Old 07-15-2007, 11:13 PM   #176
06Saabaru
Member#: 115234
2006 Saab92xAero 6MT
Brilliant Red
oops wrong forum
06Saabaru is offline   Reply With Quote
Old 07-26-2007, 11:38 AM   #177
cincyrider
Member#: 95026
Just got the turbo inlet hose from stylinmotors.com. Can't wait to install this weekend. Will let you know how it goes. Anyone have any tips?
cincyrider is offline   Reply With Quote
Old 07-26-2007, 02:54 PM   #178
ATK
Member#: 123698
2004 WRX Sportwagon
Check out my posts #160 and #165.
ATK is offline   Reply With Quote
Old 07-26-2007, 05:07 PM   #179
cincyrider
Member#: 95026
I was talking about the turbo inlet hose, not the intercooler hose. Already did those. Thanks
Old 07-26-2007, 05:18 PM   #180
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It is easier to remove if you use a hack saw to chop off two nipples off of OEM hose. Also, spray small amount of WD40 on new hose to make install easier.
It can be easily done in 1 hour.
Old 07-27-2007, 01:01 PM   #181
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Originally Posted by txl146 View Post
... spray small amount of WD40 on new hose to make install easier.
Not really a good idea. A little bit of rubbing alcohol works great - it makes things nice & slippery but doesn't leave any residue.
jac04 is offline   Reply With Quote
Old 09-08-2007, 02:26 PM   #182
EL-GUAPIN
Member#: 149300
2003 Lexus IS300
GGP
Just got my STi TMIC install. I purchased the hose kit form StylinMotors. after some triming I got everything to line up,no problem. My only concern now is the AC lines. I have about 2cm clearence but I want bend the line back to be safe. HOW DO I BEND THOSE LINES WITHOUT BREAKING THEM ???.. Ill post pics later.. THNX
EL-GUAPIN is offline   Reply With Quote
Old 09-20-2007, 11:57 PM   #183
Cosmic_Subie48
Member#: 152949
07 WRX Limited
WRB COBB Stg. 2
I have a STI tmic, and mine came wit the stock y-pipe, and hose that connects to the turbo. I bought the STI gasket. (that triangular rubber thing)
now my question is, do i have to wait to buy a STI air splitter? or can i put it on, and then order 1 and put that on later?
Also i hear about people having to bend their AC lines? if i have to do this...fine, but someone please explain the easiest way to do it without crazy tools.
Cosmic_Subie48 is offline   Reply With Quote
Old 09-21-2007, 03:28 AM   #184
sleepyfu
Member#: 124219
2004 W(agon)RX
dose anyone else see how clean ATK's engine bay looks? wow..
sleepyfu is offline   Reply With Quote
Old 09-21-2007, 10:53 PM   #185
tw000
Member#: 119028
2005 Legacy 2.5i SWP
'06 WRX Wagon
I ran mine without the STI splitter for a couple of months without any problem, YMMV. The STI splitter caused underhood temperatures to drop noticeably, though
A/C lines are clear on my car, but I had to bend the pipe that connects the BOV back to the intake.
tw000 is offline   Reply With Quote
Old 10-11-2007, 10:25 PM   #186
ATK
Member#: 123698
2004 WRX Sportwagon
Whoa, just saw this. Thanks dude. I try to keep it clean all the time. Every time I wash my car, I'll take the wetter of the towels and wipe everything down. It keeps everything clean pretty well. Simple maintenance.
Old 10-23-2007, 12:19 AM   #187
Cosmic_Subie48
Member#: 152949
07 WRX Limited
WRB COBB Stg. 2
alright, i know everyone has been through this...but i still stand confused. I tried putting this on with what you see in the picture, but the hose is to short for my td04 turbo. Anyway heres a list of what i got. Tell me what i'm going to need to make this work! I am getting frustrated trying to make this work.
Going onto a 07 WRX
- Air Splitter for STI
- Triangle Rubber Gasket
Also, with the mounting brackets. I didnt really check to much b/c i was trying to get the hose that came with the IC to fit all the way around the turbo. thanks for the help guys, i know its a bunch of repeating but i read the whole thread and was just confused.
