Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 03-02-2006, 08:28 AM   #1
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default IAC on Hydra, 75mm TB
I'm using a 75mm Mustang TB on my project, and the very few who have successfully done this are not forthcoming. Don't worry, I will be. It's not rocket science, for Pete's sake.
What I'd like to know before I purchase the TB is:
-Is the IAC on the stock WRX or STi (DBW) a stepper motor, or solenoid? Is it on/off, or does it have a range, relative to idle speed desired?
-How does the Hydra control this? PWM output? Can a IAC be "remotely mounted", i.e. not on the TB machined surface?
Thanks to the great minds on this forum,
S.
n2xlr8n is offline   Reply With Quote
Old 03-02-2006, 09:00 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
steve, i can give you SOME information on the IAC on the stock rig:
1) i believe it is a stepper motor--it's certainly not an on/off solenoid.
2) it does have a range of flow rates from wide open to fully closed.
3) it seems to be controlled via a single conductor, which would indicate PWM control. the 03 ecu pinout from http://www.northursalia.com/modifica...ng/wrxpin.html seems to back this up, showing possible values of either 0vdc or battery voltage, and having a "waveform" shape.
hth
ken
edit: oh yeah, one other thing: there is NO discreet iac on the throttle by wire setups, since it just uses the throttle plate itself as the iac.
Old 03-02-2006, 09:04 AM   #3
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Somehow I knew you'd be the first to know.
Thanks, Ken. I suppose that Phil will have something to say about this, as well.
S.
hth
ken
Old 03-02-2006, 09:19 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
not the first to know, just the first to goof off while "working" and make yet another post to nabisco!
i enjoy following your build up as it progresses. you'd better be a chatty cathy with the info when it's done!
Old 03-02-2006, 10:30 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ok, did a bit more research:
first, did some reading on stepper motors. they all generally require multiple connections so that more than one coil/winding may be fed current. this is how they are able to move in discreet steps and retain precision and repeatability.
so, i went out to my car and popped the hood. three wires are connected to the IAC itself. but only one wire is pinned out from the ecu... hmm. where are the other wires going?
then i hit the old FSMs i have on my computer.
there are the three connections to the iac on the tb. pin1/white goes right to the ecu, so there's one down. follow the S and T connections to another page...
there's T. the thing labeled GE1 is just an engine ground point. two down, one to go... S. S appears to be a power supply rail, feeding purge control solenoid, and the 4 injectors. it also branches off from injector 1!
point R feeds the wastegate solenoid and the mass airflow sensor, then continues on as point O.
point O hits the main relay and ECU. it also continues on as point E:
point E feeds the drain valve and pressure control solenoid valve:
when the main relay is energized, point A is shorted to point E. point A is battery, thus feeding ALL of the above sensors and actuators with 13vdc.
if by now you are thinking as i am, then you'll be thinking that this is some crazy assed wiring path. obviously it was intended to be easy to install as a complete harness which enabled the engine to be easily pulled, but, electrically speaking, it absolutely sucks. there is no reason to have four injectors, a purge solenoid, an IAC and a wastegate solenoid (all constantly switching on and off and drawing a not inconsiderable amount of current) sharing a power supply rail with the MAF sensor!!!
back to your original question, i found this here http://www.megasquirt.info/ms2/IAC.htm:
Note: Beginning in 1985, Ford multi-port EFI uses an Idle Air Control (IAC) valve, which allows air to bypass the throttle plates. Unlike the stepper motors used by GM and Chrysler, the Ford units only have two terminals and one winding. These units regulate IAC plunger position using pulse width modulation (PWM). The idle speed is controlled by applying varying duty cycle percentages.
judging by the lack of multiple control terminals for our IAC i have to conclude that this is probably what we're talking about.
what to do about the mess of electrical current paths is for another thread.
Old 03-02-2006, 10:55 AM   #6
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Wow.
That seems to be my conclusion, as well.
I'm thinking the Mustang TB will work fine regardless, because the Hydra's control of IAC is PWM.
I determined a while back (with the grounding mod, lol) that my Subaru wasn't EMC / UL compliant. Junior engineers with no RFI experience on the harness.
Thanks for the help, Ken. I appreciate it.
Steve
Old 03-02-2006, 11:09 AM   #7
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The WRX has a solenoid valve and not a stepper ISC valve. The Hydra controls this via a PID algorithm so itís not a straight forward PWM map that the user can adjust. You will have control over the proportional, integral, and derivative of this function along with a minimum PWM duty, a maximum PWM duty, and if you upgrade to software 2.16-2.17 it also adds maximum PWM duty based on coolant temperature.
I donít see you running into any problems that cannot be tuned out.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 03-02-2006, 02:10 PM   #8
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Thanks,
Phil
Wonderful news
Thanks, guys!
