Old 03-02-2006, 07:05 PM   #1
BBBsti LTD
Member#: 71682
2007 WRX Sti LTD.
Default Will COBB AP fix the CEL with HELIX DP?
I'll be getting UP/DP (HELIX) and COBB AP. Does the COBB AP take care of the CEL or do I need the mec. fix???
BBBsti LTD is offline   Reply With Quote
Old 03-02-2006, 07:19 PM   #2
hondaeater69
Member#: 60324
AP will take care of all DP and UP CEl's.
Old 03-02-2006, 07:41 PM   #3
NorthCoastWRX
Member#: 99176
04 WRB STi Stg II
[email protected]
I just put on a Helix DP and went to Stage 2 with my AP.
No CELs
NorthCoastWRX is offline   Reply With Quote
Old 03-02-2006, 10:51 PM   #4
Jasvboost
Member#: 37160
RIP 04 Stg2 JBP WRX
07 SWP WRX 335/350 HTA68!
I'll be able to tell you on Monday.
Jasvboost is offline   Reply With Quote
Old 03-02-2006, 11:07 PM   #5
pingpong
Member#: 108539
2004 wrx sedan
I have the Helix DP w/ cat and before I got Cobb AP, I had a PO139 "rear o2 sensor circuit slow responce" cel code. After I got AP stage 2 put on, the previous code went away but I picked up a PO420 "catalyst system efficiency below threshold" code. While the weather was cold it stayed away, but when it gets warm (the weather), it comes on a few days after I clear it. I've been told by a few different people that a protune would fix it, that the higher flow is just outside the ecu's parameters.
Hope that helps.
pingpong is offline   Reply With Quote
WTB : : COBB AP v 1/2 , titek , helix, up / dp , CBE gnabgibeht Private 'Wanted' Classifieds 0 04-25-2007 08:15 PM
will cobb AP work with a reflashed ecu??? south_texas_scoobie Commercial ECU Reflashes 2 06-03-2006 04:29 PM
COBB AP fix up pipe cel? nutzkicker617 Engine Management & Tuning 2 09-07-2005 12:57 PM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 12:53 AM
CEL installed Helix dp jatyrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-21-2003 09:48 AM
