Old 03-02-2006, 06:52 PM   #1
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
Default Dash Swap HELP!
I'm doing a complete 03 wrx swap into my 1998 RS. The engine and harness is not the problem.
I have come into the issue of the Dash bar. I am swapping the complete dash over as well, and need to know if there are any modifications that are needed when doing this. We have not been able to mount the bar into the RS in the stock spots, and are curious of what people have done to fix this problem.. thanks in advance for your help..
and yes i did a search and nothing has come up that would help me out.
eric
the_short_bus is offline   Reply With Quote
Old 03-02-2006, 07:41 PM   #2
BoostinEJ20
Member#: 73710
are you doing a write up on this swap? thatd be awesome! sorry i cant be of any help (n00b) but i always said if anything happened to my wrx with body damage (major) id attempt to swap into an older rs...good luck!!
BoostinEJ20 is offline   Reply With Quote
Old 03-02-2006, 07:49 PM   #3
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
there's a guy over on rs25 that's done it a few times, east coast swapers I think. From what I remember you have to move the bar down a few inches or something to that effect. so basically you wont use the stock RS mounting points, going to have to drill & tap some holes.
probably going to have to do a lot of test fitting.
looks sweet when it's all done
XENONSVX is offline   Reply With Quote
Old 03-02-2006, 07:57 PM   #4
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
yea i will do a write up on this when its done, but just was curious if there was someone who had some insight before we do all the tapping and test fiting.
Old 03-02-2006, 08:22 PM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Didn't paul walk you through this on the phone?
jamesfacts is offline   Reply With Quote
Old 03-02-2006, 08:50 PM   #6
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
no, he said he wasn't sure which bar he used. if you know or could give me some insight that would be great.
Old 03-03-2006, 07:54 AM   #7
Nitro Don
Member#: 19820
2007 NINJA ZX-10R
Your going to have to trim the 03 dash bar. In the center of the bar,where it bolts to the trans tunnel,there are four holes on the bar.The bottom two need to be cut off. You might need to trim it up a little to so it fits properly.Now the dash is at the right height.
Next,cut off all the studs on the chassis,(where the bar bolts to the door area).Then mount and bolt the bar into the chassis using the lower floor (two) bolts.
Now you should be able to move the whole bar back and forth.
Now take a level and ruler and square up the top of the bar using C-clamps to hold it in position.
Take a drill and using the holes in the 03 dash bar drill out the chassis sides.
Finally using carrage bolts slip them through the chassis holes and tack weld them in place. These will be your "new" studs.
Nitro Don is offline   Reply With Quote
Old 03-03-2006, 09:05 AM   #8
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
pmed you...
Old 03-03-2006, 11:37 AM   #9
jamesfacts
Member#: 51282
98 RS
He (we) use the WRX one. Maybe he wasn't sure which one you were trying to use?
Old 03-03-2006, 02:44 PM   #10
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
actually i spoke with paul last night and cleared up the confusion. thanks again james
eric
Old 03-06-2006, 12:24 AM   #11
the_short_bus
Member#: 106593
2008 impreza 2.5i
Dark Grey
update: after actually doing this we came to find a easier way to get the dash to fit without having to cut the studs and re-weld "studs" (bolts)
there will be a write up with pictures after i'm done with the swap
Old 03-06-2006, 09:08 PM   #12
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Sweet! I'll be interested to see how it looks when it is done!
sheepdog is offline   Reply With Quote
Old 03-19-2006, 06:00 PM   #13
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
the write up that you are all asking for http://www.rs25.com/forums/showthrea...3&page=2&pp=20
-Paul
PumpsGOTAWD is offline   Reply With Quote
COMPLETE 05 sti dash swap, EVERYTHING hvac,radio,dash,centerconsol+++ Ctracer911 Interior/Dressup/Audio & Security 15 10-22-2009 07:22 AM
03 WRX dash swap into 95 GC8...Help? scoobmaster95 Subaru Conversions 1 06-17-2009 12:53 PM
Dash Swap Wiring Help Needed XanRules Subaru Conversions 3 01-20-2009 02:26 PM
HVAC dash swap help piker28 Interior & Exterior Modification 2 03-29-2007 12:28 AM
dash swap and motor swap questions aka_tur Subaru Conversions 6 02-27-2007 05:21 PM
