Old 03-02-2006, 02:28 AM   #1
prlblkwrx02
Member#: 104773
Question Ignition timing on 02 wrx
I want to know how to check ignition timing on 02 wrx by using timing gun.
prlblkwrx02 is offline   Reply With Quote
Old 03-02-2006, 02:32 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....uuummmmmm......w 0 w....didn't know ya could
Old 03-02-2006, 02:42 AM   #3
prlblkwrx02
Member#: 104773
Smile
Awesome thank you very much
Old 03-02-2006, 01:10 PM   #4
Division By Zero
Member#: 7555
Although there is a rubber cover over the flywheel on the back of the block. There probably is a way to check it via the flywheel but I haven't done that before.
Division By Zero is offline   Reply With Quote
Old 03-02-2006, 02:13 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
You might not feel that way when you get to:
4) Insert the cartridge to the SUBARU SELECT MONITOR.
If you look closely at the crankshaft pulley you'll find the timing marks for the #1 cylinder embossed on the block.
Jon [in CT] is offline   Reply With Quote
Old 03-02-2006, 02:27 PM   #6
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
I use the www.pocketlogger.com to view most of the sensors, timing and to clear CEL's if needed. It plugs into the OBD2 port. Its a neat package.
You can data log from it too, and DL to your computer for viewing.
But I know there are quite a few other products out there that do the same.
Just another option.
gpd323 is offline   Reply With Quote
Timing an 02 WRX Austintitan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-21-2008 04:31 PM
Local prices for Timing Belt on 02 wrx Rambo Texas Impreza Club Forum -- TXIC 6 03-17-2005 10:05 AM
ignition timing on MY00+ ecu inpreza kid Normally Aspirated with bolt-on Forced Induction Powertrain 0 11-28-2003 09:55 PM
Procedure to set timing on 02 wrx engine? Aspen_2.5RS Service & Maintenance 5 09-01-2003 10:50 PM
Timing Belt 02 WRX tellravi Service & Maintenance 7 08-21-2003 03:57 PM
