Old 03-02-2006, 10:52 AM   #1
Division By Zero
Member#: 7555
Default Green connectors under driverside dash plus a white one
Guys, last year, I had a little engine fire and since it singed the bulk and engine harness' they got replaced under my insurance. Well this also required the entire dash to come out and was a huge job. To this day, I am still finding an anomoly in their work
So anyway, you all know about the green connectors under the dash? Well they're not supposed to be connected AFAIK. The whole time they've been connected until yesterday when I was doing some under dash wiring. I of course disconnected them but I also noticed a white connector that's unplugged too and, which is right next to the green ones. I don't see another plug to connect it to though. And, IIRC (I'll have to check on this later) I believe there might be a black unconnected one as well I'm not sure of that.
As far as the green connectors, I thought the car would be in some kind of limp mode?? It's kind of odd that the car was running for the last 3.5k miles with them connected. I wonder if the UTEC was overriding it or something. What do they do exactly?
Division By Zero is offline   Reply With Quote
Old 03-02-2006, 10:58 AM   #2
-Kevlar-
Member#: 82378
unplug the green conn. on the drivers side and look for the same on the pass side. <--- plug them. the white one isnt supposed to be plugged in to anything.
-Kevlar- is offline   Reply With Quote
Old 03-02-2006, 10:59 AM   #3
hondaeater69
Member#: 60324
The green ones are for putting your car into test mode when the key is turned into the on position. It should not be connected on a regular basis, but if it were, you would surely know (your car would really run like poo).
The white has something to do with the ECU. . it should be disconnected, unless you use flashing SW, then it can be plugged with a jumper plug (Not actually connected to anything else if that makes any sense). I leave my white plug in all the time, this doesn't effect the operation of the ECU, only allows you to flash it.
Old 03-02-2006, 11:07 AM   #4
Division By Zero
Member#: 7555
Can you elaborate a little? I don't understand
Maybe it's the way you said it or something Looks like you're saying that there's an identical looking set of connectors on the pass-side and to connect one of those to one of the ones on the driverside??? I don't see that being possible.
Old 03-02-2006, 11:10 AM   #5
-Kevlar-
Member#: 82378
yes there are two sets. the pass side ones stay plugged and in order to go into test mode the drivers side (both sides) have to be plugged in. like 69 said they are for putting the car into test mode. sometimes the pass side ones will be unplugged, so just plug them up and leave the drivers side unplugged. sorry if im confusing im trying to type fast...
Old 03-02-2006, 11:14 AM   #6
Division By Zero
Member#: 7555
Okay, wrxblubayou. Thanks for clarifying. I'll have to check the pass-side today.
Old 03-02-2006, 06:53 PM   #7
rewt
Member#: 60794
2007 Solstice GXP
The green connectors are "test mode" connectors as everyone else has been stating. When plugged in, they put your car into a diagnostic mode.
The white connector next to them is the flash block; it should only be connected if you're reflashing your ECU, and there should be no corresponding connector for it.
rewt is offline   Reply With Quote
Old 03-02-2006, 10:41 PM   #8
Division By Zero
Member#: 7555
Hey rewt, I appreciated the input but was it neccessary to repeat what was already stated like several times Thanks anyway though.
Old 03-03-2006, 12:03 PM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
todd, these connectors?
ride5000 is online now   Reply With Quote
Old 03-03-2006, 12:06 PM   #10
Division By Zero
Member#: 7555
Ken, so the white connectors should be connected then?
Old 03-03-2006, 12:15 PM   #11
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
tmarcel, so the white connectors should be connected then?
The 3 conectors should look exactly like the ones in the picture above
ALL 3 OF THEM DISCONNECTED
kevin2.5rs is offline   Reply With Quote
Noticed a green connector under the dash disconnected? ret63 Car Audio, Video & Security 8 05-06-2010 09:12 PM
The unhooked green connector under the dash? fizzak Newbies & FAQs 6 12-22-2005 11:43 PM
Green Connector under steering dash in 04 STi. LESLIEx317537 Electrical & Lighting 2 07-27-2005 07:05 PM
That green connector under dash DDMan Car Audio, Video & Security 0 01-20-2002 05:38 PM
Weird green connector under dash? Eric SS Technical Forum Archive 4 08-27-2000 06:51 PM
