Old 03-01-2006, 11:51 PM   #1
kbahus
Member#: 70256
2000 STI V2 Swapped
Default legacy turbo vs wrx crossmember
I am going to order my crossmember tomorrow for my V2 swap and have been reading as much as possible on this subject but can't find any definite answers. Functionally, other than the shimming, are there any other pro's or con's for using one over the other? I would tend to think sway bar's and mounts would be easier and cheaper to get a hold for the wrx crossmember. I have read contradicting threads regarding the legacy crossmember fitting with a wrx swaybar as well though. I am just really confused, I would like to order the legacy unit but don't want to have dick with finding a legacy sway bar to fit. Please inform so I can go down to Subaru in the morning and order one up. Thanks guys!
kbahus is offline   Reply With Quote
Old 03-02-2006, 12:01 AM   #2
JDM_Scobaru
Member#: 57809
So wait, your deciding whether or not to get either crossmember because of what swaybar to use? First, I used the legacy turbo crossmember for my swap, direct bolt-in, for a WRX one, you have to use spacers for the control arms. The crossmember didn't affect the front swaybar at all. Cusco makes a front swaybar for the GC with either the WRX/Legacy crossmember, and you can use almost any front endlinks for the front swaybar. I would go that route.
Zach
JDM_Scobaru is offline   Reply With Quote
Old 03-02-2006, 01:16 AM   #3
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
I'd go for the legacy turbo x-member, if you dont mind paying a little more. You already have so much to do with the swap, whats the point of spending extra time dealing with the shims
Old 03-02-2006, 09:32 AM   #4
kbahus
Member#: 70256
2000 STI V2 Swapped
I really didn't want to mess with shimming anyways. Off to the dealership....Thanks again
Old 03-02-2006, 10:55 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Got your PM. Don't go to the dealership yet. I may be able to help...
Old 03-02-2006, 01:24 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 5MT EJ22T AWIC Swap
The shimming of the LCA mounting is the only thing that is going to be different.
The only issue with the swaybars....and I'm not even sure it is.....is between the WRX wagon & sedan. I know the sedan has a wider stance, but don't know if the sway bar mounting stayed the same between the sedan & wagon LCA's. If they did, then there is no difference in swaybars between the WRX & tleg. If they're not the same, you'd just need to make sure to get a bar for a WRX wagon.
Legacy777 is offline   Reply With Quote
Old 03-02-2006, 05:14 PM   #7
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Do the legacy turbo. Thats what i did. And it worked perfectly.
subbyspeed is offline   Reply With Quote
Old 03-03-2006, 01:25 AM   #8
kbahus
Member#: 70256
2000 STI V2 Swapped
What sway bar are you guys running with the legacy crossmember?
Old 03-03-2006, 01:21 PM   #9
JDM_Scobaru
Member#: 57809
cusco 21mm
Old 03-04-2006, 10:28 AM   #10
kbahus
Member#: 70256
2000 STI V2 Swapped
Is it the one for the wrx sedan, wagon, gc8 sti, or legacy fitment? Whiteline lists them all as different part numbers.
Old 03-04-2006, 02:14 PM   #11
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Originally Posted by JDM_Scobaru
cusco 21mm
me too.
Get it from Z1. Its for a GC with turbo swaps only.
Old 03-07-2006, 02:06 PM   #12
Legacy777
Member#: 4800
Whiteline is a little stupid when it comes to this.
I believe they list the BSF18 for the turbo legacy. It has a bend in it....for what reason I don't know.
I'm currently running the BSF20 on my turbo legacy crossmember, and it's straight across. Works fine.
The bends are there on the n/a setup to clear the headers.
Pics of the BSF18
http://www.main.experiencetherave.co...tiswaybar1.jpg
http://www.main.experiencetherave.co...tiswaybar2.jpg
BSF20
http://www.main.experiencetherave.co...ages/ej22t/14/
The WRX ones will probably work, but the ends may be setup for the newer style drop links.
Legacy turbo VS Legacy NA Radiator support and dimensions ciper Pre-2002 Factory Turbo Powertrain 4 07-11-2009 09:43 AM
Legacy GT vs WRX x5-992 Legacy Forum 59 04-06-2006 05:00 PM
wtb locally: legacy turbo xmember/wrx wiring harness/wrx fuel pump legacy2003 New England Impreza Club Forum -- NESIC 16 06-24-2005 02:19 PM
WRX turbo vs WRX STi turbo twlai Factory 2.0L Turbo Powertrain 3 12-06-2001 04:52 PM
Message Board Statistics All times are GMT -4. The time now is 02:42 AM.
