-pipe elbow work just as well as one from StylinMotors? I'm hoping so as the Samco is $40 vs the $45 for the Stylin...
I can't get my new STi TMIC to fit on my 05 WRX with the TD04 obviously. Guess I need that 90 degree elbow. Hope it's longer than the stock red one on the STi y-pipe... already ordered a longer TB/IC coupler from Stylin too...
Any feedback on the Samco 90 degree elbows?
05wrx09 is offline   Reply With Quote
Old 09-15-2009, 08:29 AM   #285
Ryan314
Member#: 82989
Hybrid EJ257
I just recently installed a USDM STi TMIC on my 02 WRX and the only problem I ran into was the bolt hole on the left side of the intercooler. There is NO way this bolt hole will line up without bending the A/C line or getting a new line all together.
Old 09-15-2009, 02:43 PM   #286
05wrx09
Member#: 204111
2005 WRX
Stock turbo? Did you use a different 90 degree elbow?
Old 09-15-2009, 03:44 PM   #287
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Every single question which was recently asked is CLEARLY answered in the stickies and other posts regarding this topic.
Oh and word of advice for Ryan314: On my 02 with an STi Top Mount i took two zip ties and used one on the passenger side where the AC lines go in/out of the firewall and tied the two AC lines together near the C clip holding the return line down, then I took the other zip tie and again tied the two lines together near the dead center of the car behind the intercooler there is another clip holding the return line to the firewall. (on mine this clip was not a C, but a complete clip) Now, the combination of the two keeps the AC lines away from the intercooler completely. I wrapped the line where it could contact with rubber for a precaution though.
No noticeable change in AC temp (may hurt its efficiency a bit, i dont know). If you are worried about these lines touching that much, then you can always insulate them.
Good luck, this was the best and easiest solution to the problem I have been able to find.
Agkelos is offline   Reply With Quote
Old 09-22-2009, 11:25 AM   #288
Ryan314
Member#: 82989
Hybrid EJ257
Question about the STi y pipes- Why is it that some y pipes are solid until the elbow like this one (mine)...
While others have the a piece of silcone hosing in between the y pipe like this?
Old 09-22-2009, 01:03 PM   #289
05wrx09
Member#: 204111
2005 WRX
Good question. I have wondered the same thing. My STi TMIC has the all metal pipe until the elbow like yours too, but ours seems a lot less common than the 2nd one you mentioned there with the little silicone hose part in the middle of the Y-pipe
Old 09-22-2009, 04:08 PM   #290
Ryan314
Member#: 82989
Hybrid EJ257
I did a little research and from what I read, the solid metal cast ones are from 06+ STIs, while the two piece with the silcone hose are from the 04-05 STi.
Correct if I'm wrong someone!
Old 09-22-2009, 05:42 PM   #291
05wrx09
Member#: 204111
2005 WRX
Right on. Wonder if the 06+ ones are any better then... I could think so...
Old 09-29-2009, 10:54 PM   #292
Ryan314
Member#: 82989
Hybrid EJ257
Does anyone know exactly how much to trim off of the Stylin' Motors 2" ID Elbow for a perfect fit?
Old 09-29-2009, 11:01 PM   #293
eb_rat_7
Member#: 106910
2016 GTI
C6 ZO6 track toy
it varies car to car. put it on, mark it, cut a little, put it back on, trim a little more. dont do it all in one wack or you may end up with one that is too short.
Old 11-14-2009, 06:03 AM   #294
Mekks
Member#: 219749
anyone know if the Samco 04 sti... IC->TB hose is long enough for this swap?
Mekks is offline   Reply With Quote
Old 12-01-2009, 12:10 AM   #295
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Mekks, STI IC-TB hose is not long enough for the swap.
Old 12-15-2009, 02:26 PM   #296
beedee
Member#: 124727
thanks, i'll be doing mine this weekend.
beedee is offline   Reply With Quote
Old 03-11-2010, 01:41 PM   #297
pnoyjstylez
Member#: 172235
2002 ImprezaWRX Stg2
So to put this into an 02 wrx without any problems..im going to need
-The kit from stylin' motors.
-Sti Splitter
-JDM Hoodscoop
both from rallyspec?
pnoyjstylez is offline   Reply With Quote
Old 03-13-2010, 02:02 AM   #298
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I am sure you can get splitter and JDM hood scoop from any nasioc vendors. Give them a call to find out.
Old 03-14-2010, 05:18 PM   #299
requience139
Member#: 240240
2007 WRX
is the jdm hood scoop necessary? im trying to buy hose from the y pipe to turbo but cant decide where to buy. someone said siliconehose.net but im not sure which one i should buy in the website. anyone for sure know and have bought it before?
requience139 is offline   Reply With Quote
Old 03-15-2010, 06:07 PM   #300
SoobieDoobieDoooo
Member#: 156440
-_- I am da wheeler
dealer king! Yeea buddy!!
Quick question people...I just got a Turbo XS TMIC with just the Y pipe & gaskets...that's it. Bought it used. Can I re-use the parts off my '07 STI TMIC? Thanks.
SoobieDoobieDoooo is offline   Reply With Quote
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
