Old 03-06-2006, 10:21 PM   #26
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Originally Posted by Freon
Ok makes sense, since the WRX throttle body is shorter...
There are two reasons why IC do not correctly align on mounting tab on passenger's side:
1. TB hose is about 1" short.
2. Turbo to IC hose is also short.
You will need to upgrade both hoses for IC to correctly align on both brackets.
Old 03-06-2006, 10:26 PM   #27
1illusion
Member#: 48286
2005 2.5L WagonRX
not black, blue or grey.
Exactamundo!
1illusion is offline   Reply With Quote
Old 03-08-2006, 06:55 PM   #28
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I finally received 2.5" ID TB hose today. However, I found out that it won't fit! You must use a 2.75" ID TB hose to fit correctly...
Old 03-08-2006, 07:48 PM   #29
1illusion
Member#: 48286
2005 2.5L WagonRX
Even squeezing, squishing and prying? The ID of the stock hose was only 2.5 as I mentioned earlier, maybe it is more pliable. Yeah I should have noted that the 2.75 was snug going over the clamping rib which is right about 2.75.
Old 03-08-2006, 10:32 PM   #30
gopsu
Member#: 96448
02 WRX VF34
2.75" seems to be the correct size...
gopsu is offline   Reply With Quote
Old 03-08-2006, 10:34 PM   #31
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I tried to squeeze it to get it to fit, but it is way too small. 2.75" ID is the best size.
Old 03-09-2006, 07:36 AM   #32
Farnsrocket
Member#: 83567
08 Outback
Obsidian Black Pearl
This is a HOSE issue, not a BRACKET issue!
People are getting confused with this..........the IC mounts perfectly to the brackets ....you do not need to bend them.
Farnsrocket is offline   Reply With Quote
Old 03-09-2006, 08:11 PM   #33
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Default y-pipe
How do you tell the differance between an sti y-pipe and a wrx y-pipe?
dsmtowrx is offline   Reply With Quote
Old 03-09-2006, 08:17 PM   #34
1illusion
Member#: 48286
2005 2.5L WagonRX
STi is a solid smooth metal Y, WRX is two metal flanges off of the IC, with the nastiest looking excuse for a plastic Y you've ever seen.
Old 03-09-2006, 09:10 PM   #35
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
WRX y-pipe doesn't exist from factory. It's y-hose. Gruppe-s sells y-pipe for WRX.
Old 03-11-2006, 05:42 AM   #36
Phase315
Member#: 57655
2004 WRX Impreza
ok guys....now im confused...if i order from hosetechniques, which are the hoses i need? i dont want to order the wrong ones like txl146. after i get these hoses do i need to cut them to make them fit?
-thanks in advance
Phase315 is offline   Reply With Quote
Old 03-11-2006, 12:45 PM   #37
1illusion
Member#: 48286
2005 2.5L WagonRX
-thanks in advance
These are the one's I got and they worked fine for an 04 USDM STi TMIC with the Cast Y pipe.
50.275-300-110 $10.50 (2.75" ID, 3" long)
56.200-418-110 $38.25 (2" ID, leg are 4.18" from center of bend)
Old 03-17-2006, 12:22 PM   #38
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Yes, you will need 2.75" ID, 3" long TB hose. You will have to cut close to an inch to make it a perfect fit.
2.5" ID hose WILL NOT FIT no matter how hard you try.
Old 03-20-2006, 07:51 AM   #39
JBravo920
Member#: 73420
2008 Camry XLE
& 10' Kawasaki Vulcan 900
by the by, i totally agree on moving your stock A/C lines, i figured it would be ok and did not move mine, just let them rub. i no longer have A/C since there is a big hole burnt into the line where the intercooler was rubbing.
JBravo920 is offline   Reply With Quote
Old 03-20-2006, 07:59 AM   #40
Farnsrocket
Member#: 83567
08 Outback
A 1/2" rubber hose split lengthwise and zip tied to your lines will solve that.
Old 03-20-2006, 09:17 AM   #41
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
The big problem here is that mounting points on the ICs are in a different spot.
I have a V7 and a US STi sitting here in my living room. I'll take some pics.
dbrier is offline   Reply With Quote
Old 03-20-2006, 09:01 PM   #42
JBravo920
Member#: 73420
2008 Camry XLE
Are you saying that will solve my problem? Like i would just put the rubber hose over the spot that has the hole, zip tie it on and then maybe recharge the A/C...
Old 03-20-2006, 09:07 PM   #43
Farnsrocket
Member#: 83567
08 Outback
No, not at all....LOL.....and I am sorry for the confusion, cause now, after reading my post, it does sound like that is what I was trying to say.
I should have typed would have solved that.
Old 03-20-2006, 09:12 PM   #44
JBravo920
Member#: 73420
2008 Camry XLE
haha, its cool man, thats what I figured you meant, just kinda got my hopes up, but since i figured i was screwed anyway there was no damage done to my feelings. Anybody know of anything that could possibly fix this other than just getting a new A/C line? If not, i may just be taking the A/C out, a little weight reduction if you will.
Old 03-21-2006, 08:32 PM   #45
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Just received USDM STi air splitter and shroud in mail today. Will post some more pics later.
Old 03-26-2006, 02:47 PM   #46
cincyrider
Member#: 95026
where are the pics?
cincyrider is offline   Reply With Quote
Old 03-26-2006, 08:51 PM   #47
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Sorry, I will post some pics tomorrow. Just came back from vacation.
Old 03-27-2006, 06:54 PM   #48
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I have tried to install USDM STi TMIC today. Unfortunately, it won't fit on my car although my car has JDM STi hood scoop. Air splitter sits way too high to clear JDM STi hood scoop.
I guess what I learn from this experience is that you will need a JDM V7 air splitter and not USDM STi air splitter.
Old 03-27-2006, 10:21 PM   #49
dsmtowrx
Member#: 48879
Grey Stocker
Default Splitter didn't work?
Your trying to install a USDM STi intercooler and the USDM STi splitter doesn't work because of the hood scoop? I have an 04 and just bought a USDM STi IC and want to know what splitter will work with stock scoop? V7 or what?
Old 03-27-2006, 10:38 PM   #50
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
If you have 2004+ body style, USDM STi air splitter will work just fine (if you have STi hood scoop). For 2002-03 body style, JDM STi splitter will work with JDM STi hood scoop.
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
