Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 05-14-2010, 10:15 AM   #301
BoostinChick
Member#: 218971
2007 WRX
FWIW, I purchased a 2" ID from here - http://www.siliconeintakes.com/
Direct link - http://www.siliconeintakes.com/index...01078ee9aee664
It was the correct length/size so I did not have to do any additional cutting. The only thing I am missing out of is the "Samco" label. For the price, I am sure it will be able to withstand the capabilities of MY07. If not, I only wasted $17 and I have a template for cutting to the correct size. I will post pics when I get a chance.
BoostinChick is offline   Reply With Quote
Old 05-14-2010, 11:52 AM   #302
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
FWIW....I was able to install the USDM STI TMIC and retain my Samco TMIC to TB hose (same length as stock) and use the stock STI "y" pipe and stock red STI elbow hose.
I slotted the 2 holes on the driver side I/C bracket where it mounts to the manifold. There isn't enough material on the passenger side I/C bracket to slot the holes so I used a simple square peice of metal with 2 holes to accommodate the 1-.75 inch difference between the I/C bracket and TMIC. Worked like a charm...
sanremo_russ is offline   Reply With Quote
Old 07-18-2010, 09:33 PM   #303
BoostAWD
Member#: 99108
2007 Impreza WRX LTD
Satin White Pearl
Default Sti Tmic
OK, I installed an 05 STI TMIC in my 07 WRX LTD. Everybody has different measurements they used for their hoses. I used Hose Techniques brand hoses on my install. I used their NX500 series for both the 90 degree elbow and the Straight Hose. For the elbow I aligned the mount bracket holes to those on the IC and placed the hose in its place. After marking with a sharpie I removed it and little by little I cut from the both ends until I had the perfect fit, and after having success with the elbow I did the same with the straight Hose. I also replaced the stock WRX Splitter and the Splitter duct seals with those of the 06-07 STI, which I bought at Subarugenuineparts.com. Since the 06-07 WRX Hood scoops are the same as the 06-07 STI, there was no need for replacing it. This took about a half hour but only because I took my time. Here is my end state pics. Hope this helps others. The best advice I have for anybody doing this mod is trim the hoses little by little until you get the wanted outcome. One more thing, T-Bolt Clamps are a good investment.
Stock Parts
For My 07 WRX LTD I didnt have to bend or put any padding on the AC Lines, they wrap around enough so that they do not rub. Many of the other WRX guys claim they have rubbing on their lines.
BoostAWD is offline   Reply With Quote
Old 07-18-2010, 09:37 PM   #304
BoostAWD
Member#: 99108
Satin White Pearl
Oh the hoses I used from Hosetechniques.com are their 2" (51mm) ID 90 Degree Elbow Coupler, and the 2.75" (70mm) ID Straight Hose (3.00" Long). Both from their NX500 series. There was no need for bracket adjustment or fabricating for this mod, just trimed the hosed as needed and installed.
Old 07-18-2010, 10:21 PM   #305
jtheshowstoppper
Member#: 252406
2002 wrx
nice install man
jtheshowstoppper is offline   Reply With Quote
Old 07-28-2010, 11:44 PM   #306
adictd2b00st
Member#: 126446
2006 WRX Ltd Wagon
San Remo Red
Originally Posted by 1illusion View Post
These are the one's I got and they worked fine for an 04 USDM STi TMIC with the Cast Y pipe.
50.275-300-110 $10.50 (2.75" ID, 3" long)
56.200-418-110 $38.25 (2" ID, leg are 4.18" from center of bend)
Sorry if this has been mentioned before but..
If anyone is going back into this thread, the part numbers are slightly different now according to hose techniques website. And cheaper
50.275-300-NX-Black $5.98 2.75 in ID x 3.00 L Straight
56.200-418-NX-Black $16.46 90 deg bend 2.00 in ID leg is 4.18 in long
adictd2b00st is offline   Reply With Quote
Old 08-03-2010, 05:38 PM   #307
blk05wrx
Member#: 180559
2005 WRX Cobb Stg 2
This thread was a big help with my TMIC purchase. I ordered the elbow and TB coupler from Hose Techniques. Fast shipping, nice product.
My STI TMIC didn't come with a Y-Pipe, so I ordered one of Ebay. It's surprisingly a very nice kit. It's not the cheapest one on Ebay, but the seller was able to answer my questions and their other products were all name brand products.
The seller name is boombop. Here's a link to the kit and a picture.
http://cgi.ebay.com/ebaymotors/ws/eB...m=350365014413
I do have one question. Will my breather hose fit on the STI TMIC? I have an 05 WRX.
blk05wrx is offline   Reply With Quote
Old 12-13-2010, 03:59 PM   #308
gtfaded
Member#: 142322
2002 wrx
wrb
Ok, so someone please help me out here. Installed an STi intercooler on my 2002 WRX. Obviously doesn't line up well. The TB coupler hose has slipped off a couple of times. Now by reading this thread I am left with the impression that all I need for a correct line up is extended piping. This doesnt seem to be right as the throttle body coupler is where the problem lies, I have the Spekter coupler or whatever it's called from advanced auto parts for like 8 bucks. It's long enough but it's stressed to the left (drivers side) I dont suppose STi brackets will help?
gtfaded is offline   Reply With Quote
Old 12-13-2010, 05:26 PM   #309
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You need to extend out both 90 degree hose and TB hose in order to make them perfectly fit. WRX and STI brackets are identical IIRC.
txl146 is online now   Reply With Quote
Old 12-13-2010, 05:34 PM   #310
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
Brackets are the same.
