Old 03-02-2006, 06:07 AM   #1
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Default Ap Installed
installed my AP yesterday and drove 50 miles after, how long down it take to fully read and adapt to ECU? I felt the difference when i added it on as stage 2, do I have more to look forward to?
Boxer112 is offline   Reply With Quote
Old 03-02-2006, 09:21 AM   #2
-Kevlar-
Member#: 82378
after about 50 miles it should be there. i only had to drive for about 25 miles before i really started to feel it.
-Kevlar- is offline   Reply With Quote
Old 03-02-2006, 11:41 AM   #3
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
300 ish before it's comfortable imo.
parker/slc/gc8fan is online now   Reply With Quote
Old 03-02-2006, 11:42 AM   #4
Rev1
Member#: 51240
08 Lexus IS350
Give it about a week, more or less.
Rev1 is offline   Reply With Quote
Old 03-02-2006, 12:01 PM   #5
tuskenraider
Member#: 65699
15 WRX
WR Blue
You could also try a Vishnu reset detailed here to speed things up: http://forums.nasioc.com/forums/show...hreadid=302047
tuskenraider is offline   Reply With Quote
Old 03-02-2006, 12:03 PM   #6
jays05
Member#: 78165
05 STI 35r + e85
Yup, do the vishnu reset and you're good to go as far as performance goes. The remaining ECU learning will mostly be long term fuel trims affecting idle and part-throttle driving.
jays05 is offline   Reply With Quote
Old 03-02-2006, 12:34 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....ya REALLY wanna know what to do???????
Here it is all simple like....
When ya have a couple hours or so---FIRST THING WHEN THE CAR IS STONE COLD.....disconnect the battery and pump the brakes---push the horn---lock-unlock doors.
Re-connect battery...get in car....DO NOT TOUCH THE GAS PEDAL AT ALL.......push in clutch and turn the key---it may not start right away but that is OK...and it may run a bit rough for a bit---LET IT....
but DO NOT TOUCH THE THROTTLE.....leave car idle.....
Go inside and have sammich---knock off quick piece with gf...whatever....for 15-20 minutes......go back outside and see if the radiator fans have started to cycle---meaning that the engine is at operating temp.....fans cycle...go to next step---fans NOT cycle....wait.
Next step is to, WITHOUT TOUCHING THE THROTTLE AT ALL, turn the car off and remove the key....count 10....put key back in and start the car and go drive it in the manner in which you want the ECU to learn for an hour or so....and done.
This is a full re-set...and ferget the vishnu thing.
Old 03-02-2006, 12:46 PM   #8
hondaeater69
Member#: 60324
Originally Posted by Uncle Scotty
....]...and ferget the vishnu thing.
i agree, just drive the car and let it learn on it's own, tricking the ECU into a higher DAM then what it wants is not a good idea. Just drive up a big hill under boost (but not WOT), you'll be able to WATCH your DAM go up
Old 03-02-2006, 08:31 PM   #9
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
i'm driving down to new jersey sunday morning which is 175 miles. drive it hard on the way down for best results???
Cobb AP installation, what the **** am I doing wrong? breathinez Engine Management & Tuning 32 07-23-2005 01:31 AM
Any pics of AP installed on STi? jsavage Engine Management & Tuning 23 07-09-2005 11:29 AM
CEL P1446 after AP install on 2005 OBXT doogdog Engine Management & Tuning 5 03-23-2005 08:52 PM
Might need some help with Cobb AP install (Portland Area) Dark Baal North West Impreza Club Forum -- NWIC 5 03-04-2005 11:47 AM
Cobb AP install AC7880 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-19-2004 10:35 PM