S.
Old 03-02-2006, 03:55 PM   #9
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Sorry, but I will have to be the one to ask the dumb question. What will swapping to the Mustang TB do for you overall?
offset
offset is offline   Reply With Quote
Old 03-02-2006, 04:07 PM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
n2xlr8n-can I ask where you got the TB and how much? I am needing one for my H6 project and a true 3" TB would be ideal, especially if they sell TB flanges for these things too
thanks
Ben
Old 03-02-2006, 04:13 PM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ben, a quick search turned up these:
http://www.mustangtuning.com/ac75pothbo9g.html
http://www.carshopinc.com/product_in...ducts_id=43302
http://www.lildevilmotorsports.com/f...dy-p-9240.html
looks like around 225 or so. i suspect making your own mounting plate will be required to interface to your intake plenum of choice.
Old 03-02-2006, 04:26 PM   #12
PHATsuby
Member#: 13617
2001 Legacy GT back
thanks ride5000, I was checking ebay too. Will these use our stock TPS sensors, or will that need to be sourced as well. Sorry for the semi hijack.
Also, I am fabricating my own intake manifold, so basically whatever TB I choose I either need to model a flange in solid works and have CNC'd or if I can find one to buy that would save some time
thanks for the help.
Ben
Old 03-02-2006, 04:55 PM   #13
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
offset
At the power levels we're seeing, it's likely to be the next restriction.
I figured I'd try it out.
Normally, I wouldn't go to a larger TB unless I had extended my upper rpm range, but I think in this application, it warrants a test. In FI applications, TB size is not as critical as Carbureted.
S.
Old 03-02-2006, 04:59 PM   #14
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Ben
I'd imagine it would depend on the EM, but it's standard 5v TPS sensor. If you are using a Hydra, it shouldn't be an issue, but I'd ask Phil, anyway.
For those that are interested, my friend makes billet TBs for the LS1/Mustang parts vendors (the big ones) on his CNC lathe / 3 axis machine. He is making mine. If the interest is there, he can make several. I'd imagine the cost to be in the neighborhood of $375. More expensive than cast, but it's billet.
HTH
S.
Old 03-02-2006, 05:02 PM   #15
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
thanks
Ben
Sorry, I missed your post.
I couldn't find anyone willing to sell a adapter. Sponaugle had mentioned fabbing one, but I haven't heard anything back in months.
I think you're going to be in the same boat as I.
My Magnus manifold came with the needed 75mm flange
S.
Old 03-02-2006, 05:14 PM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
I am running the Hydra as well, just wondering if our TPS will bolt to the slot they have for TPS on the mustang TB.
I can fab a flange no problem, it is just more things to do on a an already high list, haha.
Thanks for the info.
Ben
Old 03-02-2006, 06:48 PM   #17
bboy
Member#: 56468
04 Improved STI
Dirty White
You got all the info.
How much bigger is the Mustang TB? Seems like mine is pretty close to 3 inches which would be 76 mm. Or......is it the same size and your building a new plenum-intake-manifold.....mmmmmmmmmm..
Old 03-02-2006, 07:20 PM   #18
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
IIRC, the stock WRX/STi is 65mm, so 1cm. The mustang TBs come in many sizes.
Magnus TGV-less manifold, 75mm TB flange, N2O bosses (for future expansion), and plenum rev 25,178. It makes power where I want it.
S.
Old 03-02-2006, 11:59 PM   #19
boogerwrx
Member#: 13448
2002 wrx wagon
Just to add a quick note. Electromotive makes an adaptor so you can bolt on a GM IAC motor onto any aftermarket Mustang style throttle body if you want to go that way. I think they run $50-75 each and you can pick up a GM IAC from any local yard for $5.
Ron
boogerwrx is offline   Reply With Quote
Old 03-03-2006, 11:18 AM   #20
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Ron
Thanks, Ron; that's great info.
I'm assuming you've done this also?
S.
Old 03-03-2006, 04:37 PM   #21
bboy
Member#: 56468
04 Improved STI
Dirty White
Well that sounds like fun. 1 cm will yield you a lot more flow capacity.
TOP FEED:***MAGNUS intake, 75mm tb and 1600cc fuel setup oneoverWRX Engine/Power/Exhaust 6 03-01-2010 08:01 PM
IAC on a 2002 suzuki4life Normally Aspirated Powertrain 0 07-01-2008 12:51 PM
Location IAC on 2002 RS imprezkid Normally Aspirated Powertrain 2 12-19-2006 10:13 PM
Help to eliminate knock on hydra RemlapaN Other Engine Management 14 11-20-2005 01:57 PM
funny idle oscillations on Hydra Matrix 1193 Other Engine Management 1 12-01-2004 09:54 AM