I have an 04 STi TMIC on my 02. Picked up a longer 90* elbow for the I/C to turbo connection and a longer I/C to throttle body coupler. Fits like a glove.
stikboy9 is offline   Reply With Quote
Old 12-13-2010, 05:37 PM   #311
evoeater1
Member#: 210044
2004 STI BABY!!!
Java black (o yeah!)
Ive blown sooooo many holes in those spectra couplings, god i hate those things LOL! 5 ply couplers from ebay ! YAY!!! Permanent solution
evoeater1 is offline   Reply With Quote
Old 12-13-2010, 05:43 PM   #312
joenova
Member#: 146829
2005 Saab 92x Aero
Artic Silver
same setup I have on the saabaru. Same hoses etc etc.
joenova is offline   Reply With Quote
Old 12-13-2010, 05:50 PM   #313
gtfaded
Member#: 142322
2002 wrx
wrb
Thanks for the breakdown guys, I'll get the needed pipping asap.
Old 03-11-2011, 10:09 AM   #314
fenix-silver
Member#: 231700
2004 WRX Wagon
Originally Posted by Petrie View Post
I used an 06/07 STI splitter and the holes were in the right spot. They were recessed away from the hood a little bit but that closes up as you bolt it on.
Can anyone confirm that the 06/07 splitter will work with an 04 wrx scoop? I'd prefer to keep the stock scoop if I upgrade to an STI tmic.
Thanks!
fenix-silver is offline   Reply With Quote
Old 03-24-2011, 08:28 PM   #315
devildog12390
Member#: 251000
Can anyone confirm that this 90* elbow will be long enough to fit an 06+ Sti TMIC in an 02 WRX?
I'm running a PE1820 so the Sti elbow doesn't sit perfectly on the turbo by about an 1" or 1.5" i just didn't want to order something too short...
http://www.siliconeintakes.com/produ...01078ee9aee664
devildog12390 is offline   Reply With Quote
Old 03-24-2011, 08:39 PM   #316
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Seems a bit too short. Order longer hose then trim as needed.
Old 03-24-2011, 09:13 PM   #317
devildog12390
Member#: 251000
Any suggestion besides stylin motors? They never delivered when I ordered from them so I had to get a refund...
Old 03-26-2011, 10:59 AM   #318
requience139
Member#: 240240
2007 WRX
I got mine from stylin. It was pretty expensive for a piece of hose. Samco is expensive but it looks nice
requience139 is offline   Reply With Quote
Old 03-26-2011, 11:22 AM   #319
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
I bought Tial silicone hoses for my V7 STI TMIC. Very pricey and had to trim the elbow legs. Used T-bolt clamps and have run up to 26 psi without a worry. Spend a little more up front and never have to do it again.
soobaviator is offline   Reply With Quote
Old 01-21-2012, 05:12 PM   #320
squeezeboxer2.5
Member#: 234974
2006 WRX
SGM
this thread helped me get the job done on my 06 WRX Limited
squeezeboxer2.5 is offline   Reply With Quote
Old 03-13-2012, 12:57 AM   #321
Nickarub
Member#: 230509
06 vf39 wrx
ugm
one question? when you say the IC to turbo hose is 1" SHORT... is it short left-right from the lower turbo side of the hose or short up-down from the upper IC part?
Nickarub is offline   Reply With Quote
Old 04-24-2012, 02:42 PM   #322
kylej
Member#: 100084
Alrighty so I have a vf39 and STi TMIC in my 04 WRX. I should just need the longer TB coupler, correct?
kylej is offline   Reply With Quote
Old 05-24-2012, 08:35 AM   #323
kylej
Member#: 100084
Just to answer my above question, if you have a vf39 or vf43 and an STi TMIC, and you're installing BOTH into your WRX, you ONLY need a longer throttle body coupler (2.75" inner diameter, 3" long)
I bought one from here for super cheap and it's nice quality
You'll probably have to trim the coupler a little bit to get the brackets on the intercooler to bolt up. Just a centimeter or so of trimming, but fit it with the full 3" long coupler first to see if it works as-is, every car is a little different.
One of the bigger issues I'm running into now is the AC line rubbing against the intercooler, I've wrapped it, bent it, etc and nothing helps. When they rub it'll feel like rod knock or something too, the whole car shakes like crazy. I just ordered the larger STi AC line to clear the intercooler a few days ago which should fix the problem ( part number # 73422FE031)
hope this helps anyone who stumbles on this!
Old 08-02-2012, 12:09 AM   #324
VFXWRX
Member#: 310146
2002 vf39'd wrx
psm (sold)
I know this is an old thread, but did you get that AC line replaced? Did it fix the issue? Just did the STI tmic install and the damn rattling has got to stop.
VFXWRX is offline   Reply With Quote
Old 08-02-2012, 12:38 AM   #325
VFXWRX
Member#: 310146
2002 vf39'd wrx
psm (sold)
One other note, I got an STI top mount and splitter from an 07 from a friend, and I'm cheap, so I decided not to buy the v.7 sti scoop/splitter combo. The 07 splitter actually fits great with a few cuts from some tin snips
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
