Old 12-21-2006, 11:10 PM   #126
burnside
Member#: 43404
2002 WRX Wagon
txl146, Thanks! That is what I thought. I just wanted to see if there were any other options and/or if I was off-track with my conclusion. I guess I will order the JDM splitter sometime soon!
burnside is offline   Reply With Quote
Old 01-23-2007, 01:30 AM   #127
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
is the lengthing on of IC>turbo still neccesary if your mounting it to a vf39 and not the td04?
sluflyer06 is offline   Reply With Quote
Old 02-15-2007, 01:34 PM   #128
thejean
Member#: 17763
Can't the USDM STI splitter be modified to fit under the JDM STI hood scoops on the 02 WRX's? I am thinking just cut it down some and re-rivet.
thejean is offline   Reply With Quote
Old 02-15-2007, 02:04 PM   #129
only1agam
Member#: 56183
does anyone know if the prodrive y-pipe will fit the STI intercooler?
only1agam is offline   Reply With Quote
Old 02-15-2007, 02:09 PM   #130
thejean
Member#: 17763
^^^good question (because that's also what I have).
Old 02-16-2007, 12:47 AM   #131
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
most likely it will fit, but I am pretty certain that it will be about 1" short.
Old 02-16-2007, 12:51 AM   #132
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
FYI, USDM STI splitter is noticeably bigger than JDM ones. You can try and let us know.
Old 02-16-2007, 01:03 AM   #133
SubiePilot
Member#: 85245
V7 STi wanna be
Talk to Steve that is what he did on his car, except he had a JDM STI TMIC, a USDM STi splitter and a JDM scoop. But still the same splitter/scoop combo.
And txl146 I have to commend you on this and your other how to threads(injectors, turbo) They were a huge help to me when doing a turbo swap. Alot better than anything else I found. I recommend your threads to anyone thinking of doing these mods.
SubiePilot is offline   Reply With Quote
Old 02-16-2007, 01:18 AM   #134
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
SubiePilot, thank you...
Old 02-25-2007, 05:27 PM   #135
STinewbie
Member#: 88240
Default Update 2006 STI TMIC install to 2006 Wagon
This thread was of great use. Couple updates that I experienced though. I got the two hoses suggested on this thread (the 90 degree bend and the 3" straight hose) and I had a 2006 STi TMIC with the stock Y-pipe that came with it. I put it onto a 2006 WRX Wagon this past weekend. I actually had to chop about an inch on both sides of the 90 degree bend hose that I got from hosetechniques but once I did I was able to line up both mounts easily and the bolts went in no problem. I would say that I dont think I needed the 3" straight hose though since the stock one worked ok, but I ended up just using it (and cutting it a litte) to make both of my hoses match.
It was a great upgrade though. My wagon is still pushing the same boost etc. but I am getting colder air and I can feel the new intercooler (and hear it) work hard when I am above 3500RPM and the car's throttle response is ridiculous. I used to have a 2004 STi and got the Wagon for family changes....now I am getting back to having an STi with the Wagon.
Also added a Cobb cat back and the car rocks. I am actually still running a little rich, but its useful when I am pushing it hard. I will take pics when the snow stops.....
Great instructions though txl146!
STinewbie is offline   Reply With Quote
Old 02-26-2007, 01:02 AM   #136
kaeo_15
Top Scoob 021
Member#: 115406
On to the next...
Is it possible to use a gtspec intercooler splitter instead of a JDM sti splitter with a JDM sti bugeye hoodscoop? This would be for either a USDM or JDM V7 TMIC.
kaeo_15 is offline   Reply With Quote
Old 02-26-2007, 10:41 AM   #137
thejean
Member#: 17763
I was told the GTspec splitters scratch the crap out of the intercooler (no rubber shroud).
Old 02-26-2007, 04:24 PM   #138
kaeo_15
Top Scoob 021
Member#: 115406
On to the next...
^ Thanks, guess i'll go with the JDM one then...
Old 03-19-2007, 10:35 PM   #139
tw000
Member#: 119028
2005 Legacy 2.5i SWP
'06 WRX Wagon
For those of us missing the $300 red elbow this kit works great:
http://www.rallysportdirect.com/shop...it-p-2469.html
I'm not advertising, I'm just saying that I used this kit on my '06 and it worked. I ordered it from these guys and they were pretty cool.
Reply back to the thread or PM me if you have any questions. It took me while to find this kit.
tw000 is offline   Reply With Quote
Old 03-19-2007, 11:12 PM   #140
scoobydrew06
Member#: 32951
Maybe this is a good place to post this, maybe not. I have a JDM v8 STi TMIC on the way. Not sure if it is going to have the y pipe or not. If it doesn't, I think my wrx elbows will bolt on, and then would I be able to use one of those samco IC hose kits to finish the package?
scoobydrew06 is offline   Reply With Quote
Old 03-19-2007, 11:29 PM   #141
tw000
Member#: 119028
'06 WRX Wagon
A guy I know, he is on the boards, used his WRX elbows with one of the WRX IC hose kits to mount a USDM STI TMIC in his '06.
That's probably where I'd start. I think another friend has a JDM STI TMIC in his car and it's mounting points don't quite line up (he has a swapped '99 RS, not sure what year motor). I seem to remember something in the thread about the JDM TMIC.
Old 03-19-2007, 11:38 PM   #142
scoobydrew06
Member#: 32951
JDM TMIC is a bolt on for the 2.0 wrx, just not sure what to do about the hoses.
Old 03-20-2007, 02:20 PM   #143
thejean
Member#: 17763
Update... my STI TMIC fit my car with no problems. I had to hack my WRX prodrive silicon hoses to fab and elbow piece, but otherwise, everything bolted up nicely. JC
Old 04-22-2007, 02:11 PM   #144
CSULBwagon
Member#: 95428
02 WRX wagon STG2
Dirty Silver
I did the extention in my current pipes with the metal tube and it keeps poping off at high boost ~15psi. I have tried ring clamps but it still pops off. It is a bit greasy and I was thinking some kind of bonding epoxy. Any thoughts?
CSULBwagon is offline   Reply With Quote
Old 04-22-2007, 08:41 PM   #145
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
you may have cut your pipe too short? I've never had any problem of it popping off even at 19psi.
Old 04-22-2007, 08:45 PM   #146
MasterKwan
Member#: 98961
2003 WRX
Mine doesn't pop either but. I'm using T-bolt clamps which are tight as hell.
Old 04-22-2007, 08:46 PM   #147
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
That's what I am using also.
Old 04-23-2007, 02:14 AM   #148
CSULBwagon
Member#: 95428
02 WRX wagon STG2
Dirty Silver
what are t-bolt clamps?
well I used an epoxy today and its holding just fine. The stuff was rated for 1500psi so I think I should be fine. I just hope that it is not effected by the heat.
Old 04-23-2007, 03:32 AM   #149
dankEe
Member#: 97958
ASPEN
wow, so much work, must think twice bout a sti tmic
- Danny
dankEe is offline   Reply With Quote
Old 04-23-2007, 11:13 PM   #150
WRX-N-FX
Member#: 124062
Ok, im sure this has been done to death, but after six pages of reading, im more confused than when I started. So here goes......
I have a 2002 WRX. Just bought a 2005 USDM STi TMIC w/solid Y-pipe and red elbow on the end... Please if someone could give me a list of parts to do the swap clean and nice, It would be appreciated, Thanks
WRX-N-FX is offline   Reply With Quote
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