Old 11-08-2007, 03:43 AM   #188
fonzy
Member#: 129124
Any mounting problems with 05 USDM STI TMIC on a 06 WRX? thinkin of gething this kit www.stylinmotors.com/subaru.html.
fonzy is offline   Reply With Quote
Old 11-28-2007, 06:16 PM   #189
Bettbaseball25
Member#: 159462
2006 wrx
I am a more confused now after reading through this entire thread. I have a 06 wrx with a 05 sti tmic that came with the sti y pipe. I am putting this in with a FP18g turbo and was wondering what all I need to install the intercooler. Could I just get the Samco STI intercooler hose Kit or do I even need anything at all? Thanks
Bettbaseball25 is offline   Reply With Quote
Old 01-25-2008, 04:40 PM   #190
Computergeek24
Member#: 108964
2013 Ford Focus ST
Performance Blue
Just to get a clarified answer here before I order stuff.
I have a 2004 WRX and a 2007 STi intercooler with the full metal y-pipe.
Will the Samco hose kit seen here allow me to install it cleanly and correctly? The elbow on it looks longer than stock which is what sounds like is needed.
http://www.rallysportdirect.com/shop...it-p-2469.html
Also, to have it line up with a USDM 04/05 STi scoop/splitter will I use the WRX or STi TMIC mounting brackets (I have both)?
Computergeek24 is offline   Reply With Quote
Old 01-25-2008, 06:24 PM   #191
cincyrider
Member#: 95026
What you should need is the USDM WRX STi kit from here:
Old 01-25-2008, 07:36 PM   #192
Computergeek24
Member#: 108964
2013 Ford Focus ST
Performance Blue
I know that one is cheaper, but I have a friend who gets REALLY good deals on Samco. Anyone know if the Samco one will work?
Old 01-25-2008, 08:28 PM   #193
jac04
Member#: 49895
09 Forester
^I used the TCS209 kit to install an 04 STi intercooler on my 05 WRX. It worked perfectly. The elbow was actually slightly longer than it needed to be.
Old 01-25-2008, 08:32 PM   #194
cincyrider
Member#: 95026
Hey if you want to pay for the name it is your money. Stylin's hoses have more reinforcement and the wall thickness of the hoses are thicker by about 3/32 of an inch. Almost double. This makes the hoses much stronger.
Old 01-26-2008, 02:10 AM   #195
Computergeek24
Member#: 108964
2013 Ford Focus ST
Performance Blue
Just the answer I was looking for.
Like I said, I can get a good deal on Samco stuff. They will end up pretty much the same price.
Old 02-27-2008, 08:11 PM   #196
driftin240
Member#: 110657
2003 Impreza
I just ordered my parts from Stylinmotors.com, and the splitter from Rallispec.com.
Hopefully I can get them soon, and get the intercooler installed quick!
driftin240 is offline   Reply With Quote
Old 04-02-2008, 02:12 AM   #197
ALTIMIT_09
Member#: 138527
2004 WRX 4eat vf39'd
I have an 04 wrx and i wanna know if I can just keep my stock air splitter and just modify it to fit is there any write up on this? someone please post a link for this or send me a pm with what you found.
the rest i understand but the air splitter i am confused with. Thanks!
ALTIMIT_09 is offline   Reply With Quote
Old 04-02-2008, 09:56 AM   #198
BIGSKYWRX
Member#: 7958
09 GH B+
it would be pretty difficult to do (but probably doable) and at a minimum you would still need the longer STi seal- the oe splitter/seal is designed to perfectly match (fit into) the oe sized intercooler, w/ the larger STi ic the oe seal/splitter is simply too small and a large % of the ic won't be getting the proper air flow.
it's been demonstrated that a correct seal is absolutely essential for peak intercooler performance, you can have a high dollar, fancy intercooler if it isn't sealed correctly it isn't going to perform worth a damn
Old 04-02-2008, 11:48 AM   #199
Computergeek24
Member#: 108964
2013 Ford Focus ST
Performance Blue
Bigsky is right. I have the same setup (04 WRX w/STi TMIC) and with my stock splitter/shroud, the seal and coverage is far less than what it could be. It will work as a temp solution, but the best route to go will be an STi scoop/splitter/shroud. Should be a direct and perfect fit, that's what I'll be going with.
Old 04-02-2008, 01:08 PM   #200
GeneralTJI
Member#: 152680
Strangely enough, I just installed my STi TMIC on my 02 and didn't have to extend the hose going to the compressor outlet... both brackets lined up correctly, the tb to IC outlet lined up, it sits in the car square and lined up.... everything lined up fine.. (I'm running a vf39)
GeneralTJI is offline   Reply With Quote
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 03:16 PM
